Old 06-21-2015, 04:01 AM   #295
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
A fix for the 3" header to 2.5" overpipe gasket problem
As seen in this thread, http://www.ft86club.com/forums/showthread.php?t=89680 , there is now an adapter flange to mate up the 3" PLM header to an aftermarket 2.5" overpipe.
I got my dyno's done and am underwhelmed again. Today I determined I'm going to install this adapter flange and stop the leaks for good. I got pics before the removal. I have lots of overpipe clearance, but just one thing won't clear, the flange pipe into the 2.5" overpipe.
See pics below, I had to cut the pipe flush with the flange, then grind down to make the pipe lip flush, then sand and sand to get rid of the gouges I made in the flange while cutting the pipe. Notice how shiny the flange is now? There is about 1/4" of play in the flanges once the bolts are through all three plus the 2 gaskets. The bolt holes will not line up with a stock overpipe, but only an idiot would mate a 3" header to a 2.25" stock overpipe. I used a shorter bolt on the inside of the header curve, and a longer bolt on the top, outside of the curve.
I didn't have an assistant, so there isn't any video, but I got some good pics. If anything my overpipe has even more clearance then it did before. I have before and after clearance pics if you're interested. It really only applies if you also have an inexpensive, Top Speed Pro 1 Overpipe. How does it work? Great, now the only time I smell my exhaust is when I open a door or a window. I'm sure it flows a lot better too.
KoolBRZ is offline   Reply With Quote
The Following 3 Users Say Thank You to KoolBRZ For This Useful Post:
Hyper4mance2k (06-22-2015), raven1231 (06-21-2015), Valentino (06-22-2015)
Old 06-21-2015, 12:40 PM   #296
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
I'd be interested in seeing if this offers any gains.
Decay107 is offline   Reply With Quote
Old 06-21-2015, 01:37 PM   #297
KoolBRZ
KoolBRZ's Avatar
Not any gains compared to a 3" overpipe, but since those are real hard to come by for automatics, it definitely is more efficient then a flat lip, reducing from 3" to 2.375". It also makes sealing with gaskets straightforward and leak proof. The extra .25" thickness fit just fine with my aftermarket over and front pipes. If anything , I have even more clearance now. In addition, it is much cheaper than a 3" overpipe.
Old 06-23-2015, 08:06 PM   #298
Starkiller
Drives: 2013 Scion FR-S 10 series
I purchased one of these headers knowing full well what I was getting myself into. Lol. I'm still confident that it will be a good value for the money. I had the same gripes as everyone else about the roughness of the flanges, the lack of interior welds on where the runners meet the flanges and the fact that it is a three inch collector and flange where almost every overpipe on the market is 2.5". I decided to reduce it down to a 2.5" flange, plane the flanges and fill in the lack of interior welds and port it. Here it is...
Sent from my iPhone using Tapatalkoryopu
Starkiller is offline   Reply With Quote
The Following 4 Users Say Thank You to Starkiller For This Useful Post:
Hyper4mance2k (06-24-2015), KoolBRZ (06-24-2015), Lithium (06-29-2015), Turdinator (06-23-2015)
Old 06-25-2015, 03:09 AM   #299
steve99
Drives: FT86
since this is pretty will a nameless
posted up some cam tables for namless plm headers in OFT tune Tweaks thread below
They will get you in ballpark and probably better than the standard oft EL tables, but you may need to make other adjustments to fueling and ignition timing to get max benefit.
some their for ACE header as well.
The Following 4 Users Say Thank You to steve99 For This Useful Post:
AceHeader-MT (06-25-2015), Cross (06-25-2015), R2 (06-25-2015), raven1231 (06-25-2015)
Old 06-25-2015, 11:47 AM   #300
Shady195
Drives: '13 10 Series FRS #1203
Thanks @steve99
Edited all my tables, going to flash and check it out when I get home tonight.
Shady195 is offline   Reply With Quote
Old 06-25-2015, 01:14 PM   #301
Cross
It's the Mad Cow
Cross's Avatar
I'm getting ready to dyno mine now that it's completely done and supercharged but I'm still happy with the header.
