#2325 |
#2326 |
Drift King
Drives: '13 Firestorm FR-S 6MT
Ahh okay, didn't much in the pics, thought it was from the over pipe back. I know my setup is 3" turbo back so it wouldn't have been an issue. Sent from my iPhone using Tapatalk
'13 6MT Firestorm FR-S
#2327 |
Drives: RX-7 / BRZ
Disconect the overpipe from the front pipe. Install overpipe to header, then attacher the front pipe/catback.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#2328 |
#2329 |
Drives: 2014 BRZ Limited [6MT/SWP]
Yup pretty much looks the same, that stock over pipe should bolt right up no problem, but mine also does not, putting stress on the turbo and exhaust
#2330 |
NASA SpecE30 Racer
Is that a 4 bolt downpipe or a V band downpipe? Can you rotate it? I agree that you should connect everything from the front going backwards in order.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#2331 |
Drives: 2013 Subaru BRZ-S
Thanks King Tut for the explanation, makes total sense haha just wanted to make sure of myself when i install my tru-boost!
#2332 |
Drives: too many to list
I had the same problem with my DP, I had a local fab shop cut off the last section weld it up correctly, I have Full Blowns 3" turbo back so I had him weld in a 3" flange instead of the reducer it came with, I agree that Full Blown customer service was great
#2333 |
Does anyone run the GT86 headlights with this kit? The back of the headlight is pinching the silicone hose real bad
#2334 |
Turbo E85
Drives: 13 wrb brz
im currently installing my turbo kit FBM Base. can anyone take picture of the vacuum lines that needs to be cut off and reconnected using the fittings provided by fb?
Flex Fuel Turbo BRZ
#2335 |
Drives: Scion FRS Firestorm
@Mikeez @Ironsquid @Reaper @Travisty75 @Kiske @King Tut @Infamous Performance
I wanted to thank everyone who graciously was trying to help me out with my water in intake problem many posts ago. My car has been all better for a while now. She's seen some road course sessions and some autocross sessions this season and is running strong. The steps I took to remedy the situation were: 1. Converting the PCV crankcase catch can to vent to atmosphere. 2. Laying down a thin piece of vinyl material underneath the black, metal bracket at the front of the engine bay. 3. Placing a piece of window weather stripping to reinforce the seal between the hood and front bumper. After all the discussion, I still believe that the water was coming from a bad seal at the hood/front bumper. The water was running down the holes where the black bracket was mounted onto the air filter where it was sucked into the system. I did a lot of testing and that seal would consistently leave large puddles of water along that area after rains or car washes. The black metal bar is actually already starting to develop some rust around the screw holes. The vinyl layer I placed made it so water that did leak past the seal couldn't get through the holes where the rivets lay. The weather stripping made the seal at the hood/bumper much more rigid which helped stop any water from entering there. For safety and piece of mind, I also vented my crank case catch can in case this was causing the issue all along. I really would be interested to see if anyone else has issues with water entering the engine bay through that seal. I'm willing to bet we see this happen again in the future. Either way, i'm happy I've got it figured out. Thanks again to all that have provided brain power to helping me solve my problem! |
| The Following 3 Users Say Thank You to blackfireball5 For This Useful Post: |
#2336 |
DADA
Drives: 2013
Got any pictures of how you did the seal?
#2337 |
NASA SpecE30 Racer
I am pretty sure that the way they intend you to hook them up is to install the T/manifold into the brake booster hose that comes off the back of the manifold and then run that over to the passenger side where you install another T with one side going to the BOV and the other side going to the wastegate.
- King Tut
#2338 | |
NASA SpecE30 Racer
- King Tut
| Tags |
| best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo |
| AVO Turbo Kit Owners Topic | Sportsguy83 | Forced Induction | 1935 | 02-20-2023 10:46 AM |
| Full Blown FRS/BRZ Stage 1 Turbo Kit | FullBlown | Forced Induction | 456 | 09-27-2021 03:10 AM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
| Full Blown Turbo Kit! | Unleashed | Engine, Exhaust, Bolt-Ons | 70 | 10-09-2013 09:46 AM |
| WTB: Full Blown turbo kit (used) | whitefrs | Engine, Exhaust, Bolt-Ons | 12 | 03-29-2013 09:15 PM |
