Old 07-09-2015, 03:45 PM   #15
timmydatooth
Drives: Scion Frs
I was looking at more exhausts with the burnt tips. Does anyone have the agency power catback on there car? Aound isnt bad on it either.
timmydatooth is offline   Reply With Quote
Old 07-09-2015, 03:55 PM   #16
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
Originally Posted by timmydatooth View Post
Not really sure what the difference is between cat and catless or res or non res. I know the catted front pipe costs more tho. Sorry im a noob to this
Its okay, catted front pipes have a catalytic converter, these are somewhat quieter than catless front pipes, the resonated pipe has a resonator which should reduce rasp and make it a bit quieter too.
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
The Following User Says Thank You to yelsew For This Useful Post:
timmydatooth (07-09-2015)
Old 07-09-2015, 04:24 PM   #17
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
if you're not planning to get header then N1 should be fine. otherwise Q300 or Perrin or other quieter exhaust set up.
Old 07-09-2015, 05:43 PM   #18
timmydatooth
Drives: Scion Frs
So the N1 on a stock frs (besides a CAI) wont be too loud for daily driving/cruising? And im not trying to leave the silencers on all the time. Lol a lot of people say its good for the track but the drone can get annoying for DD
Old 07-09-2015, 06:22 PM   #19
timmydatooth
Drives: Scion Frs
Ok so i think im gonna go ahead and pull the trigger on the q300! Im also going to get the invidia front pipe but whats better? Catted or non? Resonated or non? Whatever adds more sound and power is what im looking for.
Old 07-09-2015, 06:41 PM   #20
kch
Senior Misanthrope
kch's Avatar
Resonators reduce the high-frequency "raspy" sound a lot of people don't like. If you keep the stock header, rasp won't be a huge issue, but a resonator wouldn't be a bad thing. Resonators have 0% impact on performance, so it's a question of personal preference.
I'm not sure what the law is in Florida re emissions inspections. Technically, removing a functional, factory catalytic converter is against federal law, but many people do it anyways (myself included). By default, these cars have two cats: one in the header, one in the front pipe. Cats are purely there to reduce emission of NOx and CO. Cats have a mild effect on performance because, by their very nature, they cause an exhaust restriction. Similarly, they reduce the volume (and maybe raspiness?) of your exhaust as well.
If you're staying naturally aspirated, getting a catless front pipe won't give you much of a performance gain (but it'll be something, maybe). Catless front pipes are less expensive, though. It's ultimately your choice. The popular route is to get a catless header with a catted front pipe. That way you have lower emissions, less restriction, and will probably pass a sniffer test.
Note that if you decide to go completely catless, you will most certainly fail an emissions sniffer test. Your exhaust will also smell like gas fumes.
The Following User Says Thank You to kch For This Useful Post:
Old 07-09-2015, 06:55 PM   #21
timmydatooth
Drives: Scion Frs
So would it be better for me to just skip on the front pipe and just get the q300 catback by itself? Does the stock pipe have a cat or a resonator?
Old 07-09-2015, 07:37 PM   #22
kch
Senior Misanthrope
kch's Avatar
Stock has a cat and a small (helmholtz?) resonator. In my opinion, swapping out the front pipe isn't particularly cost effective unless you're doing full exhaust, including header. But that's just me.
Edit: install the Q300 and see how you like it. If you decide you want a little more volume, I think a FP with a high-flow cat would make it a bit louder. But that's just speculation on my part.
timmydatooth (07-10-2015)
Old 07-09-2015, 08:50 PM   #23
ramiram1984
Drives: 2016 STi DGM
Resonators add more weight. More weight to or already slow cars.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 07-10-2015, 12:18 AM   #24
timmydatooth
Drives: Scion Frs
Yeah im gonna go the catless front pipe since florida doesn't have emission laws anymore. Last thing i need is more weight.
The Following User Says Thank You to timmydatooth For This Useful Post:
JoeBoxer (07-10-2015)
Old 07-10-2015, 12:28 AM   #25
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Does anybody have a pair of the N1 silencers they aren't using? My exhaust didn't come with them and would like to try and see how it sounds.
Old 07-10-2015, 02:11 AM   #26
kch
Senior Misanthrope
kch's Avatar
Originally Posted by ramiram1984 View Post
Resonators add more weight. More weight to our already slow cars.
I seriously doubt OP is building a racecar where a 5lb(?) resonator would matter.
The Following 3 Users Say Thank You to kch For This Useful Post:
EastBayCanuck (07-10-2015), JoeBoxer (07-10-2015), timmydatooth (07-10-2015)
Old 07-10-2015, 10:35 AM   #27
timmydatooth
Drives: Scion Frs
Have you guys every had any problems or fitment issues using a different brand front pipe with an invidia cat back? I was thinking of going a cheaper route on the front pipe like tanabe or jl2. Also doesnt the q300 catback come woth with the midpipe already that has a resonator on it?
Old 07-10-2015, 02:43 PM   #28
JG
JG's Avatar
Drives: Whiteout FRS
I still have my N1's on. Also with Invidia straight pipe, front pipe, overpipe, and openflash UEL header. It's loud when I want to be loud but when i drive casually it's not bad at all. Before i installed my header it wasn't bad at all, drone's a little on the hwy but you wont notice it after a week or two.
JG is offline   Reply With Quote
exhaust, invidia, q300
WTT: Borla Catback for Invidia Q300 androopoo Engine, Exhaust, Bolt-Ons 1 04-27-2015 12:42 PM
Invidia N1 Catback or Invidia Q300 Catback?? Jolaessss Northern California 43 04-28-2014 04:23 AM
FS: Invidia Q300 catback exhaust $450 N_A Engine, Exhaust, Bolt-Ons 19 03-26-2014 02:08 PM
FS: Invidia Q300 catback exhaust N_A Southwest 17 03-18-2014 11:02 PM
Invidia q300 catback titanium Howardwei Engine, Exhaust, Transmission 0 07-25-2013 08:30 PM
