Old 06-25-2015, 01:05 AM   #239
modernbeat
Vorshlag R&D
modernbeat's Avatar
Drives: A new one every month
Not a sponsor here, so no.
Jason McDaniel at Vorshlag Motorsports
modernbeat is offline
The Following 2 Users Say Thank You to modernbeat For This Useful Post:
cdrazic93 (06-25-2015), civicdrivr (06-25-2015)
Old 06-25-2015, 07:50 AM   #240
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by cf6mech View Post
..my car weighed 2682 and now weighs 2814..
60 kg increase!! That's just crazy (in a good way). To think that 4 extra cylinders plus transmission plus a metric truckload of power only costs that much weight. Light weight seats, battery, wheels and bam! You're at zero gain.
Sounds mean too!
Can you tell us if there will be replacement bracing for the the indicated oem bracing shown in pic?
Ta.
Captain Snooze is offline
Old 06-25-2015, 08:21 AM   #241
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by modernbeat View Post
I think it went from 55% front weight with the flat four to 53% front weight with the LSx.
Very cool if true... Other swaps have gone the other direction, to 56/44.
What measures were taken to move the c.g. aft? Engine weighs more and its c.g. is further forward, transmission weighs more and is further aft, but still well forward of vehicle c.g. => no way an LS3/T56 Mag transplant into an 86 moves c.g. aft without other stuff going on! A/C delete, battery moved to trunk, etc.?
FTR the c.g. of an FD RX-7 moves forward a good 1.5% with LS/T56 transplant keeping all else equal. Not that its that a huge deal on a car that starts at 48F/52R :P
ZDan is offline
Old 06-25-2015, 12:14 PM   #242
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
the trans and engine doesn't have to move aft of c.g.
For the overall CoG to move aft, the weight only has to move aft relative to the weight it's replacing, not aft of the cars CoG...
Jaden
Jaden is offline
Old 06-25-2015, 01:52 PM   #243
cf6mech
Drives: FRS Silver LS1 swapped.
Sounds mean too!
Attachment 113552
Vorshlag, unlike some swaps, shoved the LS as far back against the firewall as possible, to the point of totally trashing a set of proto type motor mounts with hours upon hours of development work invested when they discovering they could gain another couple inches aft, another consideration is this isn't a Tremec T56 which some are using which requires remote shifter that puts the weight more forward, but the Tremec Magnum XL which is longer, making it direct shifting/more aft weight/better feel/and worth every penny in this swap in my opinion.....They have been doing swaps for years and understand the minutia to making it right the first time. As far as the factory bracing, I will be replacing it with a strut tower brace.
cf6mech is offline
The Following 2 Users Say Thank You to cf6mech For This Useful Post:
civicdrivr (06-25-2015), wparsons (06-26-2015)
Old 06-25-2015, 02:02 PM   #244
cf6mech
Read the build, it will make more sense if you read the whole build, there was a lot of work involved in moving the CG as far aft as possible, another consideration is the tranny it's not a T56, but the Tremec Magnum XL direct shifter...i.e. another gain in moving cg aft. Before the swap I already had Recaro seats and a battery relocate to the trunk. You guys gotta realize how heavy that little boxer engine weighs and how far forward they placed it.
cf6mech is offline
The Following User Says Thank You to cf6mech For This Useful Post:
hmong337 (10-17-2015)
Old 06-25-2015, 02:52 PM   #245
ZDan
ZDan's Avatar
Drives: '23 BRZ
I understand that, but the point was how much heavier the T56 Mag is vs. the stock trans. If it *is* significantly heavier, then it is likely is moving c.g. forward even if it's located further aft than stock.
Let's say the 140 lb. T56 is 40 lb. heavier than the stock transmission (wag). Stock trans looks like its c.g. is ~16" aft of front wheel centerline. Say T56 c.g. is 6" aft of that (probably optimistic), 22" aft of front wheel centerline.
Stock trans weight distribution on the front/rear wheels would be 84 lb. front, 16 lb. rear (100 lb. * 16"/101" wheelbase)
T56 Mag would be 109.5 lb front 30.5 lb. rear.
Stock weight is 2750 with 55/45 distribution, 1512.5 front/1237.5 lb rear.
T56 Magnum would change the weight distribution to 1538/1252, or 55.1/44.9.
