Old 06-26-2015, 10:10 AM   #309
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by moto-mike View Post
A bigger problem that we've found is fuel starvation under load in left turns. We've had some problems with it before at 1/4 tank or less, but we were fuel starved as high as nearly 3/4 at the event this weekend. We had two long left hand 3rd gear sweepers and on both we lost all power. Unsettling feeling when at full tilt. The issue is that at high boost running e85 you suck the fuel pump bucket dry in seconds. And the crossover tube is drawn by a venturi, which falls apart under high stress like this. We're looking at cost effective ways to battle this. Yes, we could keep the fuel tank at full, but at 19 psi on e85 we won't make it more than 10 minutes on track before having the same issue.
This is not a kit issue really--just a high power track car issue. No doubt just the first of many as we keep pushing this platform.
I have the same exact problem at the same fuel levels with my 205whp NA car running E85.
In for a solution!!
ATL BRZ is offline
Old 06-26-2015, 10:15 AM   #310
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
In for a solution!!
You know the solution. Surge tank.
King Tut is offline
The Following 2 Users Say Thank You to King Tut For This Useful Post:
ATL BRZ (06-26-2015), CSG Mike (06-26-2015)
Old 06-26-2015, 05:55 PM   #311
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Yup...we'll figure it out. We have something like 8 track days scheduled in the next two months and no way the miata will make them all (300whp SC...)
BRZ will get some love as time allows and we'll flog it at NJMP or Lime Rock. Just no way I'm putting it on there with stock brakes and no oil cooler. Custom bracket will be no problem as we did with the Greddy install two years back.
Xero-Limit is offline
Old 06-26-2015, 09:23 PM   #312
dstrout
dstrout's Avatar
So I have just read this whole thread. Assume my parameters are a stock motor and exhaust, always good 93 oct with occasional tanks of E85 when handy, 6-8 track days a year, and I'm mostly looking for silly-strong roll-ons from 2500 - 4K rpms on a daily basis. I'd also like to hit an honest 300 hp just for the ****-wagging rights of 9 lbs / hp.
Do I understand correctly that my best plan is a 335 with a small-ish pulley, a BOV to limit boost on the high end, and possibly a lowered rev limiter? Or could I do what I'm asking with a 210, given that I'll never build up a motor for this car, so don't need the headroom of the 335.
dstrout is offline
Old 06-26-2015, 10:26 PM   #313
s2d4
s2d4's Avatar
No
s2d4 is offline
Old 06-26-2015, 10:31 PM   #314
dstrout
dstrout's Avatar
Originally Posted by s2d4 View Post
No
I'm listening...
dstrout is offline
Old 06-27-2015, 09:00 AM   #315
350matt
Drives: toyota mr2/ Toyota GT86
you can limit the boost in the map by getting the throttle to close down so there should be no need to fit a BOV
if you want 300Bhp crank then you can get this without the 335, if you want 300 Whp then thats a different matter
from waht I've seen so far though you need a very savvy tuner to avoid blowing the engine with this big blower and a stock block
350matt is offline
The Following User Says Thank You to 350matt For This Useful Post:
dstrout (06-27-2015)
Old 06-27-2015, 09:53 AM   #316
s2d4
s2d4's Avatar
Let me know how and where you are going to install that BOV?
s2d4 is offline
Old 06-27-2015, 01:59 PM   #317
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
This is where @moto-mike's expertise comes into play. My 335 will hopefully be getting installed in July and I will be getting Mike to perform my tune.
Chad86 is offline
The Following 2 Users Say Thank You to Chad86 For This Useful Post:
Dream20b (06-27-2015), Xero-Limit (06-27-2015)
Old 06-27-2015, 03:58 PM   #318
SprintexUSA
SprintexUSA's Avatar
Drives: 2014 FT86
Do
not
EVER
put
a
blow
off
valve
on
this
system.
Thank you.
/PSA
SprintexUSA is offline
The Following 3 Users Say Thank You to SprintexUSA For This Useful Post:
CK_Bladesmith (06-28-2015), Dream20b (06-27-2015), Xero-Limit (06-27-2015)
Old 06-27-2015, 05:09 PM   #319
dstrout
dstrout's Avatar
So if I follow, a blow off valve is not a good idea?
My original post was actually meant as a serious question, I was not trying to troll. It didn't occur to me you could manage the risk of overboost through tuning. I think its going to take a while for me to get my head around the intersection of software and metal.
Thanks, and carry on!
dstrout is offline
Old 06-27-2015, 05:22 PM   #320
Dream20b
Y u do dis?
there is no potential for overboost on an SC due to being belt driven.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline
Old 06-27-2015, 05:40 PM   #321
Originally Posted by SprintexUSA View Post
Do
not
EVER
put
a
blow
off
valve
on
this
system.
Thank you.
/PSA
bee
cuz
it
already
has
something
to
do
that
job
Ultramaroon is offline
Old 06-27-2015, 06:48 PM   #322
SprintexUSA
Drives: 2014 FT86
Correct. A recirculation valve is the opposite of a BOV. Ours is open under vacuum and closes under boost. It does not vent "excess boost" because there isn't any excess boost. The only time you might get overboost is if you downshift into the wrong gear and hit 10k rpm. By then, excess boost is the least of your worries.
The Following User Says Thank You to SprintexUSA For This Useful Post:
Dream20b (06-28-2015)
500whp or bust, sprintex, sprintex 335
The new sprintex 335 supercharger jet86 Forced Induction 39 11-01-2014 11:27 AM
Innovate/sprintex SC rudysaliby Scion FR-S / Toyota 86 GT86 General Forum 3 10-28-2014 03:14 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 24 04-04-2014 02:38 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 5 03-05-2014 07:26 AM
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing TyperRspec789 Forced Induction 63 12-31-2013 07:39 PM
