Old 07-10-2015, 08:48 AM   #589
celek
Resident Gear Head
celek's Avatar
Originally Posted by WHITE View Post
Gotcha, I was hoping for something still using a fa20. Fb25 Seems like a big trade off for just .2liters more then a bored and stroked fa20.
Greddy TODA and HKS crank are all at 90mm stroke
FB25 is 90mm stroke but the actual width of the rod bearing is around .500"
The above mentioned after market cranks are using a RB26 SR20 rod journal if I recall at .650 wide same 48mm journal. over 20% more oiling surface area
FB25 uses a 94mm piston to make up the difference to get the extra .2 ltr vs a sleeved 90mm FA20 block at 2.3ltrs
That is a lot more mass in an unsquared piston to stroke to try and rev. Additionally the rod to stroke ratio on the FB 25 is 1.41:1 vs 1.50:1 on the FA20
The infamous Honda B16 runs a 1.75:1 with that factory 8200 Redline just to put it in perspective.
Not to go way off subject but the reason the FA20 makes 200HP at 2.0ltrs is because how light the internals are. Start adding weight to components the outcome may not exponentially increase i.e adding 25% displacement may not equate to 25% more power.
celek is offline
The Following User Says Thank You to celek For This Useful Post:
BatStig (07-10-2015)
Old 07-10-2015, 09:50 AM   #590
burdickjp
Drives: 2013 ultramarine Scion FR-S
That's a rather severe oversimplification, and not at all true.
burdickjp is offline
The Following User Says Thank You to burdickjp For This Useful Post:
abraxis (07-15-2015)
Old 07-10-2015, 10:23 AM   #591
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
@celek im sure there is a way to bore a fa20 to 94mm. The current darton sleeves have a 4" O.D. So boring them to 94mm(3.7") leaves only a .150" cylinder wall. But if we were able to fit a 4.25" O.D. sleeve into an fa20 then a 94mm bore would have a .275" cylinder wall wich would be more then thick enough for even boosted applications.
For comparison a current darton sleeve bored to 90mm has a wall thickness of .2285" and is said to handle 50+psi.
I'm probly going to look into this more once I start building my engine, if anything though ill be same as you with a 90mm squared stroker, just boosted instead.
WHITE is offline
Old 07-10-2015, 10:41 AM   #592
celek
Resident Gear Head
celek's Avatar
Problems with 94mm bore is we are dealing with DI larger the bore higher the CR at the same dome Easily fixable with custom pistons.
Additionally DI is very picky on the quench minor changes can hinder power production. I would also be concerned with losing cooling efficiency shrinking the jackets volume. Lots to consider.
I wanted to keep the thread on its original subject and drop the highjack, without going into mathematical calculations of proportional displacement to component weight ratio's
Now back to the INTAKE MANIFOLD!
celek is offline
Old 07-10-2015, 08:30 PM   #593
burdickjp
Originally Posted by Tim Radley View Post
I wouldn't worry about the cutout in the piston top, its not critical. I've removed them on Audi builds and made over 700bhp.
One example does not make a generalization.
Old 07-10-2015, 09:04 PM   #594
celek
Resident Gear Head
celek's Avatar
Can't compare turbo to NA though
celek is offline
Old 07-11-2015, 09:57 AM   #595
wootwoot
Drives: FRS
Stay focused people.
wootwoot is offline
Old 07-11-2015, 07:15 PM   #596
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
But but but... the anticipation!
Captain Snooze is offline
Old 07-11-2015, 08:33 PM   #597
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
I'm confused why this topic is keep being bumped. Didn't they already state the manifold isn't great for NA applications and are going towards FI applications? Should this thread to be moved to Forced Induction?
dem00n is offline
Old 07-11-2015, 08:35 PM   #598
Calum
That Guy
Drives: 2013 asphalt FRS MT
Hope is a powerful foe. Desperation an even worse enemy.
Calum is offline
Old 07-11-2015, 08:39 PM   #599
plucas
plucas's Avatar
Drives: Subaru
I think the thread is in the correct location
plucas is offline
Old 07-11-2015, 09:03 PM   #600
dem00n
dem00n's Avatar
Drives: Scion FRS
Trust me, I'd like to believe this will work, but he did say this.
Without giving 2much (haha) away, like we suspected it does not work well with an NA application. It loses some power mid-range but actually picked up power downlow, didn't see that coming.
We're moving onto FI testing which is what this manifold was designed for.
We have another idea for NA application we want to test once funds become available .
http://www.ft86club.com/forums/showt...=60125&page=10
dem00n is offline
Old 07-11-2015, 09:21 PM   #601
Captain Snooze
Drives: Red Herring
Head (and heart) is sad, wallet breathes a sigh of relief.
Arrrrggghhhh!!
raven1231 (07-12-2015)
Old 07-11-2015, 10:59 PM   #602
Calum
That Guy
Calum is offline
The Following User Says Thank You to Calum For This Useful Post:
fika84 (07-13-2015)
FT-86 SpeedFactory LCA by Verus - Lightest LCA for the Twins - Development Thread FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 236 06-20-2019 01:42 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Intake manifold viking Engine, Exhaust, Transmission 6 09-23-2014 11:08 PM
Oil on/around Intake Manifold Wepeel Issues | Warranty | Recalls / TSB 2 05-12-2014 11:40 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 02:24 PM
