#463 | |
Drives: FT86
The only difference between the 91/93 tunes is about 1.5 degrees extra ignition timing over 6000 rpm. see above post from @Phantobe |
#464 |
Drives: Toyota 86 GTS
This is the best I can do with MAF scaling OL.
http://datazap.me/u/wayne/v55-4-3rd-...6452-6460-6472 Still rich on tip-in for a second and a half and between 7200 to 7400 ignition cut. It will go about 0.2 leaner when IAT is heat-soaked on the dyno with bonnet closed. |
#465 |
Drives: 86
ok so bad engine
JAJ01A ROM http://www.datazap.me/u/aagunss/log-...0?log=0&data=2 http://www.datazap.me/u/aagunss/log-...8?log=0&data=2 JA700J OLD ROM http://www.datazap.me/u/aagunss/log-...6?log=0&data=2 http://www.datazap.me/u/aagunss/log-...4?log=0&data=2 http://www.datazap.me/u/aagunss/log-...2?log=0&data=2 http://www.datazap.me/u/aagunss/log-...4?log=0&data=2 http://www.datazap.me/u/aagunss/log-...1?log=0&data=2 http://www.datazap.me/u/aagunss/log-...1?log=1&data=2 http://www.datazap.me/u/aagunss/log-...1?log=0&data=2 FAST MS JA01J ROM http://www.datazap.me/u/aagunss/log-...9?log=0&data=2 http://www.datazap.me/u/aagunss/log-...9?log=1&data=2 LTFT IS HIGH 24% - 30% = 8% OF AEM FIC + 16% - 22% DI FAILURE old rom 4/2012 - 3/2013 JA700J kill DI resistors / coils Last edited by aagun; 06-01-2015 at 09:24 AM. |
#466 |
Just picked up my OFT the other day and flashed the Stg 1 V2.XX 93 tune. Here are two quick data logs that I was hoping you guys ( @steve99 @wparsons ) could take a peak at to make sure its all safe. I am running 94 which has an E content of up to 10%
First log was just some in town driving between a few sets of lights. http://datazap.me/u/dthissen/log-143...4?log=0&data=1 Second log, was 3rd gear getting on to the highway. Unfortunately I caught up to some traffic so I could not go completely WOT and why you might see a longer duration at the 5000RPM range. http://datazap.me/u/dthissen/log-143...4?log=1&data=1 Sorry if I logged the wrong info, still learning this whole process.
| The Following User Says Thank You to D_Thissen For This Useful Post: | wparsons (06-12-2015) |
#467 | |
Drives: FT86
no knock iam 1 long term fuel fuel trims max 2% afr looks fine |
| The Following User Says Thank You to steve99 For This Useful Post: | D_Thissen (06-11-2015) |
#468 |
Thank you sir. That's what I thought too, but it's always good to get a 2nd opinion lol.
#469 |
@steve99 here is another if you don't mind. I noticed my LTFT are a bit lower now. http://datazap.me/u/dthissen/log-143...0&data=1-2-3-6
#470 | |
Drives: FT86
#471 | |
#472 |
#FiftyShadesOfBlue
Drives: 2015 FR-S
would someone mind taking a look at a log for me. Just switched over to corn juice for the summer and would like to make sure everything is running ok
![]() http://www.datazap.me/u/tectoniic/lo...9?log=0&data=1
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes ![]() |
#473 | |
Drives: FT86
knock ok running richer than commanded afr but oft tunes do that normal for oft tune on E85 your IAM is not monitoring correctly, make sure you have updated tablet and running ofm V20 and template 7.2 |
#474 | |
#FiftyShadesOfBlue
Drives: 2015 FR-S
Thank you very much for continuing to help!!
#475 |
Drives: 14 Ultramarine FR-S
@steve99 or anyone
![]() Can you check these out? I know I'm getting a bit of knock I'm working on editing the timing, currently going onto rev3. But I seem to be getting some weird jumps in AFR & ST Fuel Trims. I'm running Stg1 91 Tune, just swapped back to oem exhaust manifold. LTFT seems to be pretty stable. Open loop AFR seems to be a bit lean, I was used to seeing like low 12s now I'm seeing high 12s even low to mid 13s. Also when I'm coming to a stop @ idle I see the AFR jump down to like 13.5 then jump up to 16, seems to be acting weird I don't recall this while on stg2. http://datazap.me/u/phantobe/stg1pul...log=0&data=1-5 3rd Gear Pull http://datazap.me/u/phantobe/stg1kre...0&data=1-5-6-7 Drive Home
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
#476 | |
Drives: FT86
When your rolling downhill or to a stop the momentum of car is used to turn engine over and the ecu shuts off fueling to save fuel so you will see afr go to high values like 20. Looks like you still have some knock arroind 3000 to 3400 loads 0.8 to 1.1 , probavly what knocking your iam down. and some 4800-5200 loads around 1 |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
