Old 06-29-2015, 03:50 PM   #1
pattyb86
Drives: Scion FR-S
Mods before adding turbo/supercharger
I'm going to be adding a supercharger or turbo (haven't decided yet) to my FRS. So far, i have upgraded the intake as well as the exhaust. Im wondering if there are any other mods that I should make before going ahead with the forced induction. Also, input on what to choose between a turbo and a supercharger would be greatly appreciated!!!
pattyb86 is offline   Reply With Quote
Old 06-29-2015, 03:51 PM   #2
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Yes.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following 4 Users Say Thank You to woode For This Useful Post:
cdq85 (06-29-2015), kch (06-29-2015), ShadowReaper (10-23-2017), WHITE (06-29-2015)
Old 06-29-2015, 03:51 PM   #3
Astroboy
Astroboy's Avatar
Drives: None
Bypass valve, catch can, oil cooler, better oil.
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 06-29-2015, 04:19 PM   #4
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
Read.
WHITE is offline   Reply With Quote
Old 06-29-2015, 04:21 PM   #5
kbogarto
Drives: 2013 BRZ limited WRB
3 bar map sensor, wideband O2
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 06-29-2015, 04:21 PM   #6
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
Larger wheels/tires... stockers are a joke
ybotspawn is offline   Reply With Quote
Old 06-29-2015, 04:22 PM   #7
IBill4You
Drives: 2015 Subaru BRZ
clamp your pcv system hoses. cam block off plate.
take care of the required supporting mods then look at your budget. You have to decide if you want supercharger or turbo then which kit fits your budget and power/reliability/manufacturer/distributor customer service. Then find a tuner for a dyno tune.
IBill4You is offline   Reply With Quote
Old 06-29-2015, 04:32 PM   #8
dpgfunk
Drives: 2012 E92 M3, 2013 BRZ
Tires
dpgfunk is offline   Reply With Quote
Old 06-29-2015, 04:50 PM   #9
STV3
Señor Member
STV3's Avatar
Driver Mod
STV3 is offline   Reply With Quote
Old 06-29-2015, 04:54 PM   #10
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Ultimately it depends on the kit you are getting, fuel you expect to run and horsepower you want.
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 06-29-2015, 04:58 PM   #11
raven1231
Da power cable needs pluggin in first
Old 06-29-2015, 05:05 PM   #12
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
if you have to ask big man, you can't afford it.
cdq85 is offline   Reply With Quote
The Following User Says Thank You to cdq85 For This Useful Post:
ybotspawn (06-29-2015)
Old 06-29-2015, 06:18 PM   #13
Crazypinoy9
Drives: FR-S TRD RS1#1488
not exactly sure how the OP asking what he needs has to do with him being to afford it or not...
and FYI to the OP, you said you upgraded the intake but does that mean you upgraded the filter or installed an aftermarket intake? Because if you bought an aftermarket intake you better plan on selling that because you won't be able to use it with either the SC or the Turbo.
Crazypinoy9 is offline   Reply With Quote
Old 06-29-2015, 06:45 PM   #14
cdq85
cdq85's Avatar
that quote was a joke (from a movie). if you would like a serious response, here it goes. there are a trillion threads on supporting mods for FI so if you haven't done the research and aren't mechanically inclined, you may want to hold off until you are sure about what you're getting into. OP gave a broad questions with no specifics on power goals of car so of course he will get jackass responses
Crazypinoy9 (07-05-2015)
forced induction, mods
HKS Supercharger V2 vs. Greddy Turbo Kit vs. Crawford Turbo Kit Ogremair Forced Induction 27 09-10-2015 04:39 AM
Installing a Turbo Kit + other mods chiefshayan Forced Induction 21 01-22-2014 10:58 PM
HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! rickspecd Forced Induction 4 07-12-2013 11:50 AM
turbo kit supporting mods lbroskee Forced Induction 13 03-30-2013 08:56 PM
Sensible Mods Adding Value to FR-S/BRZ? Braces Scion FR-S / Toyota 86 GT86 General Forum 24 11-12-2012 10:32 PM
