Old 06-22-2015, 02:46 AM   #1
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
SPOON rigid collars install
SPOON Rigid Collars
I'm gonna try my best to explain the differences after installing the rigid collars. For those of you not aware of this product, YouTube has a great video of a Prius installed with the collars and that video explains it way better than I ever can so please reference it here: [ame="https://www.youtube.com/watch?v=zWyUD6UXfog"]Rigid Collar - Spoon Sports Europe - English Version - YouTube[/ame]
Ok onto the differences. I'll start in the order of most significant to small. The biggest difference is the lack of vibration. Before the install, there were lots of unwanted small, high frequency vibrations in the chassis, even on relatively smooth flat roads. I believe it was probably due to the fact that the area where the chassis and the front crossmember touches is not flat. I like how one of my friends put it; it feels more like a BMW, in a sense that jarring vibrations are non existent.
Second biggest thing I've noticed is vertical movement of the car, or rather, lack of it. Before the collars were installed, when the car drove through a dip or a bump, it would try and absorb the impact, but would take a bit of time to recover. Simply put, it used to be a "boing boing boing" vs "boing". The car stays a lot more planted and recovers in a lot less time now. It's as if I installed higher end dampers on the car (can't wait to actually do so in conjunction with these collars). It almost feels like I have shorter/stiffer springs without the unwanted harshness.
Another difference is how much better the steering stays on-center. It's almost weird how little corrections I make driving the car. After getting wider wheels and tires, the car would tug along the expansion joints or undulating surfaces (especially under braking), but the car drives through them without even feeling like they're there now. Sometimes the freeways here in California have two different types of Tarmac laid, and half of my car would be on one and other side on the other, making it extremely difficult to drive the car straight, but the "tugging" effect is very minimized, if not completely gone.
Now, I do think cars already equipped with high end suspension may not feel it as much (due to good dampening), but it was a very good learning experience on my part that. I thought I would gain more NVH due to a more solid connection to the chassis, but it in fact worked the other way around. If this theory stays true my solid rear bushings for the rear subframe (http://www.ft86club.com/forums/showt...t=61522&page=2) will also have a very positive effect. Can't wait to install those!
here is one of the holes on the chassis; notice how misaligned it was!
mokinbird87 is offline   Reply With Quote
The Following 7 Users Say Thank You to mokinbird87 For This Useful Post:
chaoskaze (06-22-2015), DieselDog (07-10-2015), DustinS (11-02-2015), GT86_PRAGUE (06-22-2015), Joe-G (06-22-2015), Mark@S (06-23-2015), NLSP (06-22-2015)
Old 06-22-2015, 03:21 AM   #2
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
Good to know the high price tag has some merit. Will add this to my mod list.
Did you get the rigid collar kit for the rear as well? Or would it have not worked in conjunction with the sub-frame inserts you purchased? (I'm planning to get the Whiteline rear sub-frame inserts)
Old 06-22-2015, 03:30 AM   #3
ryoma
ryoma's Avatar
so where exactly does this mount to, the sub frame? this might be a dumb question, but how exactly do these inserts improve overall dampening of the struts? is it because it's using the chassis flex as a way to absorb extra energy? though, even without the inserts, I believe the chassis would flex the same way with properly torqued bolts. I watched the video but it hasn't really explained anything except for the fact that the inserts are supposed to fill in extra space between two surfaces. I'm assuming if everything is torqued correctly, there shouldn't be any movement between the two surfaces in the first place.
Old 06-22-2015, 10:10 AM   #4
mokinbird87
BOXER FR
I was under the impression that it wouldn't work with the revolution garage subframe bushings.
The Following User Says Thank You to mokinbird87 For This Useful Post:
Mark@S (06-23-2015)
Old 06-22-2015, 10:22 AM   #5
mokinbird87
BOXER FR
It's not improving the dampening but it feels that way. You can torque down the crossmember bolts all you want but since the area where the chassis and the crossmember touches is not 100% smooth and flat (and they are stiff materials) you will have small movements. Having said that it's more of a feel good mod vs I spent $200 how many seconds have I shaved at the track, but the way my car feels now I would never go back. But again I do think that it will shave lap times though because the front end takes less time to recover from bouncing around and no road in this world is perfectly flat.
Old 06-22-2015, 11:14 AM   #6
CSG Mike
CSG Mike's Avatar
This.
86 South Africa (01-03-2016)
Old 06-22-2015, 12:29 PM   #7
8R6
8R6's Avatar
Drives: FRS
interesting. im gonna have to look into getting this soon too. thanks for sharing!
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
mokinbird87 (06-22-2015)
Old 06-22-2015, 02:56 PM   #8
ryoma
ryoma's Avatar
where did you buy your set from, and I'm assuming it's front and rear? is an alignment necessary after reinstalling the subframe?
Old 06-22-2015, 03:29 PM   #9
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
This.
You just like them cuz its Spoon. #hondafanboi
Old 06-22-2015, 03:33 PM   #10
crash
Drives: 2013 SWP BRZ
How does this differ from the subframe bushing inserts (positive traction kit) from Whiteline?
crash is offline   Reply With Quote
Old 06-22-2015, 04:03 PM   #11
mokinbird87
BOXER FR
PROVA makes them for our cars. front and rear. I didn't buy the rears as I have something else going on the car for the rear. alignment is required after the install.
Old 06-22-2015, 04:04 PM   #12
mokinbird87
BOXER FR
whiteline stuff will help tremendously but mostly in the vertical movement of things. Rigid collars also prevent lateral movement of the subframe/crossmember.
GT86_PRAGUE (06-23-2015)
Old 06-22-2015, 04:14 PM   #13
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Vendor?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 06-22-2015, 04:27 PM   #14
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
Http://Rigidcollar.com
Sleepless is offline   Reply With Quote
Spoon GT86? c147258 Scion FR-S / Toyota 86 GT86 General Forum 67 04-27-2016 12:31 AM
No Spoon parts for the 86... twincamRob FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 81 06-02-2015 10:37 AM
Fs: brand new pbm subframe collars Guildjs Brakes, Suspension, Chassis 3 10-16-2014 08:54 AM
T1R Differential Collars Mikepage Engine, Exhaust, Transmission 0 05-01-2014 09:18 PM
