Old 07-13-2015, 06:59 PM   #1
Icanfaptothis86
tickle fight referee
Icanfaptothis86's Avatar
Drives: 2015 Subaru BRZ
BRZ traction control won't stay off
Just bot a 2015 subaru brz with about 500miles on it now. Still doing engine break in.
I can turn off traction control (not the sport mode button the other button that says off) at low speeds or a dead stop only. Above 20mph it won't turn off. Sometimes it will only turn off for around 8-10seconds and then turn back on other times it will stay off much longer.
Anyone had this experience ?
Icanfaptothis86 is offline   Reply With Quote
Old 07-13-2015, 07:08 PM   #2
Icanfaptothis86
also might as well mention - have a slight idle issue - Idle seems like its searching sometimes. It holds at 600RPM the vast majority of the time with slight dips to 500RPM and occasional gains to 700 or even as high as 900. Its tough to tell if headlights or Air conditioning is to blame.
Old 07-13-2015, 07:14 PM   #3
Can't help with the trac control but the idle will jump around a fair bit with the air on. Every time the compressor starts or stops your idle will drop or jump. Not an issue and very common on small displacement engines.
Old 07-13-2015, 07:16 PM   #4
mightaswell
Drives: 2015 WRB BRZ Sport-Tech
That's by design. If you want to turn it off for speeds above 20, you need to hold it down for 3-4 seconds. Then both the 'TRAC OFF' and Swervy Car lights will come on.
mightaswell is offline   Reply With Quote
Old 07-13-2015, 07:16 PM   #5
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
1. Are you just pushing the TC or Are you holding both VSC & TC til Sports mode is off?
2. Idle issue happens when? When you start it in the morning or...? Cuz if car isn't fully warmed up, it can cause idle issue AC is blasting.
tyrantcf (07-13-2015)
Old 07-13-2015, 07:18 PM   #6
Icanfaptothis86
Yea I live down in Houston TX so its fawkn so hot all the time. Puts the AC thru its paces. I am just scared that I might have that stupid idle issue that plagued the first edition models.
Old 07-13-2015, 07:19 PM   #7
ichitaka05
Site Moderator
ichitaka05's Avatar
If there is idle issue, you can get it fixed/update the ECU at the dealership
Old 07-13-2015, 07:23 PM   #8
Icanfaptothis86
Do you know how long that fix takes to complete ?
Old 07-13-2015, 07:28 PM   #9
About 5 minutes but I doubt that is you problem with a 15.
Not impossible but really rare.
Old 07-13-2015, 07:29 PM   #10
Icanfaptothis86
ok cool ... at every stop light i find myself just starring at the idle. I am a nervous wreck ... i love my car
Old 07-13-2015, 07:33 PM   #11
Icanfaptothis86
Do you have to be at a full stop to do this?
Old 07-13-2015, 07:33 PM   #12
ichitaka05
Site Moderator
ichitaka05's Avatar
Any time car need to do extra work (fans, ac, headlight & so on) extra extra power, that causes idle to drop. When extra stuff is off and even with that idle is still dropping, get it checked... but I wouldn't worry too much.
Old 07-13-2015, 07:34 PM   #13
tyrantcf
Drives: '16 WRX, CBR1000RR
For TC, you need to hold the button down until vsc and traction is off.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 07-13-2015, 07:34 PM   #14
Icanfaptothis86
Yes I am aware. I am just being super cautious during my engine break in .... Any advice for engine break in period ? My car is on its period.
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 02:48 PM
Traction control PolishFrs13 Issues | Warranty | Recalls / TSB 14 12-30-2014 02:31 PM
Traction Control vs. Stabilization Control vs. Sport Question MurderRider Scion FR-S / Toyota 86 GT86 General Forum 26 08-07-2014 01:56 PM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 04:28 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 12:20 PM
