Old 06-18-2015, 05:43 AM   #1
FRS Justin
Drives: 2013 Asphalt FRS
New Sleeves for the FA20
Hey everyone LA Sleeves has come out with a NEW sleeve design for the FA20. LA Sleeve told me they would take 50 PSI of boost no problem. Now I just have to figure how to keep the heads on at 50PSI....I love a challenge... More pics on my build thread "FT86PROJECT9S"
FRS Justin is offline   Reply With Quote
The Following 5 Users Say Thank You to FRS Justin For This Useful Post:
chaoskaze (06-19-2015), DAEMANO (06-19-2015), flippy (06-19-2015), GT86_PRAGUE (06-18-2015), jliongh (05-24-2018)
Old 06-18-2015, 08:45 AM   #2
GT86_PRAGUE
Drives: GT86
Shouldnt be there NSFW warning?
GT86_PRAGUE is offline   Reply With Quote
The Following User Says Thank You to GT86_PRAGUE For This Useful Post:
FRS Justin (06-18-2015)
Old 06-18-2015, 09:25 AM   #3
celek
Resident Gear Head
celek's Avatar
Nice to see another company supporting the platform. Honestly the stock sleeves are good to 750 WHP though.
I went with Darton for more displacement and a closed deck.
celek is offline   Reply With Quote
The Following 4 Users Say Thank You to celek For This Useful Post:
chaoskaze (06-19-2015), Freeman (06-18-2015), jliongh (05-24-2018), themadscientist (06-19-2015)
Old 06-18-2015, 10:43 AM   #4
FRS Justin
I was told by LA Sleeves that it would be no problem to punch it out to a 2.2 liter I believe that's 89mm. Outfront Motorsports is looking into building a closed deck version FA20 but they are in the R&D Stages of that now.
This is one of there EJ closed deck.
Your Darton's do look sic tho
The Following 6 Users Say Thank You to FRS Justin For This Useful Post:
celek (06-18-2015), DAEMANO (06-19-2015), GT86_PRAGUE (06-19-2015), jliongh (05-24-2018), R2RO (06-19-2015), themadscientist (06-19-2015)
Old 06-18-2015, 11:04 AM   #5
OkieSnuffBox
Drives: '23 BRZ Limited
Closed deck + O-ring the block ?
Old 06-18-2015, 11:15 AM   #6
FRS Justin
I'm more concerned with lifting a head. I have not seen anyone push more than 30 psi. It's uncharted territory on if the head studs will pull out of the block or stretch or break. The Dyno Day will be very stressful
Old 06-18-2015, 06:43 PM   #7
celek
Resident Gear Head
celek's Avatar
Forged Performance in Australia is waiting for some custom Head studs to stop lifting the head. I want to say like 13mm Diameter
The Following User Says Thank You to celek For This Useful Post:
FRS Justin (06-19-2015)
Old 06-18-2015, 08:08 PM   #8
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
While nice. Piston rings, rods, heads ... Etc. are the things that are going to go first.
-Jack Burton
The Following User Says Thank You to tahdizzle For This Useful Post:
Old 06-18-2015, 08:51 PM   #9
aagun
Drives: 86
think about oil pressure and wearied parts
aagun is offline   Reply With Quote
The Following User Says Thank You to aagun For This Useful Post:
Old 06-19-2015, 03:21 AM   #10
FRS Justin
On the street oil pressures are no problem' I only go a 1/4 mile at a time on the track so again oil pressure will be fine. I will leave it to Element Tuning to push the circuit track, they seam to have the oiling issues down to a science.
At first I thought about oiling issues but after calling in some of the pros we are confident it's not going to be a issue. We did do some clearance and oiling system mods, and I will report any issues thru my build page.
Old 06-19-2015, 03:22 AM   #11
FRS Justin
All upgraded check out my build page.
The Following User Says Thank You to FRS Justin For This Useful Post:
tahdizzle (06-19-2015)
Old 06-19-2015, 03:25 AM   #12
FRS Justin
KEEP ME IN THE LOOP!!! After I test this engine I will be Starting another build.
Old 06-19-2015, 03:34 PM   #13
aagun
Drives: 86
push the limit of fa20 . God bless you
Darton Sleeves for FA20 JP Engine, Exhaust, Transmission 23 10-09-2017 03:21 AM
FS: GC coilover sleeves Deadspool Canada Classifieds 0 02-22-2014 11:47 AM
Darton Sleeves BNIB RRBS Engine, Exhaust, Bolt-Ons 1 12-18-2013 12:44 PM
Carbon Fiber Laptop Sleeves - DFWcomposites DFWcomposites Miscellaneous 3 08-12-2013 03:42 AM
question about cylinder walls(sleeves) carbonBLUE Engine, Exhaust, Transmission 12 04-13-2012 07:21 PM
