Sam Strano
Old 07-06-2015, 04:47 PM   #3459
Cueman
Cueman's Avatar
Drives: In Perfect Control At All Times
Regarding tire pressures, I'm curious what others are using with 245 RE71's.
I finally ditched my Star Specs and picked up a set. 225 would have been preferred, but a local vendor had a screaming deal on 245's.
Tire pressures...
I have a pyrometer, so at the first event was checking temperatures, and letting them tell me what they can about what pressures to run. The surface was well worn asphalt. Not that grippy. Ambient temperature about 70 degrees.
Rear: I started at 35 psi, and bled all the way down to 27psi before getting nice even temperatures run after run. The tires were still not rolling over to the triangles.
Front: I started at 38 and bled all the way down to 31 before roll over became an issue. Temperatures said the center of the tire was still getting over worked. I wanted to bleed down more.
As for speed and feel. My co-driver and I definitely felt like the car was more sloppy feeling with less pressure... but speed seemed alright, and I thought the car got more friendly on the edge. We didn't quite PAX where we had hoped to on the new rubber, but were pretty close.
What is everyone else on 245's using for pressures? I'm thinking I might throw a couple more pounds in next time, just because 31/27 seems really low.
Cueman is offline   Reply With Quote
Old 07-06-2015, 07:42 PM   #3460
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
If you guys had to guess at it... what do you think the time difference is between factory alignment and -1.5 camber front, -1.0 rear on a 60 second course?
Tire pressures...
I run 29 front, 27 rear on 225s. It wasn't even close to the triangle on the sidewall until I did that. The stupid TPMS warning light comes on but at least it's a good reminder to put air back in after I'm done racing. 31/27 isn't "really low" if that's what works.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 07-06-2015, 08:49 PM   #3461
Biggins
Drives: Yes
I've regularly run 31f, 27-28r on 235/45 and 225/45. It works, but do what's comfortable for your driving style/pavement.
My local lot was just resealed, so I ran 28f, 25r to compensate and it was okay. No one was fast, but I was on par with where I usually am...
Biggins is offline   Reply With Quote
Old 07-06-2015, 09:22 PM   #3462
renfield90
The Stig's German cousin
Tire pressures...
FWIW the magazines ended up with low pressures as well (30-31 or so). You are probably on your own with pressures - I don't know anyone else in a twin running the 245 stones.
Also with the 245 pinched on a 7" wheel, accept the fact that you're going to murder your tread shoulders.
Old 07-06-2015, 09:39 PM   #3463
anonymoustallguy
Drives: Delete Me
Interesting. I thought there were others. Tires look like they will be dead in three events... not sure the shoulders are going to matter. The center rib shows major major wear after only 12 runs.
anonymoustallguy is offline   Reply With Quote
Old 07-07-2015, 01:33 AM   #3464
renfield90
Those who have worn through the center rib that fast either have too high a pressure, less than ideal driving style, or frequently run at a very abrasive site. There are people with 100+ runs on their stones with very reasonable wear.
Assuming you stick around 31psi and don't run at an abrasive site, try using less slip angle - not intending to criticize, but you may be overdriving the tire without realizing it. The RE-71R doesn't like a lot of slip angle anyways.
Old 07-07-2015, 11:29 AM   #3465
Cueman
Cueman's Avatar
weird... looks like I have a forgotten account on my wife's computer.
Criticism welcome. I registered for the Packwood Tour and Pro, which will be the first event where I get to run against other twins. Expecting to get humbled. Hopefully will learn a bunch.
Old 07-07-2015, 11:34 AM   #3466
SeanRTR
C-Street AutoX
SeanRTR's Avatar
The center rib on the RE71R wears very fast on the first couple of events.....
it seems to stabilize after that though, as I have several runs, and several thousand street miles on mine, and they're actually holding up alright. I still prefer last years tires though, as they actually require half a brain to drive fast.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
The Following User Says Thank You to SeanRTR For This Useful Post:
Jawnathin (07-07-2015)
Old 07-07-2015, 08:38 PM   #3467
Jawnathin
Drives: Toyobaru FRZ
On RE71s you can get away with WAYYYYYY more stuff than you could on something like an RS3 or Z2. You can be very hamfisted, throw it around and save it relatively easily. It really is an easy button to go fast.
Jawnathin is offline   Reply With Quote
Old 07-07-2015, 09:34 PM   #3468
coneracer30
Drives: 2013 Fiestorm FR-S
Since we are talking about tire wear. Here are my Rival S's after 156 runs on course asphalt (Packwood and PIR). They were flipped after 70. Not too bad.
coneracer30 is offline   Reply With Quote
The Following User Says Thank You to coneracer30 For This Useful Post:
SeanRTR (07-07-2015)
Old 07-07-2015, 10:27 PM   #3469
bslate3
Drives: 2015 CWP BRZ
What is everyone using for brake pads? I'd like just a little more bite and heat tolerance now that the Texas summer is in full swing.
bslate3 is offline   Reply With Quote
Old 07-08-2015, 12:50 AM   #3470
renfield90
How is grip at this point?
Seems pretty reasonable to me. I'm expecting to flip around 80 runs.
Old 07-08-2015, 03:00 AM   #3471
SVLTE
Wow, someone else is actually running the rival S? So little love for the tire compared to the 71R. Running 225 or 245? I'm on 225's and have been curious what others are running for pressures. I knew it didn't have a sidewall as stiff as the stones, but I've found mine to need pressures at or north of 35f/33r
SVLTE is offline   Reply With Quote
Old 07-08-2015, 08:52 AM   #3472
TMF
TMF's Avatar
Drives: '14 FRS TT5
I just bought the HP+, but I literally just picked up the car on Monday and haven't installed them yet. I'd be curious to hear what others are using also. Due to the lighter weight of the car, I'm wondering if the HP+ will be too much?
TMF is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
