Old 07-07-2015, 11:42 AM   #323
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Originally Posted by xxscaxx View Post
Its one of those things that when you look at it you are like "....oh!". You are like me and when something isn't in front of you, you want to know exactly how it goes on and end up over analyzing it
If you look back to @erok81 post you can see how each line is ran to each spot to give a general idea of where they go.
http://www.ft86club.com/forums/showp...&postcount=258
Dude I always do that, it's annoying even to myself lol. I literally put things together in my head, then end up saying "that's was easy" yeah shoot after I spent a week not sleeping over it
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 07-07-2015, 11:48 AM   #324
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That is one way to run it:
I preferred to run the coolant lines down off the turbo and then ran them together over to the driver side frame rail and the one heads to the back of the motor and the other goes kind of behind the A/C compressor and under the intake into the fitting on the coolant jacket on top of the motor. This keeps them hidden, but my FBM kit came with quite a bit of hose to allow that to happen. You can kind of make them out on the driver side frame rail in this shot:
yomny (07-07-2015)
Old 07-07-2015, 11:51 AM   #325
xxscaxx
Drives: 2013 SWP BRZ
This is exactly how i ran mine actually. I only quoted that other picture because the lines aren't hidden and kind of "show" where they hook up to, to help Yomny get a visual lol.
This is not a great pic but you can see the two coolant lines if you look closely on the bottom right near the block, swooping up towards the frame rail.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
yomny (07-07-2015)
Old 07-07-2015, 12:05 PM   #326
yomny
yomny's Avatar
You'll need extra hose for the one under the TB or will the supplied be enough? Another question, does JDL send the Garret with a fitting on the comp housing for boost reference?
Old 07-07-2015, 12:13 PM   #327
erok81
Drives: 2015 BRZ
They provide a good length of hose. The rear one is the right length but the front I had to cut. It was too long. I fixed mine so one of them is hidden now.
And my GTX didn't have a port for boost reference. But I fixed that with a drill, tap, and barbed fitting.
erok81 is offline   Reply With Quote
The Following User Says Thank You to erok81 For This Useful Post:
yomny (07-07-2015)
Old 07-07-2015, 12:16 PM   #328
yomny
yomny's Avatar
Thanks, I was wondering because a buddy asked them yesterday and they said it comes with it. Not sure if it's a little added bonus now @JDLAutoDesign is throwing in as it's clear we all need it.
Old 07-07-2015, 12:41 PM   #329
xxscaxx
I actually didn't cut either line, its a little long but depending on how you route it, it may be ok for the front line. The rear is good.
As far as the housing like KingTut said, the Garrett turbos don't have a boost port, you need to drill and tap it. Mention to Ronnie and they will drill and tap a hole for you. They did for me I also was provided a fitting but it was for an AN fitting since I converted everything to AN. I'm sure they could get you a barbed fitting though. If not thats an easy pickup locally.
also you can always do something like this too if you don't want to drill into the housing:
http://www.atpturbo.com/mm5/merchant...egory_Code=BCS
Old 07-07-2015, 12:46 PM   #330
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Dem ballers and their AN fittings and SS lines for a measly 15 psi, haha.
Old 07-07-2015, 12:46 PM   #331
yomny
yomny's Avatar
That's awesome, the things you could do are endless lol. Thanks
Old 07-07-2015, 12:49 PM   #332
xxscaxx
No problem. That thing actually works well too, I used it on an old setup on my STi. I think I still have it somewhere actually attached to a random coupler, lol.
Old 07-07-2015, 01:11 PM   #333
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Exactly how we do it. I know I mentioned that route to you. Its also in the install guide. Im currently updating the guide as we have made some small changes.
The reason we give lots of hose it to go under and route it away from the heat of the downpipe/manifold. Here is a shot of how we did @nelsmars lines
JDLAutoDesign is offline   Reply With Quote
The Following User Says Thank You to JDLAutoDesign For This Useful Post:
xxscaxx (07-07-2015)
Old 07-07-2015, 01:12 PM   #334
xxscaxx
Gah, I wish more than anything I could run an intake like that right off my compressor housing. Sigh.
Old 07-07-2015, 02:26 PM   #335
nelsmar
I am no longer doing this on my car... I have it reduced down significantly so that way I could attach my AOS to the intake and get a bit of vacuum. It did make things simpler / cleaner when I was just running a filter though :P
My flickr - Canibeat
Local magazine scout
Old 07-07-2015, 02:28 PM   #336
xxscaxx
yeah thats how I basically have mine...I mean I don't mind the intake pipe, I just hate how the filter is buried in between the ABS and washer fluid neck.
Looks way cleaner with just the filter, and also "balances" it better. With the piping and crap it makes everything look "off center" to me. I'm weird I know
Side Note: How you liking that 30r with the .63 hotside?
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 08:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
