Old 03-31-2012, 05:47 PM   #15
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Originally Posted by ft86Fan View Post
The turbo still uses the small blue crap filter... Now that you mentioned that Tokyo Roki oil filters are better than the Mobil1 filters I might have to take your advice.
The turbo motors are still EJ255's, so they still use the old filter size.
I don't think I'd say that Tokyo Roki > Mobil 1. They're comparable in terms of build quality, it's just that the OEM filter is better suited to this particular application.
old greg is offline   Reply With Quote
Old 05-29-2012, 11:03 PM   #16
Enigmus
Enigmus's Avatar
Drives: 1996 Integra LS 4DR, 2013 Scion FRS
Originally Posted by old greg View Post
It's definitely not going to be the M108, the new style filters are much larger than the old ones, which themselves are much larger than the M108.
Shitty old-school Honeywell (Fram) blue OEM EJ filter next to a shiny, well made Tokyo Roki OEM FB/FA oil filter (PN: 15208AA130) in Black .
Attachment 5813
And while I was digging around, I found this. It's an FB25 with a K&N HP1004 (equivalent to an M104).
Attachment 5814
That said, you're probably better off sticking to the OEM filter once you use up your stash of M1's. Tokyo Roki makes high quality filters and Subaru specifies a stupidly high bypass valve pressure, meaning that aftermarket filters will be allowing a lot more oil to bypass the filter element than Subaru recommends. The Tokyo Roki OEM filters are valved to Subaru specs, are very solidly built and they're only ~$6.50.
Where are you buying them from? PM me please
Enigmus is offline   Reply With Quote
Old 05-30-2012, 12:24 PM   #17
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I just got off the phone with Purolator. The stock Subaru filter crosses to a L14459 or PL14459. These have a 12-18lb bypass which might not be high enough unless the Purolator has about twice the media surface area. I think I might switch to these regardless as I've heard a lot of bad things about the new Subaru blue filters.
The Following User Says Thank You to Draco-REX For This Useful Post:
civicdrivr (05-30-2012)
Old 05-30-2012, 07:27 PM   #18
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Sweet! That means the same filters I use on the CL will work on the FR-S.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 05-30-2012, 07:31 PM   #19
Fly Guy
Fly Guy's Avatar
Drives: '91 MR2
But it's the Tokyo Roki black filter.
Tada-san: Oh so cooler than the concept.
Fly Guy is offline   Reply With Quote
Old 05-30-2012, 07:40 PM   #20
TwinscrollGT35R
Drives: 2006 Subaru
Why???? If something happens, Your covered. If something happens to the purolator, Good Luck!
TwinscrollGT35R is offline   Reply With Quote
Old 05-30-2012, 07:43 PM   #21
TwinscrollGT35R
Drives: 2006 Subaru
This may not apply to really anyone here. But on the subaru's some have to run the smaller filter as their turbo set ups get in the way. Like mine. I run the FullRace twinscroll and I have to run the smaller filters.
Old 05-30-2012, 07:51 PM   #22
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
Until I find something with a similar bypass valve, Ill be sticking with the Tokyo Roki blacks.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
The Following User Says Thank You to mattles For This Useful Post:
Fly Guy (05-30-2012)
Old 05-30-2012, 08:17 PM   #23
ttknf
Drives: 350z Nismo, CBR1000RR
He's still covered. Warranties cannot be voided for maintenance items that aren't OEM unless the dealer/car marker provides them to customers for free. That's why you can use any oil that you want or any filter that you want.
ttknf is offline   Reply With Quote
Old 05-30-2012, 08:25 PM   #24
TwinscrollGT35R
Drives: 2006 Subaru
Care to back your claim with facts? And a link?
I can tell you right now if you have a oil related engine failure. And it doesn't have a oem oil filter. The factory rep is going to tell you to piss off.
Old 05-30-2012, 09:29 PM   #25
ttknf
Do some research on the Magnuson-Moss act.
You asked for a link, so here's the fastest thing I could pull up in Google:
http://www.greasemonkeyintl.com/magnuson-moss-act.php
Old 05-30-2012, 11:48 PM   #26
TwinscrollGT35R
Drives: 2006 Subaru
I used to teach the mag-moss act, I have also had have been around the block with a failed oil filter.
Once again. Please use your own words and place your links to back yourself.
Side note. Why does everyone have a hard on for not using OEM oil filter. The engine oil system was designed to use it. If Subaru could make a cheaper filter that did the same job do you think they would do it? Of course they would. That is more money in their pocket.
Old 05-30-2012, 11:50 PM   #27
TwinscrollGT35R
Drives: 2006 Subaru
Don't put all your eggs in one internet basket. Not everything on the web is correct! I think Grease monkey has a stake in making you think its OK to use their filters.
Old 05-30-2012, 11:54 PM   #28
mattles
Proud of FR Layout
mattles's Avatar
the magnuson-moss act isnt an internet thing, its a real US Federal Law.
I will direct quote from the Magnuson-Moss Act:
"Warrantors cannot require that only branded parts be used with the product in order to retain the warranty. This is commonly referred to as the "tie-in sales" provisions, and is frequently mentioned in the context of third-party computer parts, such as memory and hard drives."
Full-text for those that choose to educate themselves prior to buying a new or certified-pre-owned car:
http://business.ftc.gov/documents/bu...#Magnuson-Moss
Early proposal: FA20 with a FB25 shortblock, .5l more displacement anyone? Kostamojen Engine, Exhaust, Transmission 90 03-20-2022 06:05 PM
FA20 OEM pistons, are they Forged or Cast ? adprokid Engine, Exhaust, Transmission 54 10-11-2014 05:51 PM
Turbocharged FA20 targeted for 270hp. Confirmed for next gen WRX Hachiroku Engine, Exhaust, Transmission 50 12-10-2011 01:23 PM
FA20 for sale coyote AUSTRALIA 1 12-01-2011 12:53 AM
