Old 06-01-2013, 01:34 PM   #1
kaybee123
Drives: Scion FR-S
Vortech Supercharger Without a Tune?
Hey,
I'm installing the Vortech supercharger that I received from Visconti (Along with the injectors, pulley, fuel pump, etc) and the problem is that I don't have my tune yet. (I put a request in on Friday but I'm thinking they might be closed for the weekend)
Can I run my car without a tune after installing the supercharger and all the mods?
What will happen? Also, what kind of waiting time have people experienced for Visconti tunes?
kaybee123 is offline   Reply With Quote
Old 06-01-2013, 01:37 PM   #2
Lonewolf
Lonewolf's Avatar
Drives: Moped
I'm super anal about my cars...so for me, its staying in the garage until it gets a proper tune, haha.
If you keep it low in the rpm range and don't push the car too much in heat, then it should be fine.
The second the car starts bogging, pinging, or exhibiting other strange/unwanted behaviors, its time to take her home...
Old 06-01-2013, 01:41 PM   #3
DJCarbine
Thupercharged
DJCarbine's Avatar
Did you also get the upgraded MAP sensor?
I would say that this alone would make your ecu not exactly happy....
Worst case, keep the stock MAP sensor in and place the K&N filter included over the charge pipe port where you would normally plumb the bypass valve.
It should not produce boost and it should be fine to start up/move the car if needed. Lots of "Should"
If you are thinking about actually driving the car, I would not
2013 FRS
Vortech V3 11psi
Old 06-01-2013, 01:56 PM   #4
Foobar
SLO NO MO
Foobar's Avatar
I wouldn't risk it. The relocation of the MAF sensor alone is likely to cause issues without the tune if my experience with other intakes is any indication. The fuel pump, injectors, and MAP sensor will likely cause issues on top of that.
To anyone else waiting for their Visconti Vortech kit - for the love of god, get your software installed, Visconti zendesk account set up, and ticket submitted requesting the Vortech basemap. That way it's ready for you on install day.
Old 06-01-2013, 01:57 PM   #5
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
There is a lot of work put into making the ecu run the motor right for boost. DO NOT run the car without a tune or you will destroy your motor.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
The Following 5 Users Say Thank You to Wonderbar For This Useful Post:
charged86 (06-01-2013), Freeman (06-01-2013), RedAlert (06-02-2013), reyruiz191 (06-01-2013), Sportsguy83 (06-01-2013)
Old 06-01-2013, 02:26 PM   #6
kaybee123
Drives: Scion FR-S
Damn.
"To anyone else waiting for their Visconti Vortech kit - for the love of god, get your software installed, Visconti zendesk account set up, and ticket submitted requesting the Vortech basemap. That way it's ready for you on install day. "
Hrm, wish I would have read this a long time ago.
Old 06-01-2013, 02:29 PM   #7
jamesm
sure go ahead and try it. rip it up the road. cars make more power when they're way lean like that. racecar man! be sure to take pics, video if you can.
/sarcasm. seriously, don't do that.
The Following User Says Thank You to jamesm For This Useful Post:
Pete (06-01-2013)
Old 06-01-2013, 04:40 PM   #8
reyruiz191
reyruiz191's Avatar
Drives: 2013 FRS Vortech Supercharged
Exactly, I wouldn't even turn the key unless the proper tune was on the ecu. I had issues with uploading my tune not due to the vendor from who I got my tune, but through an unknown issue that caused the tune upload to fail so my car had to sit for two days while I got the issue resolved. This is why it's always good to plan for the unexpected. Hopefully you get your tune soon though so you aren't left without a car for long.
reyruiz191 is offline   Reply With Quote
The Following User Says Thank You to reyruiz191 For This Useful Post:
Old 06-01-2013, 04:44 PM   #9
ft_sjo
Drives: GT86
If it starts and runs on the n/a maps and accepts light throttle inputs without hesitating then chances are it'll be perfectly safe to drive around on part throttle up to about 2.5-3.0k rpm.
Old 06-01-2013, 04:57 PM   #10
charged86
charged86's Avatar
My car could barely idle with full exhaust. Vortech. Pump and crank pulley with or without larger map sensor. I would highly advise not driving the vehicle
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 06-01-2013, 05:04 PM   #11
Pete
Pete's Avatar
Drives: 22 BRZ
I laughed so hard I farted accidentally. "rip it up the road" lol
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
Old 06-01-2013, 05:20 PM   #12
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
The injector swap alone will more then likely keep it from even starting/idling at all. Same injector dwell time, but with much more volume = rich
Old 06-01-2013, 05:50 PM   #13
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yeah, the injectors and FP will not allow the car to idle/run. If you did add a new map sensor, well even worse. There is no point in driving it like that. Rich condition is not exactly "safe", you can foul up spark plugs and we all know that is a PITA and a bitch to replace. Yea, to get a hold of Visconti's map you need to go through the zendesk site.
Old 06-01-2013, 05:54 PM   #14
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Yeah it wont even fire up with new injectors and map.... You NEED that tune
Silverdub is offline   Reply With Quote
Vortech Supercharger with FA20Club.com Tune msile Forced Induction 30 05-01-2013 01:12 AM
Vortech supercharger skatery1989 Forced Induction 293 04-19-2013 04:58 PM
Does anybody know if the tune from the vortech is better than the ecutek? Frsexxxy Forced Induction 16 04-08-2013 11:53 AM
Vortech supercharger. skatery1989 Engine, Exhaust, Bolt-Ons 2 02-23-2013 07:19 AM
Vortech Supercharger FRS/BRZ vividracing Forced Induction 5 01-29-2013 07:03 PM
