Old 07-14-2015, 02:24 PM   #1
John Rambo
John Rambo's Avatar
Drives: Turbo BRZ Limited 6MT
Black Flakes in Coolant Reservoir??
So there I was, poking around in my engine bay, when I noticed that there were some black specks floating around in the coolant reservoir. I took it out and dumped the coolant out and found that there was a lot of gunk and quite a few of them collected at the bottom...
Upon inspection, they don't feel like a hard material and are rather soft. I have FI and a koyo radiator, and had a flush done when it was installed less than 10k miles ago.
So should I do a coolant flush and forget about it? Or is this something to worry about?
John Rambo is offline   Reply With Quote
Old 07-14-2015, 04:29 PM   #2
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
It's buildup from internals of radiator, tubes..etc. Its also duo to water if you add 1/2 and 1/2. Not all water is filtered the same. Never use water straight from your hose. Upon heating and evaporating, many of the times it leaves a white-ish residue like salt. Also, some coolants have little floating objects in them we rarely notice to stop micro leaks.
Haven't done it on my car, but on my truck I flushed coolant, pressure washed what I could, added coolant again, ran truck for a 45mile round trip, flushed it out again and finally added coolant once more. I still notice stuff like that though. It is a waste of coolant following my actions... There's also these mini filters you can buy. Maybe another member can shed more light on them.
The Following User Says Thank You to Packofcrows For This Useful Post:
John Rambo (07-15-2015)
Old 07-14-2015, 05:44 PM   #3
Scott@HKSUSA
Scott@HKSUSA's Avatar
Drives: 2013 FR-S, HKS V2 S/C
Typically that will just be debris from the cap seal or any of the rubber lines in the system. If it's soft like you say, I'm confident that's what you're seeing. It's common with new cars, won't hurt anything, and will eventually cycle out with regular maintenance.
Scott@HKSUSA is offline   Reply With Quote
The Following 4 Users Say Thank You to Scott@HKSUSA For This Useful Post:
DieselDog (07-14-2015), humfrz (07-15-2015), John Rambo (07-15-2015), tyrantcf (07-15-2015)
Old 07-14-2015, 08:45 PM   #4
steve99
Drives: FT86
Did they use the subaru blue coolant or equlivant, if different type of coolant used you may get weird reactions or precipitates.
Old 07-15-2015, 01:39 AM   #5
It's just little pieces of "stuff"; I wouldn't worry about it .....
Old 07-15-2015, 03:20 AM   #6
tyrantcf
Drives: '16 WRX, CBR1000RR
First time I read the title I saw it as saying: "Black flakes in my corn flakes" for some reason.
Glad it was merely the coolant overflow tank.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
The Following User Says Thank You to tyrantcf For This Useful Post:
Old 07-15-2015, 05:36 PM   #7
John Rambo
John Rambo's Avatar
lol about the corn flakes. Had that happen once. It was a family of moths.
Thanks for the replies, I think I'm going to do a coolant flush and forget about it. I was meaning to do one anyway to run straight water + mocool or water wetter to help with temps in the summer.
The tech at Evasive Motorsports said it's common on the WRX and I shouldn't worry about it
The Following User Says Thank You to John Rambo For This Useful Post:
Packofcrows (07-15-2015)
Old 07-15-2015, 06:58 PM   #8
Packofcrows
Found cockroach leftovers in my Kix at age 5. Ate around cockroach shells. Had to remind me of that. Being poor was always a b!tch.
*SOLD* Cusco Coolant Breather Tank Water Reservoir Air Remover Bubble hirollaz Engine, Exhaust, Bolt-Ons 10 04-25-2016 12:33 AM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 06:56 PM
Gilroy meet/cruise (Uva's Reservoir) StayTrueSF Northern California 9 09-01-2013 10:54 AM
Reservoir Clamps/Mounts swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 07-15-2013 10:23 PM
Quabbin Reservoir Cruise - 6/8/13 Chewie4299 New England 118 06-12-2013 05:55 PM