Just don't see the transmission giving any weight distribution benefit, particularly if the T56 is significantly heavier. If they're the same weight and it's moved aft, that would move c.g. aft a small amount, tenths of a percent. I'm betting it's a wash between the added weight and it being moved aft.
ZDan is offline
Old 06-25-2015, 03:13 PM   #246
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Yeah,
For the reliable, huge, torque increase vs weight increase.
In my opinion it's an absolute hell yes.
With proper suspension, fuck yes.
How long can you consistently beat on a 400ftlb FA?
How long can you consistently beat on a 400ftlb LS?
Which engine has more meat left on the bone?
As said before transmission choice is also tits.
If the numbers are true. I would assume you could reduce the total weight back to stock. Without losing any luxuries/amenities.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline
Old 06-25-2015, 03:40 PM   #247
ZDan
ZDan's Avatar
Drives: '23 BRZ
I read the build and I've seen the pics, and I'm totally positive on this project! Totally awesome and I'm all for it I just don't see how weight distribution will not move forward unless other measures are taken.
The XL has an extended tail housing, doesn't move any major masses aft relative to the regular T56 Magnum.
FA20 may be heavy for an aluminum 2.0 four cylinder, but it is certainly lighter than a 450 lb. LS engine.
The boxer may sit relatively forward, but it's a lot *shorter* than an LS. So that even with the cylinder heads back against the firewall, there's no way the LS c.g. is aft of the FA20's, indeed it looks to be forward of it.
The 86 swap is the opposite of the BMW swap case, where the stock engine is much LONGER than an LS V8 and might actually be heavier. In that case, c.g. moves aft no question.
I could see how moving the battery from the front of the car to the back could get you back to stock distribution or slightly better, though.
Anyway, killer project and I'm looking forward to seeing it run!
ZDan is offline
Old 06-26-2015, 06:09 AM   #248
cf6mech
You might not see why but the scales don't lie. I'm sure Mr.Fair, upon his completion of the build thread will have explanations for you and us all, it will be coming out soon. As I have noted before Vorshlag weighs everything.
June 24 at 12:36pm
Terry Fair A stock BRZ/FR-S has a F/R ratio of 56% front / 44% rear. It is now 52% front / 48% rear with the V8.
cf6mech is offline
Old 06-26-2015, 12:52 PM   #249
Jaden
Road-hole
I had started to repond to him then just stopped...
June 24 at 12:36pm
I had started to respond as to why but then stopped. It has to do with the double fulcrum that two axle vehicles have.
Think of it as two sideways L's where the long part of the L represents the frame of the car and the little part of the L representing a line going to the ground at the axle line.
The front rear bias will be based on a division of where the balance of the weight resides on the length of each L, so shifting backward a balance point on the two L's can have a significant effect on the F/R bias because it affects both the fulcrums balance points, not just one.
Jaden
Jaden is offline
The Following User Says Thank You to Jaden For This Useful Post:
CxG (10-26-2015)
Old 06-26-2015, 12:54 PM   #250
Floggin Tires
Correct
ZC6-CBS, is home
Old 06-26-2015, 01:13 PM   #251
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I dont really care where the COG is, im just happy its well under 3000lbs. a good suspension system will help alleviate any under steer from front weight bias.
cdrazic93 is offline
The Following User Says Thank You to cdrazic93 For This Useful Post:
cf6mech (06-27-2015)
Old 06-26-2015, 02:05 PM   #252
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
And honestly, if you're understeering, just give it a boot-full of throttle and oversteer it out
Parting out HERE
civicdrivr is offline
The Following 3 Users Say Thank You to civicdrivr For This Useful Post:
cdrazic93 (06-26-2015), cf6mech (06-27-2015), kch (06-26-2015)
FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates Steeze_Its Brakes, Suspension, Chassis 7 06-27-2014 10:32 PM
FS: Vorshlag Front Camber Plates h4nh Brakes, Suspension, Chassis 1 03-01-2014 11:49 PM
FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) serial gixxer Brakes, Suspension, Chassis 18 05-20-2013 09:51 PM
WTB: Front Vorshlag Camber Plates YDNA Brakes, Suspension, Chassis 0 05-03-2013 06:31 PM
Maybe a repost, but have you seen the Vorshlag project car? Bart1 BRZ First-Gen (2012+) — General Topics 3 01-07-2013 02:19 PM
