| Member's Car Journals Car journals by our members. |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
Build Thread
I've put about 3k or so into this car so I've figured it's time to make a build thread Upgrade List ~~Exterior/Interior~~ -iJDM Black Side Markers -HID Retrofit -Morimoto Bixenon HID w/ blacked out headlights -Diode Dynamics Switchbacks -Diode Dynamics interior LED -Tinted Valenti Tail lights -Debadged rear/front, added GT86 badges -CNC'd Purple Shift Knob -Perrin License Plate Relocator -35% Tint -2 10" Kicker Subs in sealed box -Pioneer AVH-2400BT Touchscreen -Replaced door speakers with 6.5" Alpine 3-way ~~Performance~~ -Perrin 2.75" CAI -Zeta Performance Inlet Hose -Open Flash UEL Catless Header -Open Flash Tablet (Stage 2 UEL) -E85 Ethanol Fuel 105 Octane -Perrin Exhaust Tips ![]() -Weir Performance 4.56 Final Drive swap ~~Suspension/Wheels~~ -Enkei RPF1 17x9 +35 Gunmetal -Goodyear F1A2 245 40r17 -Eibach Sportline Springs 1.4" drop front/rear -Whiteline Camber Bolts -Koni Yellow Shocks -Camber -1 Rear, -1.5 Front -SPC Lower Control Arms The car as it stands now: ![]() So now we go onto the fun Picture detailing part ![]() Day 1: From the Dealer, used, but in perfect condition 14k miles. CAR IS COMPLETELY STOCK, other than the Pioneer unit ![]() ![]() ![]() First upgrade I do other than the air filter is the sound upgrade. Car Came with Pioneer AVH-2400 from the previous owner. ![]() ![]() Went to @DarrenDriven's house and had some Eibach Sportlines installed! ![]() ![]() ![]() 6 Months Later Went to a couple meets and got some shots of my car/others ![]() ![]() ![]() Finally decided to bite the bullet and buy some actual performance. One of the forum members was selling a used Open Flash Header / Open Flash Tablet combo for $800. Couldn't resist ![]() ![]() Started off by running a stage 1 EL 91 Tune for the first week or so. The drive-ability was increased, torque dip was reduced and it was a nice change over mostly stock performance. Constantly was checking the software tuning sub-forums and ended up paying a visit to a local shop that served E85. Corn-juice, Car booze. Whatever you wanted to call it, it WORKED... On a stock car, the E85 OTS tune is quite good. The attention to detail from @steve99 and @Shiv@Openflashperformance was noticable. After taking it easy for around 25-30 miles to let the ECU adjust, the engine roared to life like nothing before. After several days of using the tune and E85 I noticed a sound around the 3800-4500 RPM Range, I was still learning about the fuel trims and was honestly worried that it was running lean. After researching a while longer I found it was the VVTi caused from the tune, and the sound grew on me as I waited for the header to arrive from PA. After some unsuccess of getting help putting the Header on, I ended up borrowing jack stands from my brother and putting the header on myself, as this was the last piece of the puzzle that I had purchased. ![]() Took some time and using the borla header install pdf, managed to mount and seal the new header into place. I bought and used new gaskets from the dealer. ![]() ![]() 1 Month Later I decide to finally Dyno my car to see what I'm actually making at the wheels. I set up the appointment at PRE in portland and show up to get it dyno'd. Lots of mixed things about PRE, honestly I doubt I would ever let them work on my car, but as far as buying parts and using their Dyno; they're good at what they do. Video and Dyno sheet: [ame="https://www.youtube.com/watch?v=o-ChaeruUjA"]FR-S Dyno PRE - Portland - YouTube[/ame] ![]() Over 200whp was the final result, of course on E85. But i'm still very happy with the result. [ame="https://www.youtube.com/watch?v=occuNSTlkIo"]UEL E85, 4.56 FD swap 0-80MPH - YouTube[/ame] I'm loving the journey so far ![]() ![]()
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() Last edited by Aztec; 07-03-2016 at 09:40 PM. |
| The Following User Says Thank You to Aztec For This Useful Post: | Mr.Impreza (07-03-2016) |
#2 |
Bought Valenti's with the bottom tinted light to complete the Black/Red Look
I'm loving them so far ![]()
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() Last edited by Aztec; 07-01-2015 at 01:43 AM. |
#3 |
Drives: 2013 Asphalt FRS M/T
Where is the gif in your sig from?
