Old 07-13-2015, 08:05 PM   #155
Kostamojen
One of my fins was bent too
Kostamojen is offline
Old 07-13-2015, 08:19 PM   #156
Lone Starr
Drives: WRB Limited
@ft86speedfactory @NotEric6
Both strakes bent and one has a sizable chip that goes down to bare metal. I've sent an email and am waiting for a resolution.
Tony
So...at last we meet for the first time for the last time...
Lone Starr is offline
Old 07-13-2015, 09:19 PM   #157
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Sorry to hear this. For those that decide they want to fix it themselves, the aluminum is very pliable. You can straighten it with wood blocks, some microfiber towels, and some pressure from your hands or a C-clamp.
Tony
I'm sure they will get back to you in a day or two. This is upsetting for both parties. Shipping companies are absolute barbarians and we will figure out how to avoid this in the future.
In other news, we heard what some of you were saying and we whipped up an alternative strake design. This is a more subtle design. We will run CFD on it in the coming weeks and ensure we did not lose too much efficiency. We are multiple months out on this design, I would say three minimum.
Thanks,
Eric
VerusEric is offline
The Following 7 Users Say Thank You to VerusEric For This Useful Post:
brandonblt2 (07-27-2015), civicdrivr (07-14-2015), DAEMANO (07-13-2015), kask2_6.0 (07-13-2015), makinen (07-18-2015), Pug_BRZ (07-14-2015), Teclis (07-18-2015)
Old 07-13-2015, 11:32 PM   #158
Kostamojen
My fin wasn't too bad, I was able to straighten it rather easily. I can see how it can get bent REALLY bad in shipping though with one wrong drop (Perhaps a FRAGILE sticker with an up arrow might help?)
My biggest problem however, is that this doesn't clear the stock midpipe at all... I'm more disappointed about this than anything else:
The cutout is obviously for center-pipe exhausts, I thought the stock midpipe would fit fine from looking at the list of exhausts but it just doesn't clear. I had to bend the heck out of it and I'll probably have to cut a good chunk out of it to get it to not rattle at any point
Other notes:
The plastic "bushings" should probably be replaced with something more sturdy or at least wider, giving the diffuser more support.
I'd recommend having more than just 6 mounting points, maybe 8 if you can find another two just for security.
Pics:
I like the design overall, the install was a little more difficult than expected but still not difficult. Overall I'm happy with the looks, not sure about the functionality yet (haven't driven it) and not keen on the install/fit on the car. I think it needs more work.
The Following User Says Thank You to Kostamojen For This Useful Post:
Ammunition (07-14-2015)
Old 07-13-2015, 11:37 PM   #159
VerusEric
VerusEric's Avatar
Other notes:
Pics:
I have the diffuser installed on a completely stock exhausted car and it clears. It is very tight, but it clears and I have yet to get it to rub. Are you sure the front portion of the diffuser is installed as low as possible? Are the spacers installed on the rear 4 mounting points? See the photo from earlier in the thread:
Old 07-13-2015, 11:42 PM   #160
Kostamojen
Diffuser is as low as possible near the midpipe. I couldn't lower it any more where it mounts to the swaybar brackets. My muffler has plenty of clearance though, its just the midpipe thats in the way.
An alternate version with the hole setup for the stock midpipe location would work better IMO. That way I could still get better flowing air where the big gaping hole is currently.
Old 07-13-2015, 11:56 PM   #161
johan
Drives: '14 981CS, '99 NB1
I know this would kinda suck, but seems you could take some tin snips and cut a small sliver off right at the edge of the pipe to make some clearance. I'm running the stock midpipe too, and am dreading the same issue. I'm wondering though if part of the key is that having the diff cover addition allows you to let the center of the whole thing sag a bit, giving a bit more clearance?
johan is offline
Old 07-14-2015, 12:00 AM   #162
Kostamojen
The diff cover won't change anything IMO, might actually make it more difficult to fit.
I plan on cutting it when I get a chance since its basically ruined from being bent anyway, but I ran out of time tonight. I'll drive it a bit and see if it rattles tomorrow.
Old 07-14-2015, 12:05 AM   #163
johan
Well I guess I'll find out tomorrow - if mine isn't destroyed in shipping.
johan is offline
Old 07-14-2015, 01:18 AM   #164
VerusEric
VerusEric's Avatar
The stock mid-pipe will clear with the stock muffler, on the website it states stock exhaust. I personally drive my car this way right now, for 300 miles, and still have an 1/8" of clearance just like I installed it. My best guess as to what is happening is that the axle back you have pushes the factory mid-pipe lower than the stock muffler does, causing your issue. All I can do is apologize at this point; we will add even more slotting for the front of the diffuser to sit lower for the next production run. Doing an alternative version of the main plane of the rear diffuser would logistically be very difficult.
I want to ask again, you used the spacers on all *4* rear mounting points correct? The outer two most mounting points look fairly close to the rear bumper but it could be the angle of the photo.
The Following 3 Users Say Thank You to VerusEric For This Useful Post:
Ammunition (07-14-2015), DAEMANO (07-14-2015), johan (07-14-2015)
Old 07-14-2015, 02:05 AM   #165
Kostamojen
The photo I took of the midpipe hitting was actually when I just barely had the bolts on (with just a thread or two holding everything on the car). I tried with lots of bushings or no bushings and it didn't change the clearance at all because its so close to the mounting points with the swaybar brackets.
Maybe if I loosen the muffler to midpipe bolts and rotate it a little I might get some more room?
Old 07-14-2015, 02:35 AM   #166
VerusEric
VerusEric's Avatar
How many spacers are you using on each point? It's odd that mine fits and yours doesn't .
Old 07-14-2015, 02:57 AM   #167
cslntuee
Drives: Subaru BRZ Limited
Originally Posted by erok81 View Post
Oh if I came off as saying it's bad product or anything negative against you guys, I'm not. I should have been more clear I guess.
It was more of a warning to others and a heads up to you guys. Check the box before the ups guy leaves (I don't even know if that would help). Also to improve the packaging.
I haven't contacted anyone on it. At first, while I was a little disappointed, it was more of a joke. I don't expect any compensation or anything. I bent it back and it's really close. Like I said I'm probably the only one that will ever notice.
I will say one thing...I've had other diffusers in the past so was expecting an easy go bending it back. Nope. This thing is well built. It took wood and some hammering to get it straight.
On a positive note...it looks awesome and fits great. Took about 20 minutes to install. Five of that was trying to figure out what the CAD drawing was for - I'd suggest popping on to ft86 speed factory for the very nice instructions. Otherwise you'll wonder what the hell the piece of paper is for.
This isn't the best picture but it looks good!
Did you need to do any modify to fit with your rear spats?
Thanks.
cslntuee is offline
Old 07-14-2015, 08:39 AM   #168
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
That's crazy those strakes are getting damaged so bad. And WTF on that fitment? I'm leaning towards Driveway Labs diffusers after seeing this.
xkalelx is offline
The Following 2 Users Say Thank You to xkalelx For This Useful Post:
DustinS (07-14-2015), Wonderbar (07-14-2015)
Just Ordered the Complete StopTech Brake Package from FT86 SpeedFactory naikaidriver Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 02-28-2017 02:48 PM
Single-Exit Exhaust Diffuser/Hole Problem... Solution! Anthony Cosmetic Modification (Interior/Exterior/Lighting) 75 10-13-2016 07:40 PM
Front Wheel Deflectors - FT-86 SpeedFactory by Verus Engineering VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 25 09-22-2016 01:41 AM
DriveWay Labs Rear Diffuser - FT-86 SpeedFactory FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 435 01-15-2015 07:20 AM
