Old 06-25-2015, 10:22 AM   #2479
exam2300
I couldn't agree more, but if you want just a little more or a bite more free rev. Go E85...
exam2300 is offline   Reply With Quote
Old 06-25-2015, 11:53 AM   #2480
264grendel
Drives: 2013 Scion FR-s
Thats my plans down the road when i want more power.
264grendel is offline   Reply With Quote
Old 06-25-2015, 05:56 PM   #2481
JS + BRZ
Drives: 2010 MS3
So great to read all the positive comments on this kit.
Can't wait to get one on my BRZ eventually.
Old 06-25-2015, 06:40 PM   #2482
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
It's simple. Add to Cart.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
The Following User Says Thank You to Bramick For This Useful Post:
CSG Mike (06-26-2015)
Old 06-25-2015, 06:42 PM   #2483
JS + BRZ
Drives: 2010 MS3
I spend $5k, wifey spends $10k.
Not simple when you are married.
The Following User Says Thank You to JS + BRZ For This Useful Post:
Old 06-25-2015, 06:43 PM   #2484
Bramick
Bramick's Avatar
8yrs married
The Following 2 Users Say Thank You to Bramick For This Useful Post:
CSG Mike (06-26-2015), JS + BRZ (06-25-2015)
Old 06-25-2015, 06:58 PM   #2485
JS + BRZ
Drives: 2010 MS3
8yrs married
I got pwned.
The Following 2 Users Say Thank You to JS + BRZ For This Useful Post:
Bramick (06-25-2015), Porcupint (06-25-2015)
Old 06-26-2015, 01:22 AM   #2486
funwheeldrive
Originally Posted by DaiTT500 View Post
Sounds like a boost leak. It's a bitch to take off the bumper when the intercooler pipes pop off.
Are boost leaks rare with superchargers? I got them occasionally in my Srt-4 and DSMs, but Ive never owned a supercharged car.
Old 06-26-2015, 01:45 AM   #2487
SPCorBUST
SPCorBUST's Avatar
I think you can get them just the same, a loose clamp on a pipe is going to leak the same as any other loose clamp on a pipe.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
funwheeldrive (06-26-2015)
Old 06-26-2015, 04:52 AM   #2488
CSG Mike
CSG Mike's Avatar
The cause is identical, but typically you're not seeing as much pressure, so the chances are somewhat (perhaps marginally) lower.
We use assembly lube when assembling customer Jackson Racing kits to help ease positioning of all the charge pipes, and due to the length of each connector and the overlap, we've yet to see anyone blowing off charge pipes, even with a lubed up hose.
I can't really speak for the other kits, but I do know the Innovate/Sprintex/Cosworth/Edlebrock won't blow off charge pipes; they don't have any. A leak at the manifold level is unlikely. I've not really seen Vortechs blowing of charge pipes either.
Old 06-26-2015, 08:41 AM   #2489
JDsThatGuy
Drives: Subaru BRZ Limited
Relationship math
JDsThatGuy is offline   Reply With Quote
The Following User Says Thank You to JDsThatGuy For This Useful Post:
JS + BRZ (06-26-2015)
Old 06-26-2015, 11:02 AM   #2490
airmanmurphy02
Petrol head
airmanmurphy02's Avatar
Drives: 2013 Subaru BRZ
I am still loving my JR kit! Took it to the track night in America, and people were blown away with how quick the car is. I have the carb tune and a cat back. Let's just say I never had to point anyone by! Very usable power.
Sic Semper Tyrannis!
airmanmurphy02 is offline   Reply With Quote
The Following 2 Users Say Thank You to airmanmurphy02 For This Useful Post:
CSG Mike (06-26-2015), JS + BRZ (06-26-2015)
Old 06-26-2015, 11:10 AM   #2491
toast
Drives: 14 BSP Edelbrock BRZ
Originally Posted by 2ndgenhachi View Post
So a quick update on my issues with my kit. Checked ask charge pipes and intercooler pipes that I could reach without removing the bumper as I haven't had time due to work. maf sensor is clean and vertical. Reflashed carb tune to be sure. Still will not start. Forgive the awful sound effect but it has the slow vrrr, vrrr of the engine trying to turn but does not fire. Will remove the front bumper and check intercooler piping Sun. Again showed no symptoms prior to dying just cut off immediately after a right turn in 2nd partial throttle. I know I haven't checked all recommend sources yet but if this narrows it down for anyone I'd be grateful for any more input. Also I can push the lower ic piping thru the grill and they "feel" tight but can't thoroughly check them yet. Thanks again for all they help. This is a great community of car enthusiasts
Did you get your car straightened out? I know when I was working under the hood at one point I removed the maf sensor plug and thought I plugged it back in. Car ran fine for a week before it just died on me. Turns out I didn't 'quite' have the plug all the way in to where it snapped in place and eventually vibrated itself out. No maf signal = no running.
toast is offline   Reply With Quote
Old 06-26-2015, 11:14 AM   #2492
dp1
driving smoother faster
Drives: Sold
At NJMP Lightning today, first session, JRSC died. Not a problem with the kit, must be from a while back when I had a small leak from the SC cooler connection, some accelerated wear must have happened. Whine has been getting louder, slowly but surely. Can't drive the car and hoping to get in touch with Jackson Racing asap to get a replacement unit today or first thing tomorrow and fix this near the track. This will be fun. Love the kit and sticking with it. If anybody has information about a replacement unit or a shop nearby that can swap it or a mechanic who can stop by at the track and swap, please let me know, thanks!
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
