Old 06-27-2015, 02:25 AM   #1
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
Amp Remote wire issue
Last week my door speakers decided to stop working, my system is stock and wanted to get an AM amp.
I installed the amp today and noticed that the remote wire line throws voltage when the car is off activating the amp, and then goes to 0v when I turn on the car and the amp turns off.
Has anyone had this issue before, and could it be caused by a faulty HU
Cartman is offline   Reply With Quote
Old 06-27-2015, 11:32 AM   #2
Cartman
Cartman's Avatar
Found the issue, looks like my radio is fucked, Brown wire at radio plug throws contant 12v when car is off then goes to 1v when I turn it on
Old 06-27-2015, 12:37 PM   #3
Chimera
Drives: FRS
Hmm
Old 07-17-2015, 03:59 PM   #4
Envirotech
Drives: 2014 BRZ
I am having that issue in my 2014. replaced the amp with an alpine 445U and when I start the car the door speakers do not work. I shut it off and start up again and they work fine. very odd. has to be something to do with the remote wire.
Envirotech is offline   Reply With Quote
Cant find passenger window wire from drivers side remote.. help? luv85 Electronics | Audio | NAV | Infotainment 2 11-03-2020 09:13 AM
Help me identify this wire! Extra wire around battery after clutch job YouShallKnow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 12-09-2014 02:04 PM
Avoid ECU reset, and factory amp remote wire Ty89m Electronics | Audio | NAV | Infotainment 3 08-08-2013 01:37 PM
Issue with remote key locking / alarm radroach Issues | Warranty | Recalls / TSB 0 05-13-2013 05:50 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 10:22 AM