#4 |
Pulled it from another site that someone had it ^^ love it
Sent from my SM-G900V using Tapatalk
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
#5 |
Drives: 2013 Subaru BRZ
Post more pics! Especially of the wheels I want to see the drop from the Eibachs
#6 | |
Eibach springs are a great way to start lowering. I'm planning to pair them with koni yellow springs to get normal ride feeling back. Then add 17x9 +35 rims to make the wheels flush ![]()
NEW CAR!🚨🏎️⛽
| The Following User Says Thank You to Aztec For This Useful Post: | simonweisberg (07-06-2015) |
#7 | |
#8 | |
![]() Glad you dig it Sent from my SM-G900V using Tapatalk
NEW CAR!🚨🏎️⛽
#9 |
Bought new wheels/Suspension Parts!!!!
Enkei RPF1 17x9 +35 Gunmetal Goodyear F1A2 245 40r17 Koni Yellow shocks to match with the Eibach sportlines SPC Lower control arms to correct the negative camber ![]() ![]() ![]()
NEW CAR!🚨🏎️⛽
| The Following 2 Users Say Thank You to Aztec For This Useful Post: | Mr.Impreza (07-03-2016), OAKOS Automotive (03-01-2016) |
#10 |
Just got back from getting the final drive swap completed by a local shop in the NW area. Got the ring/pinion and the install kit from weir performance for a little over $400
![]() ~ Found a shop in Portland, OR that had done SEVERAL final drive swaps on the 86 platform, and he's incredibly fair for his rates! Got the entire labor complete for around $370 $300 for labor $70 for supplies ![]() It was done in a single day. I just need to change out the fluid in around 1000 miles after the gears have broken in. Absolutely NO whine at all from incorrect backlash. Entire car has more torque, and when this mod is paired with E85. I don't believe there is a better NA setup that you can do!! ![]() Just wanted to share my experience
NEW CAR!🚨🏎️⛽
| The Following 3 Users Say Thank You to Aztec For This Useful Post: |
#11 |
How's the ride? now that you have the Koni's installed.
#12 |
Better than stock honestly!
I rode in my friends stock frs, then rode in mine and the konis mitigate all the small bumps. Sent from my SM-G900V using Tapatalk
NEW CAR!🚨🏎️⛽
| The Following User Says Thank You to Aztec For This Useful Post: | Ultramaroon (08-15-2015) |
#13 |
Swapped in a pair for OEM headlights that have been
taken apart, dechromed and sprayed black. With the HID Retrofit for the FRS BEFORE: ![]() ![]() AFTER: ![]() ![]()
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() Last edited by Aztec; 09-02-2015 at 10:44 PM. |
| The Following User Says Thank You to Aztec For This Useful Post: | Lonewolf (12-07-2015) |
#14 |
Hot Lava Lover
Drives: 2013 Scion FR-S- lava
bad ass
Lookin good! I can attest that your car drives awesome after you let me take it for a spin.
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 08:52 PM |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 10:59 PM |
| SWP's 13' BRZ Build Thread | SWP BRZ | Member's Car Journals | 2 | 01-16-2015 02:23 PM |
| Jac's BRZ build thread | Jac | Member's Car Journals | 0 | 04-30-2014 08:09 PM |
| Aztec Bronze Proj BRZed | Project BRZed | Member's Car Journals | 6 | 01-13-2014 03:48 AM |
