Old 06-17-2015, 10:27 PM   #155
JB86'd
JB86'd's Avatar
Drives: JAWS
I remember reading about very close clearances on an Ace header and the possibility of it hitting something under hard driving..was that the 4-2-1 and has that been changed? Or is it just something to not worry about?
JB86'd is offline   Reply With Quote
Old 06-17-2015, 11:02 PM   #156
CSG Mike
CSG Mike's Avatar
We haven't had any issues. It's more of a disclaimer, since the header uses every bit of space that is available.
JB86'd (06-17-2015)
Old 06-18-2015, 02:17 AM   #157
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
Originally Posted by Valentino View Post
I've seen this before (I read the other ACE header post).
Probably you didn't understand what I want. But none of these dyno tests answers my question. They are all for the 4-2-1 but with different fuels and with different brand headers.
If what I'm asking is too much I'm sorry. ACE company can just ignore my post.
No problem folks, questions are good. They help us know what customers are really looking for. We'll always do our best to try and provide solutions.
In this case though, the CSG testing results seem to be more accurate. The car we tested with had a tune installed day before which may have obscured some data.
As far as the type C goes: This was originally designed for RHD customers on short notice.
This is why it has "slip" joints instead of seam welds. and the 20* converging angle is because we had to play around with the length of both the primaries and 2-1 merged collector to clear the cross member.
We had wedged a 4-2-1 into a Japan car for Suzuka and Tsukuba, but the car had other modifications which allowed it to fit.
This header was only designed with Japan, Australia and England in mind. The testing done on it has been limited to this point as we only have a few prototypes and we're still playing with 'em.
The 4-2-1 spent over 8months in development before we started production, type C is only up to about 3 weeks.
We haven't decided what to do with it yet, but when we do, we'd love to get feedback from the masses on what they think.
Anything else, don't hesitate to ask questions. They only help us improve!
AceHeader-MT is offline   Reply With Quote
Old 06-18-2015, 05:23 AM   #158
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
@AceHeader-MT
Could you please explain why the GT86/FR-S/BR-Z Stainless Steel Catless Front Pipe ( http://aceheader.com/index.php/gt86-...nt-pipe-detail ) goes from 63mm inlet to 76mm pipe to 63mm outlet? I would have thought that going back down in diameter would have led to a bit of restriction.
Old 06-18-2015, 03:08 PM   #159
CSG Mike
CSG Mike's Avatar
@AceHeader-MT
Expansion chamber to kill specific resonances
AceHeader-MT (06-19-2015), Captain Snooze (06-18-2015)
Old 06-24-2015, 08:12 AM   #160
AceHeader-MT
Drives: 2012 FR-S
[ATTACH][ATTACH][/ATTACH][/ATTACH]Hey everyone,
We are guilty of causing some confusion with our "type c" and some other new options. I hope this will clear them up:
ACE will be offering 2 separate options for the 4-2-1 headers.
Header Options
Option A: Seam welded 100% by hand
Option B: Slip joint welded 75% by hand 25% robotic. 20* converging angle
2-1 Merged collector options
350: Current 2-1 merged collector (LHD ONLY) 100% hand seam welded
250: LHD/RHD 75% hand 25% robotic seam welded. Location on 2-1 collection is closer to header to allow for RHD clearance
150: LHD/RHD 75% hand 25% robotic seam welded. 2-1 collection is very close to header make more high end power and less torque.
We are currently back ordered until August which is why we've come up with the slip joint sets which can be produced at a faster rate. It takes over 3 weeks per header with the system we have now.
Our website will be updated shortly. We're spending our time at the welding table these days and not on the non-essentials
*None of these headers will require an OP and will bolt up to any Frontpipe.
EDIT- I don't know how to delete photos, but the collectors are a 350 and 150
The Following 2 Users Say Thank You to AceHeader-MT For This Useful Post:
CSG Mike (06-24-2015), RobertPaulson (06-26-2015)
Old 06-24-2015, 11:04 AM   #161
D K
Stig's dark passenger
^^^^^ the 350 looks titanium....
D K is offline   Reply With Quote
The Following User Says Thank You to D K For This Useful Post:
Old 06-25-2015, 05:36 AM   #162
steve99
Drives: FT86
Opensource guys may wish to try these cam tables for ace header
other changes will be required to extract max benefit (ie fueling/ignition timing) but these cam tables should work better than the standard OFT EL Header tables for ACE header.
see "tune Tweaks" thread below
The Following 3 Users Say Thank You to steve99 For This Useful Post:
AceHeader-MT (06-25-2015), burdickjp (06-29-2015), Cop (11-25-2015)
Old 06-25-2015, 10:12 PM   #163
8686
8686's Avatar
Drives: 86
Do you have a picture of the 150: 2-1 and how this will help more high end power?
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 06-25-2015, 11:30 PM   #164
AceHeader-MT
Drives: 2012 FR-S
I've edited the upper post, the photo is of a 150 collector.
Here it is again
Old 06-26-2015, 12:00 AM   #165
Vroomin86
Drives: 2015 Fire
So effectively which is the best option if money wasn't a factor and staying NA
2015 FireStorm FRS
HT Auto / TRD / Toms / FA 500 / Valenti / SPC / OFT / Borla / Flossy / Vigilant Motorsports / To be continued...
Vroomin86 is offline   Reply With Quote
Old 06-26-2015, 04:55 AM   #166
CSG Mike
CSG Mike's Avatar
You want the combo we tested, which is the Type A with a 350 collector.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
AceHeader-MT (06-27-2015), chaoskaze (06-26-2015), Vroomin86 (06-26-2015)
Old 06-26-2015, 03:02 PM   #167
D K
Because unobtitanium
CSG Mike (06-26-2015)
Old 06-26-2015, 03:12 PM   #168
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
I wish we could use robotic welding in the industry I work ion. Except, we rarely make the same piece more than 10 times. Look how badass you could be
drewbot is offline   Reply With Quote
The Following 5 Users Say Thank You to drewbot For This Useful Post:
AceHeader-MT (06-27-2015), AlexBinJackson (06-26-2015), Cop (09-24-2015), CSG Mike (06-26-2015), DAEMANO (06-26-2015)
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
