Old 07-09-2015, 01:51 PM   #15
KevinK121
Miata traitor
KevinK121's Avatar
Drives: 2002 Miata SE
Originally Posted by 8R6 View Post
those look good, but how are these wheels a middle ground between form AND function? these are show wheels...
Theyre not terribly heavy and theyre only one piece. And also fairly cheap/easy to fix.
Idk made sense in my head lol
Soooo they look good but theyre not really 3 piece and theyre cheap enough to not worry about them a whole terrible bunch and they're not godforsaken heavy either. I'd call that some form of middle ground.
KevinK121 is offline   Reply With Quote
Old 07-09-2015, 02:15 PM   #16
8R6
8R6's Avatar
Drives: FRS
i guess...
not knockin on your wheel choice. like i said, i think those are good looking wheels... but being that they're cast, straight replica of OZ's, those specs, and even the bolts are just for show, i just consider them "show wheels" thats all. regardless, post some pics once theyre on the car!
8R6 is offline   Reply With Quote
Old 07-09-2015, 02:18 PM   #17
KevinK121
Miata traitor
KevinK121's Avatar
i guess...
I hear ya and can easily see where you're coming from. No offense taken
Still not 100% on these but everything considered, it seems I could do worse for something to satisfy both goals in one set of wheels.
The Following User Says Thank You to KevinK121 For This Useful Post:
8R6 (07-09-2015)
Old 07-09-2015, 02:27 PM   #18
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Originally Posted by KevinK121 View Post
Oh god so if I order now I might get them by this winter?
I ordered with FM Wheels and they are in constant contact with AG Wheels. I would call them and see when the next sets are coming in through AG. These weigh 23lbs per wheel for both offsets.
The Following User Says Thank You to NyC Zn6 For This Useful Post:
FM Wheels (07-09-2015)
Old 07-09-2015, 02:39 PM   #19
NyC Zn6
NyC Zn6's Avatar
Originally Posted by swarb View Post
Whoever mounts them first! LOL
Can you take a pic without the center cover? and maybe the backside? You should weight it too!
Here you go
The Following 2 Users Say Thank You to NyC Zn6 For This Useful Post:
FM Wheels (07-09-2015), swarb (07-09-2015)
Old 07-09-2015, 02:49 PM   #20
KevinK121
Miata traitor
KevinK121's Avatar
Nice! thats even lighter than I had hoped. Thanks again man. Maybe I can find a set already made in.
Old 07-09-2015, 02:55 PM   #21
FM Wheels
FM Wheels's Avatar
Drives: a car with nice wheels.
Avant Garde got a shipment in this week and are good in stock. All orders are made to fit and are drilled by Avant Garde.
FM Wheels is offline   Reply With Quote
The Following User Says Thank You to FM Wheels For This Useful Post:
KevinK121 (07-09-2015)
Old 07-09-2015, 03:00 PM   #22
KevinK121
Miata traitor
KevinK121's Avatar
What do you think the turn around would be at this point? Will you pm me what you're offering a staggered 18in set for? Shipped to Minneapolis.
Old 07-09-2015, 03:03 PM   #23
NyC Zn6
NyC Zn6's Avatar
Yes now that they are in stock place that order with FM wheels . they took care of me and they have great customer service
Old 07-09-2015, 03:18 PM   #24
KevinK121
Miata traitor
KevinK121's Avatar
Heavily considering it at the moment
What made your decision of not wanting to go staggered? And if you dont mind, what was your logic on the offsets? Im not doubting or criticising, Im just new to the art of sizing wheels heh
Old 07-09-2015, 03:29 PM   #25
NyC Zn6
NyC Zn6's Avatar
I wanted a slightly aggressive setup (little poke) which is why I went 18x9 +30 and 18x9+20. The lower the offset the more it will poke out from the hub(away from the car). I wanted more lip in the front because the 18x8.5 has a smaller lip than the 18x9. I also wanted a close to square setup with 225/40/18 all around. Not saying you can't do that with staggered wheels but if I was going staggered I would definitely go with a wider tire in the rear.
Old 07-09-2015, 09:00 PM   #26
KevinK121
Miata traitor
KevinK121's Avatar
Good food for thought. I know how offset works but I don't fully understand what spec equals desirable fitment. I tried poking around on the fitment calculator but it seemed flawed. I've looked through countless pics in the directory and it's often hard to tell the difference in set ups with up to 10mm of difference.
I think I'm going to play it on the more conservative side with the offset so I can space it if I want/ need to.
Thanks again for all the feedback and I look forward to seeing them mounted
Old 07-09-2015, 09:56 PM   #27
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Careful with your Avant Gardes, if you damage the paint they won't send out paint codes for you to get it repaired at a wheel facility, you have to ship them back or buy a new wheel. Learned that the hard way about Avant Garde wheels...
The Following User Says Thank You to dem00n For This Useful Post:
Old 07-09-2015, 10:54 PM   #28
KevinK121
Miata traitor
KevinK121's Avatar
If I got these I'd powder coat them but that is good info regardless.
FS: Avant Garde 3-Piece Forged norsamerican Wheels and Tires 22 06-28-2014 07:49 PM
F/S Socal Avant Garde M220 ChrisNcoronel Wheels and Tires 6 06-28-2014 05:19 AM
***** AVANT GARDE***** ExtremeAutowerks Wheels and Tires 13 12-23-2013 02:35 PM
Avant Garde m310 18x9 +30 $500 evoforstevo Wheels and Tires 4 03-11-2013 05:33 PM
