Old 07-07-2015, 09:49 AM   #15
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by wbradley View Post
Two reasons:
No experience with oil coolers. Didn't even consider the possibility the sandwich plate could be so lame. Now I have experience with it, unfortunately. LOL.
I really like your explanation, and thanks for posting it because it brings perspective and a different point of view.
On another note, my advice would be, if you can't afford buying quality parts for critical components (be it for whatever reason including currency exchange rate), then you are mostly better off not getting a lower quality product for less money.
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
ATL BRZ (07-09-2015), CSG David (07-07-2015), Lonewolf (07-07-2015)
Old 07-07-2015, 12:41 PM   #16
wbradley
Sarcastic SOB
wbradley's Avatar
Edit: can't accept, not cant afford. Having the funds and having other plans for the funds are two different things. Depending on your definition of affordable, either I can't afford the car or I can afford a new Porsche.
However I'm a big boy and will chalk this up to a lesson learned the hard way. Still I wonder how in the age of PayPal this kind of stuff can go unresolved. Incidentally CX finally emailed me back asking where the leak was occuring. I can see it leaking betewwn the spacer and sandwich, but can't be sure if not also between spacer and base.
Old 07-07-2015, 12:55 PM   #17
celek
Resident Gear Head
celek's Avatar
Probably tore the Oring but glad you got it worked out. I agree with the CX statements
celek is offline   Reply With Quote
Old 07-07-2015, 03:47 PM   #18
wbradley
Sarcastic SOB
wbradley's Avatar
The O ring looks perfect. Probably improperly sized or just insufficient ability to withstand pressure.
Old 07-07-2015, 04:48 PM   #19
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
Friend has a full CX Racing turbo kit for his KA engine and its fantastic.
Canehda is offline   Reply With Quote
The Following User Says Thank You to Canehda For This Useful Post:
Yoda (07-08-2015)
Old 07-09-2015, 03:09 PM   #20
empower-auto
Kouki-Monster
empower-auto's Avatar
if you torqued a sandwich plate to hell -- it's not a shock to me that you now have a mess.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
The Following User Says Thank You to empower-auto For This Useful Post:
wparsons (07-09-2015)
Old 07-09-2015, 03:56 PM   #21
wbradley
Sarcastic SOB
wbradley's Avatar
I didnt torque it to hell. First I tried 28 ft/lbs, what other companies recommend. Then, after it leaked like crazy I re-installed, probably 60 lbs with the same result.
Old 07-10-2015, 08:22 PM   #22
empower-auto
Kouki-Monster
I'll take your word for it.
CX Racing is a low quality company and their products are super questionable. They work for some people and they brag about it all day because they made something work for cheap -- and for others they don't work.
The rest of us just avoid brands like that and call it a day.
I don't know what Mishimoto is like but their plates look nice and they call for 35 for torque. Any legit Japanese brands or even quality legit Made in USA will have better machining and O-ring fit etc.
Rich Anderson
EMPOWER AUTO
The Following 2 Users Say Thank You to empower-auto For This Useful Post:
JoeBoxer (07-10-2015), Sportsguy83 (07-14-2015)
Old 07-12-2015, 10:13 PM   #23
wbradley
Sarcastic SOB
wbradley's Avatar
Since the only reply I got from CX was asking if the leak was from the sandwich or spacer (looks like both), and its messy and time consuming to remove and return the entire unit, I emailed asking if they'dtake back the sandwich and spacer and issue me a partial credit. I can then just put that toward the Mocal unit which AFAIK is proven reliable.We'll see what they want to do.
Old 07-12-2015, 10:37 PM   #24
JEDI
JEDI's Avatar
Drives: 2015 FR-S RS 1.0 #0993
Look at the plate. Since you were talking that the O-rings are what seals it, I'll say it again look at the o-ring journal the o-ring sits in? Is there any chips, gashes, irregular sizes? 0-rings are made of many materials so they can fluctuate in size due temps, what materials they are exposed to and so on. Do you have a micrometer, or a nice steel flat edge ruler or plained piece of steal etc, you can set the sandwich plate on and LOOK for warps, bends, gaps, light, etc..there should be little to none. The same mentality should be put towards what is mating up to the sandwich plate as well. A set calipers would come in handy right now as well. If and when you figure out the sandwich plate is not the issue and you may have moved on from there measure the O-rings with the calipers and also measure the journal the o-ring sits in as well. I think you get where I'm going. Most things mechanical have an order of operation and then by deduction and a couple minutes with some tools, a little patience and you could of easily fixed this in house so to speak if the part didn't get to you defective already. O-rings can be defective as with anything. That's is far as an uneducated wannabe backyard mechanic is going to bore you guys with. blah blah blah
2015 Subaru WRX - SOLD!
2013 Scion FR-S - Traded In!
2015 Scion FR-S RS 1.0 - My DD , GF, and BFF!
JEDI is offline   Reply With Quote
Old 07-12-2015, 10:45 PM   #25
wbradley
Sarcastic SOB
wbradley's Avatar
I'm thinking the O rings, although well seated in the groove might just be too thin and don't compress uniformly when the unit was tightened down. Maybe they aren't the ideal diameter/width/thickness. I oiled the rings before tightening down as I do an oil filter if that matters. The rate of leak was pretty rapid, only ran the car at idle and that was enough for me.
Old 07-14-2015, 09:38 AM   #26
wbradley
Sarcastic SOB
wbradley's Avatar
Update: they replied yesterday they will be sending me new parts and they are going to make sure the gaskets are properly seated and test before shipping.
The Following User Says Thank You to wbradley For This Useful Post:
D_Thissen (07-14-2015)
Old 07-19-2015, 03:20 PM   #27
wbradley
Sarcastic SOB
wbradley's Avatar
Did a bit of diagnosis last night. Seems the oil was leaking from the 2 side plugs for oil temp and oil press sensors. Also around the fittings for the outlet pipes. Missing one gasket and the others were not so great. Went crazy with Permatex Red and there are no leaks now, but it looks awful. I am expecting parts in the mail from CX next week and I will get it all fixed up, or maybe just leave the Permatex on and keep the parts to install later if the Permatex fails. Overall the CX product seems good for the money but the fact they shipped the incorrect sandwich first time and an incomplete one second time suggests, buy from them, but make sure THEY make sure to ship the right parts first time around.
PS- the quality of the parts is very good for a much lower price than the A list vendors.
Old 07-19-2015, 04:22 PM   #28
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
I'm glad you got it figured out, but it's always wise to consider the failure mode of the parts you're putting on the car. If a spoiler or something cosmetic fails, it's not a big deal. If your oil cooler fails and vomits all your oil out over the road, the first indication something has gone wrong might be a rod exiting the block if you don't catch it in time.
Things like an oil cooler aren't "go-fast" parts, they're insurance. They're there to keep the engine oil cool, so it makes sense to spend a little more money on keeping your engine intact and protecting your investment.
GSpeed is offline   Reply With Quote
Heads up - Oil sandwich plate protpibe Engine, Exhaust, Transmission 37 04-28-2017 04:15 PM
WTB: Quality Oil Cooler w/ thermo sandwich plate for NA application AyJay Want-To-Buy Requests 11 02-20-2015 10:16 AM
Oil sandwich plate with TRD intake? wootwoot Engine, Exhaust, Transmission 18 06-18-2014 10:17 PM
Greddy Sandwich Plate 12002802 Captain Snooze Australia Classifieds 2 07-09-2013 07:41 AM
Casting Defect Sandwich Plate Dezoris Issues | Warranty | Recalls / TSB 1 01-22-2013 03:04 PM
