Old 06-04-2015, 02:02 PM   #701
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Originally Posted by bear89103 View Post
i have version 1.8.52
uninstall & reinstall... it should work out of the box. no need for the PID
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
bear89103 (06-04-2015)
Old 06-05-2015, 12:31 AM   #702
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by Astroboy View Post
Did you ever figure it out?
Your factory MAP sensor can read 20 psi absolute.
Boost is going to be what your MAP sensor is reading minus ambient. Sea level is about 14.7 psi, or 1 bar.
20 - 14.7 ~~ 5.5 psi.
You'll notice your 5.5 psi occurs quite a bit before redline, and as you know, your boost continues to climb as you rev higher. The boost is there; you just don't have the equipment to read it.
If you go somewhere where ambient pressure is lower, you will see a higher boost reading.
*dont* change your MAP sensor; you'll need a custom tune if you do so.
Old 06-28-2015, 01:46 PM   #703
Vizabledreamz
Drives: Man
Send a message via ICQ to Vizabledreamz Send a message via AIM to Vizabledreamz Send a message via Yahoo to Vizabledreamz
can someone tell me how to get oil psi at all? and is there a plugin simply made for the frs/brz like nissan and fiat have on the play store?
Vizabledreamz is offline   Reply With Quote
Old 06-30-2015, 03:16 PM   #704
fika84
fika84's Avatar
Search. There is no stock oil pressure sensor. And if you haven't found a plugin on the play store, then there isn't one... at least not yet.
fika84 is offline   Reply With Quote
Old 07-03-2015, 06:56 PM   #705
Skurj
Drives: SOLD...
I've got Torque pro 1.8.54 there is no Oil Temp by default, and when I add the 2101 pid it reports no data..
Wondering if its the el cheapo BT OBD2 adapter...
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 07-03-2015, 07:53 PM   #706
Andrew025
Andrew025's Avatar
I got a new phone, the default oil temp didn't work for me either and after putting in the custom PID it didn't work.
I uninstalled/installed it and put in the custom PID first thing and it worked.
Not sure what's up with that.
The Following User Says Thank You to Andrew025 For This Useful Post:
Bonburner (01-08-2021)
Old 07-03-2015, 07:57 PM   #707
Astroboy
Astroboy's Avatar
Drives: None
OFFICIAL Torque Android app PID/Misc Thread
Where is your engine load at idle? Is 23% in the safe zone? It easily climbs to 80 percent on first gear while revving up slowly. Could this be the cause of my turbo, or a poor actuator spring?
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 07-04-2015, 06:24 PM   #708
Calum
That Guy
Drives: 2013 asphalt FRS MT
Has anyone measured the stick oil sensor to see if it really is only a switch or if it could give a viable reading?
Old 07-05-2015, 02:04 PM   #709
fika84
fika84's Avatar
Not that I know of. But many people have said that it is just a switch for the low oil light.
The Following User Says Thank You to fika84 For This Useful Post:
Calum (07-05-2015)
Old 07-05-2015, 05:17 PM   #710
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Took a quick look at my logs, not quite sure what the units are, but I'm reading about 1.7 to 14.2 (psi?) range (up to 6k rpm). Hope that helps.
I think that kind of makes sense. The stock NA engine sucks ~12 PSI of vacuum at idle, and my Rotrex supercharger offsets that by +~3 PSI at idle. My peak reading at around 25 PSI is when the engine no longer has a vacuum and the blower (without the smaller pulley) is pushing about 9 PSI. Someone else can call BS on me but I think that is what's happening. Thanks!
mit_peid is offline   Reply With Quote
The Following User Says Thank You to mit_peid For This Useful Post:
Astroboy (08-10-2015)
Old 07-09-2015, 11:05 AM   #711
lugao
Drives: 2015 Subaru BRZ Series.Blue
Hi guys, what kind of bluetooth adapter would you guys suggest that has a good quality and pretty small? Thanks in advance!
lugao is offline   Reply With Quote
Old 07-10-2015, 01:36 PM   #712
Skurj
Drives: SOLD...
Further to my issue with no oil temp..
The day after my previous post.. The next day on my way to a track day at the Mosport GP track, 1st time for me.. Well I pull out of Tim Horton's and all of sudden CEL, ABS, and one other light on the dash comes on...
WTF... Pulled off onto a side street, turned it off.. back on and CEL is still there the other lights were gone.. I realized I had left the OBD2 thingy hooked up since the night before so I immediately removed it. Went to get gas.. Next restart CEL is still there.. so now I am worried. Decide to take it to the track (I am only 15 mins away) expecting at least someone there will have a reader or something, I wasn't going to trust the one I had. I get to Taunton & 57 and turn the car off and back on.. and CEL is gone!!
wparsons of this board was at the track with an OFT, we checked the car.. no codes..
So.. I am pointing a finger at the elcheapo OBD2 ELM thingy for my issues. I spent 2 days on the GP track, that was a week ago, and the CEL hasn't come on since.
Paid for Mar 2018
Old 07-21-2015, 06:51 PM   #713
TCR
Drives: 2013 Toyota 86 GT
I would suggest the OBDLink LX one for a couple of reasons. Better quality, faster refresh rates and you can leave it plugged in without draining your battery.
http://www.obdlink.com/lxbt/
TCR is offline   Reply With Quote
The Following User Says Thank You to TCR For This Useful Post:
6pack (07-22-2015)
Old 07-22-2015, 12:07 PM   #714
lugao
Thank you!
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
