Old 07-06-2015, 02:21 AM   #29
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Originally Posted by Vroomin86 View Post
You changed everything except the snorkel! try stock snorkel, reflash to stock rom and see what happens
And another reason i dont think it is snorkel issue - she was working fine for quite a while but then suddenly something happened and this bounce appeared. It was ok with HKS duct before.
Ondreiko is offline   Reply With Quote
Old 07-06-2015, 04:00 AM   #30
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Ondreiko View Post
And i am terribly knocking on this new flash A02G.
What makes you say that? I see no evidence in that log. What I do see is that you're not using the right addresses for the change in ROM.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-06-2015, 04:25 AM   #31
steve99
Drives: FT86
just was at the dealer's service. they didnot recognise the issue, made a log with the bounce and reflashed me upto A02G (my original cal id was A00G). So they promised to send the file to subaru motorz as soon as the warranty engineer returns from vacation (in one-two weeks).
http://datazap.me/u/ondreiko/stock-a...=0&data=1-9-14
OK heres the deal on A02G roms and OFT
If your running a real A02G rom flashed by the dealer the OFT will not log it correctly.
The reason is the ram addresses for logging knock parameters changed between the A01G and the A02G roms. That why tour IAM reads zero its not knock its just the oft logging incorrect address in ecu. looks like MAF parameters not logging correctly either.
The OFT A02G rom is not rearly an A02G rom its a hacked A01G rom so its loggs correctly but your not actually getting the A02G updates which were probably only idle related as the OFT A02G is rearly just an A01G calid adjusted
The tune tables timing/fueling ect are same A01G/A02G their appeared to be only changes to undefined tables and must have been some code change to shift the ramm addresses for logging
From memory the only knock parameter that logs correctly is KC Learned you can derive IAM and knock from that if your keen.
Old 07-06-2015, 04:37 AM   #32
steve99
Drives: FT86
the oft will log a couple of "throttle" related parameters i cannot rember them at present but i think one is accelerator pedal position ie the input to ecu and the other is the throttle plate position.
it may be worth logging those and seeing if the throttle pedal position remains constant when you get the rpm bounce.
It going to be difficult to diagnose. lots of stuff happens at idle
your going to have to flash a OFT A01G/A02G rom so your logging works again as it looks like the maf v is also not logging correctly.
Old 07-06-2015, 05:41 AM   #33
Ondreiko
RWD addicted
Ondreiko's Avatar
Advance multiplier = 0, FLKC = 100. My usual reading should read AM = 1, FLKC = or less than 0. So i was thinking Adv. multiplier less than 1 means knocking anyway.
I just reflashed to OFT OTS based A02G tune and it shows everything as i like =))
Old 07-06-2015, 05:43 AM   #34
Ondreiko
RWD addicted
Ondreiko's Avatar
Do you mean my OFT was logging A02G using A00G definitions and this is the reason why i saw knocks?
Old 07-06-2015, 05:44 AM   #35
Ondreiko
RWD addicted
Ondreiko's Avatar
Now i start to undrrstand that features, thank you, mate!
Old 07-06-2015, 05:47 AM   #36
Ondreiko
RWD addicted
Ondreiko's Avatar
Yesterday i reflashed scared mine to OFT based A02G Rom, now it reads correctly
Old 07-06-2015, 06:16 AM   #37
Ondreiko
RWD addicted
Ondreiko's Avatar
And seems i forgot to mention another symptom of the same, as i think, issue - my revs are dropping too slow if i drop accel pedal on either stationary or moving vehicle. It probably can't be measured (i mean dropping speed), but my feeling is strong and i am sure it is not normal and it should drop faster.
Old 07-06-2015, 06:26 AM   #38
steve99
Drives: FT86
Maybe throttle body actuator is slow to act or faulty, but this is expensive part too expensive to just try without knowing for sure, maybe have to wait for dealer diagnosis.
maybe just try unplugging and cleaning connector at throttle body.
maybe log throttle/accelerator position and throttle plate position on see they move in sync when throttle released.
I think this will work with car just turned on without starting, you could also watch throttle plate like this by removing intake hose with engine off but ignition on.
Old 07-06-2015, 07:24 AM   #39
Ondreiko
RWD addicted
Ondreiko's Avatar
This is actually what dealer tried to find yesterday - discrepance between command and actual throttle position, but noone was sure if it was detected yesterday. Anyway, dealer loged all throttle related readings. Will see what kind of answer Subaru motors would receive from Toyota motors, where Subaru definitely will forward my request
Old 07-28-2015, 05:30 PM   #40
Ondreiko
RWD addicted
Ondreiko's Avatar
So i found to change MAP, MAF sensors and throttle body - nothing has changed, the bounce is still there. I removed HKS duct as well with the same result.
Moreover, today they called me from local dealer as they received answer from Subaru motors. It stated that my case is not an issue and my engine is working the way it should. I promised to inform them as soon as i find the reason of the bounce myself.
Still thinking of a possible bounce source.
Old 08-11-2015, 06:10 AM   #41
Ondreiko
RWD addicted
Ondreiko's Avatar
So here is kinda conclusion:
occasionally i installed new battery instead of stock Panasonick battery, and the most irritating part of the bounce is gone.
There is little bounce still remained with the car, but it is not bouncing as high as it did with the old battery. I am no more bothering about the bounce meaning i don't feel this bounce as a malfunction anymore.
And i don't think of the door panel (speaker cover) rattle fix while AC is on as this rattle is gone as well as the rough AC working (shakin') mode.
God bless new batteries and punish matsushita
Where do you keep your revs? ScionFrsFan Scion FR-S / Toyota 86 GT86 General Forum 54 06-11-2015 01:07 AM
What's causing slow dropping revs? hchi rku Engine, Exhaust, Transmission 15 03-08-2014 07:39 AM
2.5L with lower revs/more torque, or 2.0L with higher revs? Superhatch Engine, Exhaust, Transmission 124 08-28-2013 01:20 PM
vid of dealership bouncing frs off rev limiter Big T FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 95 08-02-2012 12:54 AM
AC cuts out at high revs. Cool feature? Superhatch BRZ First-Gen (2012+) — General Topics 9 06-28-2012 03:13 PM
