Old 07-03-2015, 01:17 PM   #99
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I think the FT needs a cage, without a doubt, and the front needs extra bracing due to those strut towers.
I'm sure you have loads of data with the S2, so when you get data from the FT where are the deltas? Where is it lacking? Entry, apex, exit, straight line... All of the above?
PRO86 | WTCC | STL
Old 07-03-2015, 02:20 PM   #100
D K
Stig's dark passenger
At this point Im gonna venture to say corner entry and mid corner.
Could be the exit too, but because the entry is so slow, it seems ok
D K is offline   Reply With Quote
Old 07-03-2015, 02:50 PM   #101
CSG Mike
CSG Mike's Avatar
Originally Posted by D K View Post
Im at sea at moment and dont have my old data logs handy.
If I was to list pros and cons for each car, they would be:
FRS:
Pros
Looks - its an awesome looking car.
Steering feel - very good feedback
Stock brakes - amazing how far we got with just stock brakes
Aftermarket support
Aero
Rear end break away - progressive
Cons
Drivetrain - engine and trans are made out of glass and Im just waiting to see what happens with the diff.
Balance - stupidly front heavy.
Front geometry - I suspect something is amiss there, need to tune more with telemetry (AIM Evo4 installed)
Lack of real world racing data - seems there are only a handul of people who are seriously interested in developing this car.
Too many people are interested in just shark fin antennaes.
A bitch to work on - time consuming
AP1/2
Pros
Chassis very stiff from factory
Front end bite - initial turn in is very precise
Rear end grip - very good (to a point - see below)
Engine - very well flowing head and generally bulletproof (in 32 races we lost only one engine and that was our fault for letting someone build it who shouldnt have)
Simple to work on
Cons
Looks - not crazy about them
Aero - not so good
Steering feel - numb and not much feedback
Transmission shifting - after a number of hard laps, feeling got even more vague and it was easy to mis shift.
Rear end break away - combined with the lack of steering feel, this was not ideal
Diff - only real weak point in the drivetrain - eventually we would show up with 2-3 built diffs and just swap them after a number of sessions.
Aftermarket support - much better now, but at the time we were one of the first to actually race an AP.
Expensive - parts are not cheap
Hubs - didnt like big wide slicks
Suspension mounting points - they were pretty weak and needed reinforcing
Stock brakes - rotors were only good for 3-4 sessions before cracking
This is the best that I can come up with off the cuff from memory.
I would be happy to provide more technical and precise feedback at a later date.
These are my opinions and they may not reflect yours.
Im cool with that.
D
The FRS diff will never fail. The core is shared with a MKIV Supra.
Old 07-03-2015, 02:51 PM   #102
CSG Mike
CSG Mike's Avatar
Exit and straight line.
Even boosted, it suffers a lot.
Old 07-03-2015, 02:52 PM   #103
CSG Mike
CSG Mike's Avatar
Good question!
Ironically enough - zero!
I must be the only one and I am counting my blessings.
Ive received a lot of help from the csg guys, Jackson Racing and Church Automotive Tuning.
I really think without the right ingredients, I would have been on my 9th engine right now.
As far as a vette or a porch is concerned, I didnt want to do that.
I wanted the nimbleness of a small, lightweight coupe.
Maybe after my next track day, I will unlock some big secret and fall in love with this car??
Who knows
You have no idea how much I want to slap you.
Old 07-04-2015, 04:02 PM   #104
rice_classic
DK says corner entry and mid corner
CSG Mike says exit and straight.
So I was right... all of the above. LOL
It's very difficult to fix something that's bad everywhere. Which end works the best? Front or Rear?
Is the front roll stiffness addressing the tire's contact patch? Too much/too little camber? Not enough caster to maximize cornering dynamic camber? When it comes to putting the power down (exit) is it struggling with oversteer causing the driver to "wait" or is putting power down causing the front give up like it's lifting up the inside front and outside front is giving up?
Any rear suspension bind been identified? I know some others have pointed out potential rear suspension bind. Are spherical bearings being used to make sure the suspensions moves without impedance and there's no funny business going on under load like dynamic toe changes from bushing deflection?
edit: You're not trying to use any setup parameters on the FT that worked on the S2 are you? I doubt very little of the S2 setup would be ideal on the FT.
PRO86 | WTCC | STL
The Following 3 Users Say Thank You to rice_classic For This Useful Post:
CSG Mike (07-04-2015), glamcem (07-06-2015), strat61caster (07-05-2015)
Old 07-05-2015, 08:49 AM   #105
burdickjp
Drives: 2013 ultramarine Scion FR-S
Pros
Cons
You seem to be contradicting yourself here; they moved the drivetrain to achieve a desired rate of rotation.
burdickjp is offline   Reply With Quote
The Following User Says Thank You to burdickjp For This Useful Post:
EAGLE5 (07-05-2015)
Old 07-05-2015, 01:50 PM   #106
D K
How is that contradicting?
Old 07-05-2015, 08:13 PM   #107
rice_classic
D_K,
You should fly me down, I'd be happy to help test it on track. I won't even charge.
PRO86 | WTCC | STL
Old 07-05-2015, 09:50 PM   #108
Sideways&Smiling
Drives: AP2 S2000, S14 240sx
Dude, these things are not FWD. MacPhail struts work just fine on the front of a RWD car.
The lack of dynamic camber means very little when you're working with RWD because you tend to run a higher roll stiffness setup in the front and softer in the rear so between a static camber, stiff front roll and a large caster angle the contact patch of the front tires is appropriately utilized.
Tell that to the double wishbone equipped Silvias competing at the top (& podiuming) in World Time Attack. :P
Sideways&Smiling is offline   Reply With Quote
Old 07-06-2015, 06:42 AM   #109
Valentino
Drives: GT86 2014
I'm sorry but you all are talking about the 86? That its a horrible handling car? Or you all are talking about the S2000?
Valentino is offline   Reply With Quote
Old 07-06-2015, 07:10 AM   #110
swarb
Read the question before the answer.
Old 07-06-2015, 09:34 AM   #111
Valentino
Drives: GT86 2014
So what they want to say is that the S2000 is better in corner entry, mid corner, exit and straight Then the 86?
Or regardless of the s2000 the 86 is a bad handling car?
Old 07-06-2015, 10:24 AM   #112
burdickjp
All those Porsches must be doing it wrong.
best new years ever. HolyAssertion Southwest 25 02-23-2015 07:14 PM
Me in 10 years amaciose Off-Topic Lounge [WARNING: NO POLITICS] 18 02-12-2014 01:37 PM
New Years L3P47 Scion FR-S / Toyota 86 GT86 General Forum 0 12-31-2012 08:15 PM
6 years from now... carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 18 02-02-2012 09:42 PM
