Old 07-02-2015, 05:43 AM   #1
h3opama
KW V3: 16 clicks for compression?
Hopefully this is not a stupid question but I recently picked up a set of KW V3 for my car. I read through the manual to figure out what the recommended rebound and compression settings should be. The manual mentioned that there were 12 clicks for compression (bottom adjuster). However, when I attempted to count for myself, I noted a total of 16 clicks for compression. Are the last four "soft" clicks useless? Am I going crazy?
Thanks in advance for the help guys!
h3opama is offline   Reply With Quote
Old 07-02-2015, 02:29 PM   #2
wparsons
wparsons's Avatar
Are you counting from bottomed out, or from fully loose?
flickr
Old 07-02-2015, 04:21 PM   #3
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
You should turn the dial clockwise to full stiff. Then counterclockwise to your setting. Turning it past 12 clicks counterclockwise may damage the shock.
JDKane527 is offline   Reply With Quote
The Following 2 Users Say Thank You to JDKane527 For This Useful Post:
h3opama (07-02-2015), wparsons (07-02-2015)
Old 07-02-2015, 08:04 PM   #4
h3opama
I counted 16 clicks both from full soft and from full stiff which led me to believe that there was supposed to be 16 clicks. I also actually heard the "click" noise after each turn on the knob as well which did not help. I guess those last 4 clicks from full stiff are redundant? Hopefully I didn't damage anything... I didn't leave the the settings within the last 4 clicks -
Old 07-02-2015, 09:01 PM   #5
JDKane527
JDKane527's Avatar
You probably didn't damage anything. The click you hear is just from a spring loaded ball bearing in the adjustment knob. You could continue rotating and will hear clicks. Reason I know is one of my adjustment knobs fell off so I took the other one off and discovered the ball.
The Following User Says Thank You to JDKane527 For This Useful Post:
"dEAD CLICKS" ON TEIN ST FLEX Khánh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 03-10-2019 03:36 PM
Ohlins Road & Track - settings (clicks) for street/track/ax dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-27-2016 10:36 PM
Low compression? Venator Engine, Exhaust, Transmission 4 06-17-2014 11:37 AM
Driver side window clicks everytime it opens umpadupa Issues | Warranty | Recalls / TSB 10 10-25-2013 11:20 AM
Car "Clicks" When Weight is Transferred Back and Forward disgruntld Issues | Warranty | Recalls / TSB 10 10-18-2013 07:33 PM