I did feel like there was more in it na on E85 but I knew I would be going back to FI so I didn't worry much about it. Looks like you guys have been making some great progress.
Sent from my SM-G920V using Tapatalk
Old 06-26-2015, 12:00 AM   #302
KoolBRZ
KoolBRZ's Avatar
since this is pretty well a nameless
posted up some cam tables for nameless plm headers in OFT tune Tweaks thread below
Well you know I can't just leave well enough alone, because this didn't run well enough in my opinion. I did some Open Road Tuning and tweaking of the Intake and Exhaust Safe tables, and here is what I've come up with. It has more power up top, and more torque down low, it's just the middle that's aggravating. The flat spot is hardly noticeable in 1st, 2nd, and 3rd, but in 4th it feels a bit sluggish from about 3200 - 4000. Here's some pics of the final tables I've come up with.
Last edited by KoolBRZ; 06-26-2015 at 11:17 AM. Reason: Intake table not consistent
The Following 2 Users Say Thank You to KoolBRZ For This Useful Post:
CSG Mike (06-26-2015), steve99 (06-26-2015)
Old 06-26-2015, 01:33 AM   #303
steve99
Drives: FT86
Thanks for testing that will update the tune tweaks tables
Old 06-26-2015, 06:54 PM   #304
steve99
Drives: FT86
Originally Posted by Shady195 View Post
Thanks @steve99
see the updated from @KoolBRZ 's testing above
Old 06-27-2015, 03:52 AM   #305
Kodename47
Kodename47's Avatar
Drives: UK GT86
You ought to look at the area around 1200 RPM @ 0.8 load and above on the Exhaust map. Having the table drop to 0 isn't likely to help I know you won't hit those loads regularly but either set the row above to 0 or set that to 5/7/10. The system won't be able to accurately do that anyway, it's too much too quickly.
.: Stealth 86 :.
Kodename 47 DJ:
KoolBRZ (06-29-2015)
Old 06-28-2015, 08:42 PM   #306
Lithium
Lithium's Avatar
Drives: like an asshat
Sorry this has taken so long guys; last few weeks have been quite busy. Also I must apologize for directing you to this page and not the direct video link. What can I say its how the world works these days....
check out my latest post to see how the PLM header did on the dyno. Over all I'm happy with the product.
http://seefeldtmotorsports.blogspot.com/
Lithium is offline   Reply With Quote
The Following User Says Thank You to Lithium For This Useful Post:
shu5892001 (06-28-2015)
Old 06-28-2015, 09:28 PM   #307
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
Is the baseline with header and no tune? Or no header and no tune.
Thanks
2016 Lexus GS-F PPE EL Headers, Joe Z X Pipe, Tom’s Racing Drop in, RR Racing Tune, RR Racing Motor Mount, RR Racing USRS. 430WHP.
2024 Volvo XC60 T8 Recharge
shu5892001 is offline   Reply With Quote
Old 06-28-2015, 11:32 PM   #308
KoolBRZ
KoolBRZ's Avatar
I'll try it, but, I've completely thrown logical thinking out the windows where adjusting the Intake and Exhaust safe tables are concerned. I have better tables tried and proven for low end torque, but any changes I make to the high end make the flat spot worse. I'll post what I have after I try this.
cheapbastards, dbags, knockoff
(Irvine / SoCal) ForSale FA20Club Long Tube Catted Header $350 mad_sb Engine, Exhaust, Bolt-Ons 12 03-31-2015 11:53 AM
wtb: sound tube delete inlet tube Jimmy817 Engine, Exhaust, Bolt-Ons 1 12-21-2014 09:15 AM
Long tube catted headers possible? wparsons Engine, Exhaust, Transmission 6 01-31-2014 09:56 AM
New 4-2-1 Long Tube Header Anorexic 86 Engine, Exhaust, Transmission 28 08-25-2013 03:28 PM
Cinco de Slamo Meet in Long Beach NY (Long Island) whitefrs New England 11 05-01-2013 09:03 AM
