Old 07-02-2015, 11:53 AM   #29
microbionic
microbionic's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by Astroboy View Post
What oil were you using
Past 3 changes motul 8100 ... had some castral and some royal purple in the mix before I settled on motul. All 0w20
microbionic is offline   Reply With Quote
Old 07-02-2015, 12:39 PM   #30
Astroboy
Astroboy's Avatar
Drives: None
Shit. I'm using motul 8100 eco energy
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 07-02-2015, 10:31 PM   #31
BRZnut
Drives: BRZ DGM Limited
What are your driving habits?
The Following User Says Thank You to BRZnut For This Useful Post:
Astroboy (07-02-2015)
Old 07-02-2015, 10:39 PM   #32
microbionic
Spirited but I do not think excessive. ..clean shifts.. will see redline on occasion.
Old 07-02-2015, 10:40 PM   #33
Astroboy
Astroboy's Avatar
Drives: None
That's weird. Did they say it was the oil? And when you said it was coming from the bottom, what exactly is coming from the bottom?
Old 07-02-2015, 10:44 PM   #34
microbionic
You know as much as I do. there is no way to know what the issue is till they rip it down...if they rip it down. That is up to subaru ... oil is asked about as standard procedure. .. they dont want to pay for it.. so if I did not keep up with my oil changes... thay can deny me my engine repair .. my oil recipts have me right around every 7k so I should be good..... but wont know until we hear from subaru.
The Following User Says Thank You to microbionic For This Useful Post:
Old 07-03-2015, 06:24 PM   #35
BRZnut
If it is what others have had, bet he spun a bearing in the lower end of the engine. There seems to be issue with oil starvation in the lower end causing rod knock and engine failure. At least that is what others have had happen to them on this board.
From what others have posted, if you get all the oil changes at the dealer, no issues with the repair being done under warrantee. If you do the oil changes yourself, the dealer will try every trick in the book to get out of covering the repair.
Hope all works out for you....Keep us posted!
Old 07-03-2015, 07:47 PM   #36
microbionic
Yeah... im preparing for that conversation..
Astroboy (07-06-2015)
Old 07-06-2015, 11:10 AM   #37
T182graff
Drives: Scion FR-S
Have you guys had any luck with this?
T182graff is offline   Reply With Quote
Old 07-06-2015, 11:17 AM   #38
microbionic
No word from subaru yet for me.
Old 07-06-2015, 11:42 AM   #39
T182graff
Drives: Scion FR-S
Good luck man,
I had the same issue with my car but my car broke down, the scion dealers said it won't be covered under my warranty.
Old 07-06-2015, 11:43 AM   #40
microbionic
Good luck man,
Did they give you a reason
Old 07-06-2015, 11:46 AM   #41
T182graff
Drives: Scion FR-S
They said it was the oil filter wasn't screwed on and that caused the oil loss. I told them I changed the oil for 2 years and nothing that can't be the case, they never pulled the codes or anything.
Old 07-06-2015, 11:53 AM   #42
microbionic
Was ur oil low?
engine, frs, knock, ping, sound
anyone experience engine knock on 91 octane? chenshuo BRZ First-Gen (2012+) — General Topics 15 01-13-2013 08:10 PM
obd2 engine sound app brichard0625 Engine, Exhaust, Transmission 4 09-25-2012 05:36 PM
Engine sound trying too hard? pinoyplaya BRZ First-Gen (2012+) — General Topics 8 09-06-2012 08:04 AM
Muddled sound issue was385 Electronics | Audio | NAV | Infotainment 7 06-28-2012 01:14 AM
