Old 07-04-2015, 01:40 PM   #29
donoman
donoman's Avatar
Drives: '13 FR-S
Any rubbing on a 245/45-17 R-Comp like the R888, etc with the 17x9 ET35 RPF1? I'm about the pull the trigger.
donoman is offline   Reply With Quote
Old 07-04-2015, 02:38 PM   #30
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Originally Posted by rx3 View Post
I tried the Michelin Slick mentioned above on a very tight course. (1 min 30 seconds long; 30% was in 1st gear)
There's a substantial difference compared to the Toyo R888. The rear wouldn't break out at all as it usually does (for instance, accelerating out of a tight u-turn). This was the first time that I had to say that differential does not suffice, as it would let the inside wheel spin on a regular basis.
Even shifting from 1st to 2nd at full throttle in a turn barely got the rear to move.
The grip is very impressive it feels almost as cheating.
Because of it it's also less fun to drive because it's easier to control the car.
In short, it was a very easy win in the class I ran (sort of like STX on slicks with the difference that my car is mostly stock).
Also, since the diameter of the tires is relatively small (only 605 mm), all 4 wheels can easily be placed onto the rear seat area (so the trunk can be used for other things.)
Attached is a picture of the tire on a RPF1 17x9 rim (offset is 45mm in the rear and 35 mm in front):
How long was the race? What were your temperatures? I'm curious how the S5B compound held up.
Jake
GSpeed is offline   Reply With Quote
Old 07-04-2015, 11:59 PM   #31
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Originally Posted by Toyota GT 86 View Post
Thanks, I finally got 17x9+35 with Hoosier A7 245/40 all around
What organization/class are you running in?
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 07-07-2015, 04:58 PM   #32
rx3
Sorry for the late response.
I've meanwhile run them at 3 events. (I only run on slicks when my roadtire-field has not enough participants, such that I need to run in the slick-field in order to collect more points).
The first event was 1:30 minutes per run (asphalt, 4 runs). Temperature was around 20 C. They were sticky from the get-go (no warm-up time). Even in first gear sweeper turns the rear wouldn't break out (differential struggled to lock up).
Second event was about 1 minutes per run (asphalt, 4 runs). Temperature was also around 20 C. Track was a little dusty and the rear would occasionally break out.
The third event was 3 minutes per run (asphalt, 4 runs). Temperature was over 30 C in the afternoon. It appeared as the tires may have lost some of the grip at the end of the runs, but they didn't get any greasy. I was just faster in the morning, when it was cooler.
At this event the rear occasionally broke out even though the track was clean (so maybe the slicks do heat cycle out early. They also wear out quickly. Other people on Honda Integra DC2 have to get new tires every 4 events (16 runs), but they also run on 15" tires).
rx3 is offline   Reply With Quote
Old 07-07-2015, 05:27 PM   #33
rx3
Here's a video of one run of that last event:
[ame="https://www.youtube.com/watch?v=ebo6jNbQ_II"]Slalom/Autocross on Michelin S5B - YouTube[/ame]
The Following 5 Users Say Thank You to rx3 For This Useful Post:
DarkSunrise (07-09-2015), GSpeed (07-08-2015), hpde_addict (07-26-2015), Hyper4mance2k (07-08-2015), MaximeT (07-08-2015)
Old 07-08-2015, 02:48 AM   #34
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Nice video. I like the 48p.
I dunno much about auto X, but that's faster and with more obstacles than I thought. Looks like a flat hill climb at some point.
I'm looking at using the harder Michelin myself (s8 I think) on the track. As soon as I get a car
My reason to switch to this car is to use this tire (cargo space)
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 07-08-2015, 12:43 PM   #35
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Very cool event, thanks for the video. Looks like a ton of fun. What camera are you using? (Sorry for all the questions.)
Old 07-09-2015, 12:15 AM   #36
rx3
What's nice is that these tires are available with a 605 mm diameter, which is just small enough to fit all 4 wheels in the back seat area. Btw, the Avon slicks are also available with that same diameter (and width). (Hankook slicks would be cheaper but they are not available in that dimension, but I might try them anyway because we need to use first gear quite often and I'd prefer if the first gear was longer. In that case one wheel will have to go in the trunk.)
(The S5B would definitely be way too soft for track purposes.)
Thanks, btw this year was the 50iest anniversary of that event. It's a GoPro Hero 3.
Old 07-09-2015, 02:18 AM   #37
MaximeT
MaximeT's Avatar
Yes 605mm is great. Unfortunately in Europe there's not a big price difference between Michelin/Yokohama/Avon/Hankook.
Enkei RPF1 Wheels; Gunmetal/Bronze/Black/Silver/Gold, 17x8, 17x9, 18x8, 18x9.5 OAKOS Automotive Wheels and Tires 176 05-28-2015 11:09 AM
PA:WTB/FT black enkei raijin 18x8.5 18x9.5 for enkei rpf1 17x9 SterlingBrz Wheels and Tires 1 05-28-2014 11:36 PM
WTT: 17x8 RPF1 for 17x9 wheels TemeCal Brakes, Suspension, Chassis 0 01-20-2014 12:46 PM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
