#99 | |
Drives: WORKS CARB Legal Turbo BRZ
No reservoir, but we do include a simple filler neck for when you fill the system. Cheers.
#100 | |
A couple more snaps from @hushypushy. ![]()
#101 |
A look at the boost gauge setup in our BRZ, photo compliments of STAR ROAD.
OEM Subaru SPT boost gauge in an ATI air vent pod.
#102 |
Recent photos of the WORKS Stage 2 Turbo Kit installed in our BRZ. Bosch water pump and coolant hoses pictured in the bottom photo.
#103 |
| The Following User Says Thank You to WORKS For This Useful Post: | raven1231 (05-18-2015) |
#104 | |
| The Following User Says Thank You to raven1231 For This Useful Post: | WORKS (05-18-2015) |
#105 |
Photo of the junction between our WORKS turbo kits' up pipe and factory exhaust manifold.
#106 |
Another view of how the intercooler radiator is mounted.
#107 |
Drives: FRS monogram
@WORKS
what was the deciding factor on putting the IC where it is located? i can imagine the air-water system keeps temps fairly low but the 1.0 system seems like it would incure MAJOR heat sink, especially without a vented hood im also very surprised you didnt put the temp paint on the intercooler to see what kind of temps it was running but so far really nice looking setup +1 |
#108 | |
Intercooler location was selected to minimize charge pipe length and number of bends (optimize airflow and throttle response). Temperature paint wasn't used on the intercooler as its indicating temp window is roughly 600-1200 degrees F (doesn't indicate under 600F). Great for exhaust and brake components, but intake components don't get anywhere near that hot. Cheers.
#109 |
WORKS Stage 2 installed with front bumper on.
#110 |
Our Stage 2 intercooler radiator blends in nicely behind the grill.
#111 | |
![]() It's Official! The WORKS Stage 1 and Stage 2 Turbo Kits are the first FR-S/BRZ turbo kits to be granted a CARB Executive Order! Under CARB Executive Order D-748, the installation of our WORKS Stage 1 and Stage 2 Turbo Kits are exempt from the prohibitions of Section 27156 of the Vehicle Code for 2013 through 2016 model year Subaru BRZ and Scion FR-S vehicles. What does that mean? 50 state smog legal versions of our Stage 1 and Stage 2 Turbo Kits will soon be available! Stay tuned for more details and pre-ordering. Cheers, WORKS Motorsports
#112 | |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
| The Following User Says Thank You to hmong337 For This Useful Post: | WORKS (06-30-2015) |
| Rev Works - This is what we do! | Rev Works | Member's Car Journals | 146 | 04-21-2014 05:58 PM |
| WTB:Used Works VS-XX | whitefrs | Wheels and Tires | 5 | 02-20-2014 05:29 PM |
| Wtb works abm | BlackyRose | Engine, Exhaust, Bolt-Ons | 0 | 08-09-2013 06:27 PM |
| From Rev Works UEL to HKS EL | ramiram1984 | Engine, Exhaust, Transmission | 48 | 07-12-2013 09:17 AM |
| gps fix in the works | Lytheum | Issues | Warranty | Recalls / TSB | 3 | 08-24-2012 02:43 PM |
