Old 06-27-2015, 05:14 PM   #1
wizzo
Drives: 2014 Toyota 86
Ghost Cam Idle
Hey everyone,
This is a wierd post, but if anyone has seen the ghost cam tune for the Mustang 5.0's its on the same thought train.
So the 86 has dual vvti like the 5.0 mustang, ive seen people doing wierd things with their tune like causing pops and bangs at a certain load. Has anyone ever looked into using overlap through retarding or advancing the cams or whatever it is that is done with the dual vvti to create the idle of an aggressively cammed boxer engine.
Would i have it on my car if it was possible? Probably for the laugh.
Would i get bored of it? Probably after a while.
wizzo is offline   Reply With Quote
The Following User Says Thank You to wizzo For This Useful Post:
aagun (06-28-2015)
Old 06-27-2015, 05:56 PM   #2
aagun
Drives: 86
i know here people in the GCC doing crazy thinks socially in the UAE . do you know how mach COST boxer engine repair ?? or how long it can hold of knock or misfitting ??
POPPING OR misfitting AT idle can happen if you retard intake VVT and advance exhaust VVT , reverse what it should be . that will make POPPING and knock activity
about fuel cutoff misfire and make it by retard engine timing at max RPM and late firing the spark until the exhaust valves open and make a spark to fire the fuel in the headers
BUT your engine will not survive more then 1 month
so no now will Risk his car for fun socially with DI system and high pressure fuel system
aagun is offline   Reply With Quote
Old 06-27-2015, 07:55 PM   #3
But that's not what OP is talking about. I'm no expert but I bet it would be possible to get some lope by holding the valve timing optimized for high rpm only, which is where we get that second torque bump.
I bet the engine would be practically useless up to about 4500 RPM. Maybe one could reserve that lope up to 800-ish RPM then have a quick transition back to factory timing above that.
@KoolBRZ?
Old 06-28-2015, 02:10 AM   #4
wizzo
Yeah, similar to what you said, i dont know how its done on the mustang, but as soon as you get on the throttle, car is back to normal. Have they had issues, yes they have. But i just asked because it crossed my mind.
@KoolBRZ?
Ultramaroon (06-28-2015)
Old 06-28-2015, 02:13 AM   #5
wizzo
Our thoughts are on the two opposite sides of the globe, i dont know what you were able to interpret, but it seems you summarized everything i said in two words, and those two words were "bang idle".
Old 06-28-2015, 02:14 AM   #6
wizzo
@nelsmar ?
Old 06-28-2015, 04:03 AM   #7
Kodename47
Kodename47's Avatar
Drives: UK GT86
Practically speaking, you would have to find the addresses for the data that controls AVCS at idle. The standard cam tables aren't in operation.
It shouldn't cause any issues though, but will likely use more fuel.
.: Stealth 86 :.
Kodename 47 DJ:
aagun (06-28-2015)
Old 06-28-2015, 05:51 AM   #8
ChuckD
Drives: 2013 FRS M6
A friends's kid at work has a "cam" tune on his mustang. He said the cats needed to removed so they are not damaged by it. FWIW
ChuckD is offline   Reply With Quote
Old 06-28-2015, 02:09 PM   #9
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
@KoolBRZ?
As mentioned above, catalytic converters would be damaged by raw fuel being dumped into the exhaust. That being said, the secret to tuning the vvt AVCS is to remember what is happening to the velocity of the air entering the system. We can't change the valve lift, but we can change the valve timing. Do you want the lope to only occur at idle, or do you want it only in the lower RPM's. Tuned right, it could actually increase low-end torque. I'm interested. I'll try some vvt changes and get back to you if I find I can make it do what you're talking about.
KoolBRZ is offline   Reply With Quote
Old 06-28-2015, 02:56 PM   #10
aagun
Drives: 86
I'm also interested. i tried retread and advance intake and exhaust vvts and it banging
i will re flashing my car today at night and try banging it at idle and low revs
Old 06-28-2015, 03:06 PM   #11
KoolBRZ
KoolBRZ's Avatar
After trying various changes to the vvt, I believe the lope is caused by something else, or in addition to changes to the vvt. I think timing, and fueling are also changed, and those aren't changes I'm familiar with making. In addition, there are changes that can be made to just one bank of the engine, but additional definition files would be required to make them on an OFT. So, I'm going to bow out of this attempt, and leave it to others to try.
Old 06-28-2015, 03:09 PM   #12
stugray
Drives: 2013 GBS BRZ Limited
http://www.ft86club.com/forums/showthread.php?t=61069
Old 06-28-2015, 03:10 PM   #13
aagun
Drives: 86
[ame="https://www.youtube.com/watch?v=2nHyGvGMnxE"]2013 Ford Mustang GT Bama Cam Idle Ghost Cam Tune JBA Offroad X Pipe & Pype Bomb Axle Back Exhaust! - YouTube[/ame]
Old 06-28-2015, 06:42 PM   #14
aagun
Drives: 86
I tried changing vvt angles while idleing but no use .it is at zero
it should be specific table for vvt at idle
Ghost of Akina's 2013 Firestorm FRS Ghost of Akina Member's Car Journals 3 08-22-2015 01:51 AM
Ghost Car/Dad vividracing Off-Topic Lounge [WARNING: NO POLITICS] 4 07-23-2014 05:51 PM
Ghost Lights DuroSquad Cosmetic Modification (Interior/Exterior/Lighting) 7 07-04-2014 07:14 AM
Ghost's BRZ Build RurumariGhost NY / NJ / CT / PA 5 05-23-2013 09:31 PM
