Old 06-21-2015, 10:19 PM   #1
XoticBeast
XoticBeast is offline   Reply With Quote
Old 06-21-2015, 10:26 PM   #2
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Have you installed a short throw shifter recently? Try putting the car in neutral then lifting up on the center lever/hub/thing and putting into reverse.
Bobblehead is offline   Reply With Quote
The Following User Says Thank You to Bobblehead For This Useful Post:
XoticBeast (06-21-2015)
Old 06-21-2015, 10:33 PM   #3
XoticBeast
Old 06-21-2015, 11:00 PM   #4
Bobblehead
Bobblehead's Avatar
Originally Posted by XoticBeast View Post
No I haven't installed a short shifter. I tried that, it goes into reverse... But my concern is the lock doesn't work. Going from gear one to reverse with out using that lever.
On a normal FRS it would not allow you to get into reverse with out lifting that lever.
Oh, I see. If you're still under warranty, I'd take it to the dealer. That's not something I have much experience or knowledge about.
Old 06-22-2015, 04:23 AM   #5
My 2014 Manual Transmission FRS will not lock from 1st gear to reverse! Making the lever that you pull up to get into reverse (under the shift knob) useless.
I presume this is the same car that has been sitting for a year .... ??
If so, I'd suggest you get the transmission good and warmed up ..... then give the mechanism a good workout.
If that doesn't work, you may have to get into the transmission turret and lub it up.
XoticBeast (06-24-2015)
Old 06-23-2015, 03:56 AM   #6
Sosa
[||]--(86)--[||]
Sosa's Avatar
Drives: 2015 Firestorm FR-S
Sounds frightening! I remember reading that the position of the lockout is precise (for those installing short throws). It may be worth checking out, although I would sooner go to the dealer (warranty?) as pulling apart the console sounds tedious for diagnostics.
[||•]==(86)==[•||]
Sosa is offline   Reply With Quote
The Following User Says Thank You to Sosa For This Useful Post:
Old 06-24-2015, 11:10 PM   #7
Caspeed
Caspeed's Avatar
Drives: FRS-RS1, Triumph Speed Triple, Lola
Excercise the lock out collar 20-30 times if the car has been sitting for that long. The reverse lock out collar may be binding. So pull it up all the way then push it down all the way. See if that helps. Have you changed the shift knob? That could also cause an issue. There is an adjustment for the reverse lockout under the shift boot. It sounds like you might be best off taking it to the dealer.
Caspeed is offline   Reply With Quote
The Following User Says Thank You to Caspeed For This Useful Post:
XoticBeast (06-26-2015)
Old 06-26-2015, 02:46 AM   #8
XoticBeast
Old 06-30-2015, 02:51 AM   #9
norcalpb
norcalpb's Avatar
You might need to adjust the lockout
http://www.ft86club.com/forums/showthread.php?p=1138158
The Following User Says Thank You to norcalpb For This Useful Post:
XoticBeast (09-26-2015)
Perrin WRX STI reverse lock out..NEW no box BRZeer Miscellaneous 2 12-18-2014 03:43 PM
Reverse lock out adjustment nfaj Engine, Exhaust, Transmission 10 10-03-2014 10:46 AM
Perrin Reverse Lock BRZ615 Interior Parts (Incl. Lighting) 3 08-07-2014 02:02 AM
Reverse lock out diameter? Moddiction BRZ First-Gen (2012+) — General Topics 6 09-01-2012 12:04 PM
