Old 06-18-2015, 10:05 AM   #1
Aegis3425
Drives: 2013 Asphalt FRS
Catless header exhaust smell?
Hello everyone,
I'm currently running a berm technology high flow cat front pipe and was wondering how bad the exhaust smell would get if I decide to go with a catless header set up. I would love to make it louder and gain as much hp as possible but would preferably like to avoid the fumes. Any suggestions?
Aegis3425 is offline   Reply With Quote
Old 06-18-2015, 10:38 AM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I, too, would be a little interested in this
MS, CSCS, TSAC-F, CPT
Old 06-18-2015, 10:42 AM   #3
STV3
Señor Member
STV3's Avatar
are you worried about in cabin smell? or people behind you? Because if there are no exhaust leaks then you shouldnt smell anything in the car
STV3 is offline   Reply With Quote
Old 06-18-2015, 10:43 AM   #4
UnOvertime
UnOvertime's Avatar
Drives: Firestorm FR-S AT
It's not bad, but there is definitely a smell. If any increase will bother you then you are stuck getting a catted header.
I run the JDL UEL and the catted front pipe and I can notice it. I love the sound it makes and the trade off was well worth it for me, but if you are looking for no smell then stick with the catted setup.
UnOvertime is offline   Reply With Quote
Old 06-18-2015, 10:52 AM   #5
STV3
Señor Member
STV3's Avatar
Really? I am running a straight pipe on my other car and the dump tube on my wastegate exits right under the pass side of my car. Never smell anything while I am in the cabin.
Old 06-18-2015, 01:54 PM   #6
FirestormFRS
The only time you'll smell the odor is when backing up normally and yes it is eye watering strong if you smell it long enough.
FirestormFRS is offline   Reply With Quote
The Following User Says Thank You to FirestormFRS For This Useful Post:
STV3 (06-18-2015)
Old 06-18-2015, 01:58 PM   #7
Aegis3425
Looks like I'll be going catted then. Ft86 and hks are the only ones making those right?
Old 06-18-2015, 02:24 PM   #8
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
JDL does as well.
JonAvalon is offline   Reply With Quote
Old 06-18-2015, 02:43 PM   #9
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
I don't smell anything with a JDL catless UEL, OP, and front pipe inside the car. Idle in a fairly enclosed area with the window down? Yeah, a little bit. It's not terrible though. Even people that have followed me have not smelled anything unless I go WOT.
2016 Camaro SS is offline   Reply With Quote
Old 06-18-2015, 02:52 PM   #10
kch
Senior Misanthrope
kch's Avatar
Same here. Catless JDL UEL with JDL catted FP. Don't notice any particular exhaust smell when I'm running on 93.
OP, you could always burn the corn juice if you're concerned. That stuff generally smells better
Old 06-18-2015, 03:05 PM   #11
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
i just recently went from a ark catless front pipe with my tomei uel to a perrin catted front pipe. no more smell.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 06-18-2015, 10:19 PM   #12
stevo585
Drives: White 2014 BRZ
I dont think the smell is bad at all especially on e85. I asked a coworker following me if he could smell the exhaust and he said no...
stevo585 is offline   Reply With Quote
Old 06-18-2015, 10:28 PM   #13
DJCarbine
Thupercharged
DJCarbine's Avatar
I have a revworks catless header with a motive catted front pipe, there is no real noticeable "catless" smell that I can tell.
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 06-19-2015, 01:56 PM   #14
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Please run at least one cat. I've been behind someone with a Nameless header and catless exhaust on a drive and it was disgusting. It was making my eyes burn and giving me a headache, I had to roll up my windows.
Originally Posted by humfrz
I'm old and lazy
akyp (06-20-2015)
Catless UEL Header - N1 Exhaust - OFT Stage 2 ripper Engine, Exhaust, Transmission 28 07-18-2017 06:01 PM
Any Stock Catback Exhaust Soundclips? w/ aftermarket header + op + catless fp fooddude Engine, Exhaust, Transmission 11 08-11-2016 06:18 PM
Anyone running 3" exhaust & catless header? RiskyTrousers Engine, Exhaust, Transmission 19 08-01-2013 09:09 AM
SRT header back exhaust catless w/ tip A serial gixxer Engine, Exhaust, Bolt-Ons 6 12-04-2012 11:00 PM
