Old 07-01-2015, 10:02 PM   #6427
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
Originally Posted by xjohnx View Post
do you guys offer a rebuild or refresh service?
Just sent mine off to Jon bond
ybotspawn is offline   Reply With Quote
Old 07-01-2015, 10:07 PM   #6428
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Why did you send yours off?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 07-01-2015, 10:23 PM   #6429
ybotspawn
ybotspawn's Avatar
Number of reasons, a couple of which are my fault. Completely let the oil level run low, pretty sure I torched some of the seals, so I'm burning more oil than I should. But outside of that the fluid and stuff that Gary (from Sprintex) has recommended from Jon Bond, I've talked to him a number of times and alot of upgrades he throws in with the rebuild reduce or even eliminate oil consumption. Thats been my one complaint with this kit all along. Otherwise I've been completely satisfied with it.
If everyone waits until I get mine back and installed (by @ptuning) I can post a review on performance (including dyno) and oil consumption
The Following 2 Users Say Thank You to ybotspawn For This Useful Post:
CK_Bladesmith (07-01-2015), whataboutbob (07-08-2015)
Old 07-01-2015, 10:52 PM   #6430
xjohnx
Grip>Slip
xjohnx's Avatar
Mind if i ask how much that runs? How long does it take?
Old 07-01-2015, 11:01 PM   #6431
ybotspawn
ybotspawn's Avatar
So Jon Bond says 750-850. Supposed to be less than two weeks. I'll post back here with details when I know more. I'm also having a dyno done immediately after. I kept the original dynos so I'll have a good baseline, in the event there are any performance differences before/after. Outside of seals being replaced with high temp seals, I'm doing ceramic coated rotors as well as a pressure relief.
I'll keep everyone posted.
whataboutbob (07-08-2015), xjohnx (07-04-2015)
Old 07-02-2015, 07:57 AM   #6432
xjohnx
Grip>Slip
xjohnx's Avatar
Definitely interested in hearing your results. Was that 750-850 including the ceramic coating?
Old 07-02-2015, 08:00 AM   #6433
ybotspawn
ybotspawn's Avatar
Yes it was including ceramic coating. I'll probably do a vendor review of Jon Bond when I get it back and put the entire story in there.
Old 07-02-2015, 11:35 AM   #6434
SprintexUSA
SprintexUSA's Avatar
Drives: 2014 FT86
We do that on pretty limited terms. We've made a whole lot of these units, so it's cheaper to replace them than rebuild them. Like any compressor, if you spin it within an inch of its life, it won't last as long as lower RPM usage. The same goes for turbos, roots, centry's and twinscrews---RPM and heat are your two main enemies.
We can refurbish a kit with sonic cleaning the castings and using new bearings and such. Anything behind the gears and in the rotor pack is a very meticulous affair. Forward of the rotor pack is what we handle here in the US because of speed of the work. Jon Bond is qualified to do that kind of work behind the gears and I highly recommend him. He's easier to access in the US and has quicker turnaround being on the same continent. He rebuilds thousands of superchargers a year.
Our USA branch is a warehouse, not a machine shop or speed shop.
SprintexUSA is offline   Reply With Quote
The Following 3 Users Say Thank You to SprintexUSA For This Useful Post:
sroby (11-26-2018), Ultramaroon (07-02-2015), ybotspawn (07-02-2015)
Old 07-02-2015, 11:48 AM   #6435
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
@SprintexUSA I dont know if its been asked already, or if you's supplied this info but I'm having trouble finding it on my own so...could you tell me what the max lb/min the 335 is capable of flowing? Thanks.
WHITE is offline   Reply With Quote
Old 07-07-2015, 07:53 PM   #6436
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
PSA: check your idler pulley!
In the last week or so my car developed a squeak on start-up, so I picked up a new idler and belt just in case. I pulled the belt and spun all the pulleys and they all felt smooth and made no noise. But when I pulled the plastic idler, I found this:
Now, the car is in the midst of some work, so I wasn't able to verify that the squeak is gone. But regardless if it is, this pulley needed to be replaced. So I figured I should show the other owners of this kit that may have the same pulley, in case there was a bad batch of bearings.
FYI, I replaced it with a Gates 38018 pulley.
The Following 5 Users Say Thank You to Draco-REX For This Useful Post:
CarzCarzCarz (07-08-2015), Chrisbrz14 (07-07-2015), LOJOKO (01-11-2020), stockysnail (07-08-2015), vaderbloke (07-18-2015)
Old 07-08-2015, 08:28 AM   #6437
CarzCarzCarz
CarzCarzCarz's Avatar
Drives: 2014 WRB BRZ
Where'd you get the pulley, and how much was it?
CarzCarzCarz is offline   Reply With Quote
Old 07-08-2015, 11:00 AM   #6438
smudge
Drives: Supercharged GT86
About to order my 335 kit to the UK on Friday! So excited
smudge is offline   Reply With Quote
Old 07-08-2015, 09:11 PM   #6439
Draco-REX
Corner Junkie
Draco-REX's Avatar
I picked it up at O'Reilly's since they carry Gates products and had it in stock. I'm more of an Advance Auto guy, but Gates has a better reputation than Dayco. It retails for $15.99.
Got the car mobile today, and no squeak. So the pulley does appear to have been the culprit.
The Following User Says Thank You to Draco-REX For This Useful Post:
CarzCarzCarz (07-09-2015)
Old 07-08-2015, 10:03 PM   #6440
whataboutbob
AutoX-10/10ths every run
I was only getting about 7K miles out of the gates pulleys. I upgraded to one of these and I've got 35K out of it and it is still going strong: http://www.onlineautomotive.com.au/N...e-Pulley-EP075
Build thread:Here
The Following 3 Users Say Thank You to whataboutbob For This Useful Post:
CarzCarzCarz (07-09-2015), Draco-REX (07-09-2015), SpeedWi (07-08-2015)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
