#1751 |
Drives: 2014 WRB BRZ Limited
Yeah, I've got a road trip soon for work. It will give me a chance to log some miles under high speed conditions. I just hope she doesn't go into limp mode hundreds of miles from home.
#1752 |
How long does it take the ECU to learn a new tune? Also when I plug in (or unplug) my OFT when the car is running I occasionally get an ABS and TC light. Suggestions??
#1753 | |
Drives: JAWS
Plug in your OFT before turning the key at all..problem solved. |
#1754 |
Drives: 86
anyone had their IAM (Adv Multipler) flashing on their OFT? i haven't plugged my OFT in for a while and decided to plug it in to have a look. my IAM is now flashing at 1 constantly. Anyone know how I should fix this? should I run software updates?
thanks |
#1755 | |
Drives: FT86
Their was some updates to functionallity make sure you load latesest OFM 1.20 i think and latest template file. and let oft update. Their are also tuning alerts make sure their are none set. |
#1756 | |
Drives: 86
i have updated OFM (its now v1.21), template and let OFT update. lets see if this fixes it. the logging was fine otherwise. only IAM was flashing. |
#1757 |
Drives: WRB Subaru BRZ Limited MT
So I got my OFT today and flashed a stage 1 tune... Car feels WAY better. I'm super happy, and kicking myself for not odering one sooner...
BUT... I previously has a buddy that worked at Toyota disable my seat belt chime via techstream... however the OFT reflash seems to have re-enabled the beeping that drives me nuts... can I diable the chime with romraider??? or is it seperate? and if it's seperate... why did the flash affect it??? |
#1758 | |
Drives: FT86
When ECU is reflashed other control units may be reset, its unusual that that chime has been reset, however you will need to use techstream to disable it again. or get one of these and do it yourself http://www.ebay.com/bhp/techstream |
#1759 | |
Drives: 2013 Asphalt 6spd
Phantom ESC, OFH, OFT, K&N Drop in
| The Following User Says Thank You to Target70 For This Useful Post: | MAX (07-03-2015) |
#1760 | |
... sound like an excelent soultion... since I don't want to use a techstream cable EVERY TIME i flash it... do you by chance have a pic of said cable? or a discription of where to find the connector?
#1761 | |
the fabric cover only has a small plastic clip that goes around a metal bar under the seat (circled in red), just adjust the seat as high as it goes, and reach under the seat behind the flap and pull down on the open side of the clip to spread it far enough to pull it off the metal bar (doesn't need much pressure). Then unclip the small white connector, and tuck it up out of the way (yellow circles). ![]() Disclaimer: if you need the chime to remind you to your belt, you might not want to do this. I take no responsibility for you getting thrown out of your car because you forgot to buckle up.
#1762 | |
#1763 |
This won't affect the airbags will it?
#1764 | |
shouldn't. As you are driving the car the drivers airbag should always be active. I think the seat sensor is the yellow plug in the picture.
| Tags |
| #lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest |
| Tablet on the dash ! | TRD_86 | Electronics | Audio | NAV | Infotainment | 23 | 05-16-2015 03:48 AM |
| Tablet Install | ThugNasty | Electronics | Audio | NAV | Infotainment | 4 | 04-13-2013 03:15 PM |
| Blutooth OBD II and a 9.7 tablet.. | Scooby South | Electronics | Audio | NAV | Infotainment | 10 | 12-16-2012 08:11 PM |
| 7.0 Tablet w/ Torque App | Thatruth2001 | Northwest | 26 | 11-21-2012 11:53 AM |
