Old 06-25-2015, 07:59 PM   #1
MikeyBatz
MikeyBatz's Avatar
Drives: Scion FR-S
The Twins better with 5 speed box?
I was thinking would the frs/brz be better with a one less gear? I remember back in the day before the CVTs most subaru were 5 speed.
5 speed gear pros:
-better power band?
-quicker acceleration
-easier in traffic (manual)
cons
-less mpg
what do you guys think?
MikeyBatz is offline   Reply With Quote
Old 06-25-2015, 08:10 PM   #2
Sideways&Smiling
Drives: AP2 S2000, S14 240sx
no.
Sideways&Smiling is offline   Reply With Quote
Old 06-25-2015, 08:13 PM   #3
Why not go hog wild and just have 3?
Old 06-25-2015, 08:25 PM   #4
Sideways&Smiling
Allow me to elaborate:
All cars, not Subarus.
5 speed gear pros:
-better power band?
How? No.
See above.
Ok, maybe slightly, but still....... no. Because it's a manual and you should enjoy shifting if you own a manual. This isn't a big torquey V8 with long gearing and low end power.
cons
-less mpg
The difference in MPG efficiency isn't really worth thinking about. The specific engine and how hard you drive the car will be much more important to your MPG.
The one actual criticism is that 5 speeds tend to be slightly stronger. The S15 6-speed vs the S13/14 5-speed debate is a good example...... but, in reality, neither will be strong enough for people making big power, so it doesn't really matter all that much.
I'd always rather have the 6 speed.
Old 06-25-2015, 08:32 PM   #5
Exactly, for years we got along just fine with 3 speed MTs. The first AT in Chevrolets had only two speeds.
When I had my 06 Miata, I got along just fine with a 5 speed MT, and it had less power than the FR-S.
What I would like to see come back is the old Ford type "overdrive" .....
Old 06-25-2015, 08:34 PM   #6
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Just for historical knowledge (and my learning), would 3rd gear be overdrive? Or was there no such thing back then?
The Twins make me smile
Old 06-25-2015, 08:37 PM   #7
8R6
8R6's Avatar
Drives: FRS
power band being "better" depends on the engine tuning in conjunction with the gearing... but that said, a similar 5-speed compared to a 6-speed on a same car will most likely have taller gearing than the 6-spd, resulting in slightly slower acceleration since we dont have much power to begin with.
8R6 is offline   Reply With Quote
Old 06-25-2015, 08:39 PM   #8
Slip N' Slide with Power Glide!
Hell, not just the first but clean up into the early/mid 70s.
Old 06-25-2015, 08:42 PM   #9
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
5 speed gear pros:
-better power band?
Can you provide any documentation to support these statements?
I really don't see why that would be true.
cons
-less mpg
billwot is offline   Reply With Quote
Old 06-25-2015, 08:46 PM   #10
DJCarbine
Thupercharged
DJCarbine's Avatar
My first mustang had a 3 speed manual, made picking a gear pretty trivial
But really, I don't think you can find anyone to argue that a 5 speed gearbox would be better unless it was geared for a specific reason
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 06-25-2015, 08:46 PM   #11
GreenMonster
Just doing research
GreenMonster's Avatar
Drives: 03 Acura CLS 6MT
Even w/ a 6 speed, I still find myself occasionally trying to shift into seventh
GreenMonster is offline   Reply With Quote
Old 06-25-2015, 08:47 PM   #12
Back in the day, in most 3 speed MTs, the 3 gear was NOT overdriven ..... it was 1:1.
Some drivetrains had an "overdrove" unit that would make the ratio to the differential less than 1:1.
And, of course, we always have had the "Georgia overdrive" .......
Old 06-25-2015, 08:52 PM   #13
No. The 3rd gear was just a very long gear. Some came with OD as well though.
Old 06-26-2015, 12:58 AM   #14
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
OD was a set of gears after the transmission that could be engaged to make the driveline turn faster than the engine crank.
"Overdrive Transmission" on wikipedia has a pile of info.
Other twins gravitylover Other Vehicles & General Automotive Discussions 53 03-02-2015 11:38 AM
top speed axleback....or top speed dual catback? pepe Engine, Exhaust, Transmission 10 11-07-2014 07:12 PM
Is this one of the twins? Krazy Off-Topic Lounge [WARNING: NO POLITICS] 4 07-22-2014 09:33 PM
Is it just me or Twins are everywhere now? DrawingWaves Scion FR-S / Toyota 86 GT86 General Forum 93 03-20-2014 09:31 PM
Engine Speed vs Vehicle Speed for 6MT DetroitJake Engine, Exhaust, Transmission 22 04-27-2013 06:56 PM
