| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
The Fail Boat
Drives: CWP S.B.
Oh & another thing is.......Turn off traction control if u want. The car is smooth as butter with everything off. Lots time u bog down cuz traction control locking the tires @ beginning. xD
Try it & u will see a big difference. |
#16 |
Drives: 15' CWP Limited
First thing I did in my 2015 was adjusting the clutch pedal so it sits a tiny bit below the brake pedal. It'll make things easier because in my opinion, the clutch travel in the BRZ is way too long in stock form.
The second thing I would do is go to an empty parking lot and just practice your 1-2 shift at various RPMs to figure out what works best for you. Once you have it down and you're aware of how to let the clutch out for a smooth shift muscle memory will eventually come into play and you'll laugh at the fact that you had issues shifting. Congrats on the new BRZ! |
#17 |
the clutch delay valve affects shifting that way? I thought it only affected the RPM's when you're in lower RPM than you are supposed to be and when you let out the clutch, it slowly raises the RPM to the correct amount instead of instantly jumping up and bogging the car
#18 | |
Drive From Home
Drives: BRZ STI Performance
The clutch pedal feel on this car absolutely sucks cuz of the helper spring I can tell you that much lol! |
#19 | |
maybe I was just spoiled with my older MR2 that has no assists at all
#20 |
Drives: 2015 Series.Blue
FYI: There's been no proof there's a clutch delay valve, only speculation. It hasn't been found as nobody wants to do a full teardown of the components.
#21 |
Drives: 2015 BRZ Limited 6MT
This car is super easy to shift smooth. If you have trouble you just need more practice. Don't hamfist the stick. Just guide it into gear.
I'm puzzled how anyone who is experienced on a stick could stall this car out.
2015 BRZ , 1992 SVX LSL, 2019 ASCENT
#22 |
Drives: 6MT '15 BRZ | '89 240sx (sold...)
Well did some more aimless driving around after work and after reading most of the things in this thread my shifting seems to be a bit smoother now. Definitely experienced a reduction in car lurches. Though to be fair there are times where I can't tell if the shaking is being caused by my driving or typical shitty LA roads lol.
The shift indicator thing that Sosa mentioned really helped as a starting point. That said, I can't really afford to keep looking at the tach so I've been trying to play it by ear.
la cocaina is not good for you ig: sad_fa20 |
#23 |
My last car had awesome clutch feel.. and I really didn't like this one on the test drive. Felt great after a few days though.
I only get jerking when I'm "unsure" with the gas pedal. If you slightly back off and then back on when engaging, you'll lurch. |
#24 | |
[||]--(86)--[||]
Drives: 2015 Firestorm FR-S
![]() I believe the break in period (for the transmission) is going to be a big factor. The FR-S I test drove was well broken in and I had very smooth shifts (especially in lower gears). I just need to deal with the over protective new car phase lol.
[||•]==(86)==[•||]
#25 | |
Drives: '13 BRZ SWP 6MT
#26 | |
I know that feel. I want to experiment with a lot more stuff but I'm just waiting til I hit 1,000 on the odo. If it helps any, I asked my cousin how he got used to rev matching and he told me that he'd practice it on curvy freeway exits late at night lol. Probably not the safest way to learn but it worked out pretty well for him.
#27 |
Drives: Ford Escape to BRZ
Normally I don't promote my own threads but it may help you out, I also talk about some strange sounds and such:
http://www.ft86club.com/forums/showthread.php?t=88854 It took me a full tank to be able to drive super smoothly, all I can say is practice. Go LIGHT on the gas when shifting, i practically lay my foot on the pedal and it's enough to shift smoothly, first to second is pretty rough, if I shift quickly, I normally get first to second smoothly. |
#28 | |
Great thread, solid info! |
| *Groupbuy: Invidia N1 and Q300 Cat-Back Exhausts (SS tips, T.I. tips) -fteightysix* | 86SPEED | Groupbuys | 74 | 11-09-2016 01:45 PM |
| WTB: JDM exhaust tips or perrin tips | calvinck | Canada Classifieds | 0 | 06-01-2014 11:17 PM |
| Manual Transmission troubles (tips are welcomed) | Janunez90 | Issues | Warranty | Recalls / TSB | 14 | 08-07-2013 03:02 PM |
| TRADE: my Silver GT Manual (October Delivery) for Pegasus White GT Manual -AUSTRALIA | ysagisan | Cars for Sale/Trade | 0 | 09-19-2012 11:24 AM |
| SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado | huma | BRZ First-Gen (2012+) — General Topics | 15 | 06-14-2012 11:33 AM |
