Old 06-22-2015, 08:28 PM   #2325
willharp360
Originally Posted by Brody602 View Post
Is it the connection at your midpipe thats not fitting or on the other side of the over pipe?
It's the other side of the overpipe that's not connecting
willharp360 is offline   Reply With Quote
Old 06-22-2015, 08:33 PM   #2326
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Ahh okay, didn't much in the pics, thought it was from the over pipe back. I know my setup is 3" turbo back so it wouldn't have been an issue.
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 06-22-2015, 09:25 PM   #2327
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Disconect the overpipe from the front pipe. Install overpipe to header, then attacher the front pipe/catback.
Old 06-22-2015, 10:50 PM   #2328
willharp360
Thanks we'll give that a shot tomorrow
Old 06-23-2015, 08:17 AM   #2329
Jhood
Jhood's Avatar
Drives: 2014 BRZ Limited [6MT/SWP]
Currently having problems connecting the stock overpipe, anybody have problems similar to this?
Yup pretty much looks the same, that stock over pipe should bolt right up no problem, but mine also does not, putting stress on the turbo and exhaust
|FBM Stage 1 Build|GTX2867R|
|Moto-East Flex Fuel & Dyno Tune|
|360whp / 265tq (E81 @ 12psi)|
Jhood is offline   Reply With Quote
Old 06-23-2015, 10:09 AM   #2330
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Is that a 4 bolt downpipe or a V band downpipe? Can you rotate it? I agree that you should connect everything from the front going backwards in order.
Old 06-23-2015, 04:01 PM   #2331
69Marshall69
69Marshall69's Avatar
Drives: 2013 Subaru BRZ-S
Thanks King Tut for the explanation, makes total sense haha just wanted to make sure of myself when i install my tru-boost!
69Marshall69 is offline   Reply With Quote
Old 06-24-2015, 09:51 PM   #2332
grant
Drives: too many to list
I had the same problem with my DP, I had a local fab shop cut off the last section weld it up correctly, I have Full Blowns 3" turbo back so I had him weld in a 3" flange instead of the reducer it came with, I agree that Full Blown customer service was great
grant is offline   Reply With Quote
Old 06-28-2015, 04:05 PM   #2333
willharp360
Does anyone run the GT86 headlights with this kit? The back of the headlight is pinching the silicone hose real bad
Old 07-03-2015, 05:26 PM   #2334
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
im currently installing my turbo kit FBM Base. can anyone take picture of the vacuum lines that needs to be cut off and reconnected using the fittings provided by fb?
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 07-05-2015, 11:45 AM   #2335
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
@Mikeez @Ironsquid @Reaper @Travisty75 @Kiske @King Tut @Infamous Performance
I wanted to thank everyone who graciously was trying to help me out with my water in intake problem many posts ago.
My car has been all better for a while now. She's seen some road course sessions and some autocross sessions this season and is running strong.
The steps I took to remedy the situation were:
1. Converting the PCV crankcase catch can to vent to atmosphere.
2. Laying down a thin piece of vinyl material underneath the black, metal bracket at the front of the engine bay.
3. Placing a piece of window weather stripping to reinforce the seal between the hood and front bumper.
After all the discussion, I still believe that the water was coming from a bad seal at the hood/front bumper. The water was running down the holes where the black bracket was mounted onto the air filter where it was sucked into the system. I did a lot of testing and that seal would consistently leave large puddles of water along that area after rains or car washes. The black metal bar is actually already starting to develop some rust around the screw holes.
The vinyl layer I placed made it so water that did leak past the seal couldn't get through the holes where the rivets lay. The weather stripping made the seal at the hood/bumper much more rigid which helped stop any water from entering there.
For safety and piece of mind, I also vented my crank case catch can in case this was causing the issue all along.
I really would be interested to see if anyone else has issues with water entering the engine bay through that seal. I'm willing to bet we see this happen again in the future.
Either way, i'm happy I've got it figured out. Thanks again to all that have provided brain power to helping me solve my problem!
blackfireball5 is offline   Reply With Quote
The Following 3 Users Say Thank You to blackfireball5 For This Useful Post:
Infamous Performance (07-06-2015), Lonewolf (07-05-2015), Travisty75 (07-05-2015)
Old 07-05-2015, 03:57 PM   #2336
mashal
DADA
mashal's Avatar
Drives: 2013
Got any pictures of how you did the seal?
mashal is offline   Reply With Quote
Old 07-06-2015, 09:26 AM   #2337
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I am pretty sure that the way they intend you to hook them up is to install the T/manifold into the brake booster hose that comes off the back of the manifold and then run that over to the passenger side where you install another T with one side going to the BOV and the other side going to the wastegate.
Old 07-06-2015, 09:28 AM   #2338
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Interesting. I still don't see how that much water would get past a properly oiled K&N filter unless the filter was sitting in the water. Pics would be great.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
