Old 09-12-2014, 05:50 PM   #43
Corner3garage
Corner3garage's Avatar
Drives: FR-S & BRZ
Man these wheels have a nice touch to them! We have 1 last set of Gun Blue, If anyone is interested!
Corner3garage is offline   Reply With Quote
Old 09-13-2014, 03:32 AM   #44
Steege
Steege's Avatar
Drives: 2013 BRZ Limited
Ugh, if the Weds weren't so much lighter, these would be my first choice! So nice looking!
Steege is offline   Reply With Quote
Old 09-14-2014, 01:13 PM   #45
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
How much do these weigh? and vs the 18x9.5s?
Old 09-14-2014, 02:34 PM   #46
BAMF86
much slow
BAMF86's Avatar
Drives: 13 Raven FRS, 05 Rio Yellow S2000
The 18x9.5s are 21.5 lbs, I'm guessing these are around 19-20 lbs
BAMF86 is offline   Reply With Quote
The Following User Says Thank You to BAMF86 For This Useful Post:
BlaineWasHere (09-14-2014)
Old 01-06-2015, 08:01 PM   #47
Alextouring
Drives: 2013 frs
So no clearance issues? Do you know if you can fit a bbk? Seems perfect to settle the +45 +35 debate I'm having with myself.
Alextouring is offline   Reply With Quote
Old 06-19-2015, 12:23 AM   #48
BlaineWasHere
Grip>Drift
Drives: FRS
Does anyone know any retailers I can find 17x9s at?
Old 06-19-2015, 01:18 AM   #49
BAMF86
much slow
BAMF86's Avatar
I got mine from MengMotorsports, Speedelement should be able to order them as well. They're both local
BlaineWasHere (06-19-2015)
Old 07-28-2015, 03:03 AM   #50
Higher Being
Drives: 2014 Asphalt Grey FRS
What tire size are most of you guys running? I just picked up a set and im considering a 225/235. Yes it will be a little stretched but I think it would look the best. Suggestions or experience on the matter? pics of a non 245 set up?
Higher Being is offline   Reply With Quote
Old 07-28-2015, 10:53 AM   #51
BlaineWasHere
Grip>Drift
Drives: FRS
Why don't you want 245/40/17. That's the best size for 17x9 on this car IMO.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
BAMF86 (07-28-2015)
Old 07-28-2015, 01:35 PM   #52
BAMF86
much slow
BAMF86's Avatar
Agreed with Blaine, 245/40 is probably the most functional setup without being too stretched. Although 255 is perfect fitment for this wheel, its a little too much rubber for how much power this car puts out. Go for 255/40 if you like the meaty look
The Following 2 Users Say Thank You to BAMF86 For This Useful Post:
hasanaltan (10-11-2015), mgarcia707 (01-17-2020)
Old 07-29-2015, 01:14 AM   #53
Higher Being
Like I said I like the medium stretched tire look. 245 is just a little too meaty for what i want currently. Was hoping for someone who has pictures of our car with 235/40 and or lower size just to see what it would look like. Ive found a few pics of 235/40 on s2000's but nothing for our cars. Im simply interested in exploring options a little.
Most likely will end up with 235/40
Old 10-11-2015, 06:53 AM   #54
86ish
Drives: 2016 Scion FRS
What are you lowered on, and if you could share the camber specs? I just like the way your car sits on those 17 extremes
86ish is offline   Reply With Quote
The Following User Says Thank You to 86ish For This Useful Post:
BAMF86 (10-11-2015)
Old 10-11-2015, 06:53 PM   #55
BAMF86
much slow
BAMF86's Avatar
RCE tarmac 0, -3 camber front -2 rear. Thats more of a track alignment, might be too aggressive for a street car
Old 10-11-2015, 10:02 PM   #56
86ish
Did you have any rubbing issue with 255's? I was thinking of getting Eibach Sportlines and the same wheels and tire specs like yours. Could you post more pictures of your car?
Wheel Directory: Gram Lights 57DR 17x9.0 +38 mr. slim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 179 12-07-2021 07:07 PM
Wheel Directory: Gram Lights 57Xtremes 18x8.5 +45/18x9.5 +40 WorkoArt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 02-18-2017 06:46 PM
Wheel Directory: Gram Lights 57Getter 19x8.5 +35 adprokid Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 08-20-2015 11:44 AM
Wheel Directory: Gram Lights 57Xtreme 19x9.5 +43 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 12-04-2014 10:56 PM
Wheel Directory: Gram Lights 57Xtreme 19x8.5 +43 / 19x9.5 +45 86 FRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 05-19-2014 12:28 AM
