#15 |
Now im confused.
Doesnt the STG 1 that visconti sells already comes with a ECUtek cable + license and the map for the vortech tune? What "zendesk" are we talking about here? |
#16 | |
I Love custom Turbo kits
Drives: Limited BRZ
I'm sure he has packages bundled with ECUtek cable and license and without.
#17 | |
SLO NO MO
Anyone buying Visconti's Vortech Kit can save some time by requesting the basemap file ahead of the install. |
| The Following User Says Thank You to Foobar For This Useful Post: | Sportsguy83 (06-01-2013) |
#18 |
Drives: Scion FR-S
Thank you so much for all the responses and help.
Turns out I pulled injured my neck so the install will be delayed by a few days (which coincidentally gives me more time to receive that map.) I won't run the car without it! |
| The Following User Says Thank You to kaybee123 For This Useful Post: | Sportsguy83 (06-01-2013) |
#19 | |
SLO NO MO
#20 | |
I see well this is what John said when i submit it my ticket. You'll need to submit a ROM Dump before I can send you a tune file. Pardon my ECUtek ignorance but how in the world can i do that? Edit, nvm found the tutorial |
#21 |
Drives: 2013 FRS
idk, just me but i wouldn't really do that if i were you. i was lucky to have john repsond pretty quick, but it seems like he is pretty busy this weekend. i had a ticket submitted about some questions with my vortech kit and haven't heard anything. rich was supposed to call me back, but never did sooo i assume they are pretty busy. just be ready to do a rom dump.
#22 | |
Drives: 2013 Asphalt FR-S
You have installed larger port injectors, a higher volume fuel pump, and likely a maf sensor with a wider range than stock.... In short, your fueling will be jacked up. Just for the sake of safety, don't do it. In most cases, when port only or port and DI are both active you will be over fueled. There is also a port injection trim table based on the map sensor, so once again... that will be wacked because of the map sensor change. Not to mention the timing map, the stock maf limit of 200g/s (will not read any higher than that and fueling stops increasing with more flow), the stock load limit of 1.3 g/rev etc etc etc. Still thinking about it... Just don't.
~Namaste~ |
| The Following User Says Thank You to mad_sb For This Useful Post: | Sportsguy83 (06-02-2013) |
#23 |
NASA SpecE30 Racer
As mentioned these are the primary things that will not allow you to drive the car until you get the tune:
MAF relocated and possibly different pipe size Upgraded MAP sensor (my car would not even start just swapping from OEM to 4 BAR MAP sensor) Larger fuel injectors Hopefully he got you your ROM this weekend.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#24 |
Drives: Raven Scion FR-S
I just installed my vortech no fuel pu,p without a tune and now I need a flatbed to the tuner bc my Will just stall out when I try and key the ignition... So don't even take the chance lol
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
| Vortech Supercharger with FA20Club.com Tune | msile | Forced Induction | 30 | 05-01-2013 01:12 AM |
| Vortech supercharger | skatery1989 | Forced Induction | 293 | 04-19-2013 04:58 PM |
| Does anybody know if the tune from the vortech is better than the ecutek? | Frsexxxy | Forced Induction | 16 | 04-08-2013 11:53 AM |
| Vortech supercharger. | skatery1989 | Engine, Exhaust, Bolt-Ons | 2 | 02-23-2013 07:19 AM |
| Vortech Supercharger FRS/BRZ | vividracing | Forced Induction | 5 | 01-29-2013 07:03 PM |
