Old 06-16-2015, 11:19 AM   #15
afohlin
Drives: 2013 BRZ Limited
Originally Posted by Slong View Post
Afolhin--I may get the Kicker as you did. Do you really like it? Does it help not just with bass but overall sound as well? I am sure it helps to 'even-out' the sound as more now comes from the rear? Thanks....
I was more than impressed with the factory Kicker. Easy and clean install, didn't need to do any wiring or buy a new amp, and it sounds awesome. It should come as a standard feature because it makes such a big difference in overall sound quality. I looked into the OEM+ system and the JL Stealthbox but after its all said and done those were almost double the price and to me it wasn't worth the extra $
afohlin is offline   Reply With Quote
Old 06-16-2015, 04:57 PM   #16
Slong
Drives: 2015 BRZ Premium
Thank you Afohlin!! One more question. I heard the Kicker sub has no bass control and can be too much. There is an $8 limiter I saw to purchase online--should I get that as well? What is your advice Afohlin? Thanks again!
Slong is offline   Reply With Quote
Old 06-17-2015, 03:40 PM   #17
afohlin
You're welcome! While there is no adjustment on the sub itself there is still adjustment through the equalizer in the head unit. The bass can be a loud when the volume is really low but I don't have the limiter so I can't speak to the difference it makes. For $8 it should be worth a try. You can always unplug the limiter if you don't like it.
Old 06-17-2015, 09:06 PM   #18
Slong
Cheers Afohlin!!!
The Following User Says Thank You to Slong For This Useful Post:
afohlin (06-22-2015)
Old 06-18-2015, 11:14 PM   #19
KevinBRZ
I have the factory Kicker subwoofer. The sub + wires weigh maybe 15 lbs, if you care about the weight, which is why I bought it.
I have noticed the sub sounds pretty good if you are mainly into hiphop. It's good for some electronic music, but some songs don't sound quite as good as I like. This is probably due to the fact that this is a 10" sub and some electronic music sounds better with a tighter 8" sub.
I noticed an overall clarity improvement of the factory setup since the front door speakers aren't trying to reproduce all the mids and lows. You will notice that the OEM+ audio guys said the same thing when they made their own sub. There is no rattling at the front anymore either with the sub. I also haven't noticed any trunk or body panel rattling on the outside of the car either.
Overall, this is probably the easiest sound upgrade you can do for this car. Yes, you can get a cheaper sub + box and some wire, but honestly, it won't be as clean of a setup as the factory Kicker, and I hate gaudy sub boxes taking up room in this truck. This is nicely tucked away in the corner, and leaves your trunk usable. You can also remove it in 30 seconds if you want to take it out.
The OEM+ setup is better, but it's also a lot more money. You probably won't regret getting the Kicker.
KevinBRZ is offline   Reply With Quote
Old 06-20-2015, 02:03 PM   #20
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Originally Posted by ericmpena View Post
I'd go with OEM Audio+. I kept looking in the "For Sale" thread on here and eventually found one for I believe $750. I got the "Reference 400CF" model. If you keep your eyes open you'll sometimes find people selling theirs for cheap. I'd go that route. Not to mention that the guys over at OEM Audio are amazing to work with.
Damnnn son
750 for Reference CF?? that's like less then half price!!! You lucky XXXXXXXXXx /rage
ALL JELLO
Old 06-21-2015, 11:49 PM   #21
Poodles
Drives: 2015 Series.Blue
I think the speakers took some time to break in as my stereo sounded terrible when I first bought it and now it's halfway decent. Still want an OEM+ system though...
Old 06-22-2015, 09:57 AM   #22
BlueSky
BlueSky's Avatar
Drives: 2015 Aozora BRZ
OEM reference ftw
BlueSky is offline   Reply With Quote
Old 06-22-2015, 03:26 PM   #23
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Fuck OEM+ I want this!
http://www.mitsubishielectric.co.jp/...atone/top.html
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
chaoskaze (06-30-2015)
Old 06-30-2015, 03:49 AM   #24
Speed2th
I love my series blue brz
Speed2th's Avatar
Drives: 2010 335d
more reviews for oem kicker? i just want a bit more bass. I think spending 1500 onto the stereo into this econo sports car is excessive, especially it came with loud road and engine noise. I could use the difference of price to get my self a set of perrin exhaust
Speed2th is offline   Reply With Quote
Old 06-30-2015, 07:15 AM   #25
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Originally Posted by krayzie View Post
Damn you, why post stuff I want when I just brought a set of used OEM+! 😱
Old 06-30-2015, 06:07 PM   #26
TXBRZ
TXBRZ's Avatar
Drives: Red 2015 BRZ Ltd
Try this EQ setting. Someone else told me about it and it helps a lot
09 A4 3.2 S-Line
TXBRZ is offline   Reply With Quote
2015 wrx vs 2015 gti vs ford focus st best all around dd and autocross jflogerzi Other Vehicles & General Automotive Discussions 13 05-25-2015 09:33 PM
2015 Formula Drift Tech Day - 3/28/2015 yospeed Southern California 1 03-05-2015 04:10 PM
Stock FRS stereo on Toyota 86 - Wiring problem position lights turn on/off the stereo dssence Electronics | Audio | NAV | Infotainment 0 01-27-2015 07:43 PM
Aside from 2015 Acura NSX and Toyota Supra, what else in 2015? stockysnail Northwest 7 01-13-2015 03:30 AM
Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC mav1178 Other Vehicles & General Automotive Discussions 1 05-23-2014 11:47 PM
