Old 06-17-2015, 08:14 AM   #267
raven1231
Originally Posted by Shady195 View Post
Really? I'm running the 93 EL map and from about 3k up my car pulls.
Ah you must have the PMD header instead of the PLM.
Old 06-17-2015, 08:18 AM   #268
Shady195
Drives: '13 10 Series FRS #1203
Ahh yes, the different letters must bring the torque dip back a few hundred RPM's
Shady195 is offline   Reply With Quote
The Following User Says Thank You to Shady195 For This Useful Post:
Koa (06-17-2015)
Old 06-17-2015, 08:21 AM   #269
raven1231
Yes sir! PMD will tell you more about it. That's the reason theirs cost about $300 more than the PLM.
Old 06-17-2015, 10:34 AM   #270
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Originally Posted by ZHoward View Post
Hi, so which one is 91 EL stage 2 best map? a little confused, running PLM header and weak around 3k-4k
That would be the third pic, runs 5 - 6. My best tune without wayno's additions. The torque dip isn't easy to tune out without a dedicated dyno. Get a supercharger. It completely eliminates torque dips. If I ever eliminate the torque dip on my car before I get my ESC, I'll post the Intake and Exhaust "safe" tables to put into your tune. I hate that torque dip with a smoldering resentment, like "How could they?". It's an insult to this fine automobile.
KoolBRZ is offline   Reply With Quote
The Following User Says Thank You to KoolBRZ For This Useful Post:
Koa (06-17-2015)
Old 06-17-2015, 11:23 AM   #271
ZHoward
ZHoward's Avatar
Drives: 2013 brz limited
Anyone PLM header can fit OEM air box? For me I think it is not enough space
ZHoward is offline   Reply With Quote
Old 06-17-2015, 11:30 AM   #272
Shady195
Yes. They include a plug to remove the resonating chamber that is in the way of the header.
The larger resonating chamber in the intake does get quite warm. There may be a chance of it melting under really heavy repeated load. However a full drift day in 90* heat and I did not have a problem.
I will be getting an aftermarket intake at some point however.
Old 06-17-2015, 12:15 PM   #273
KoolBRZ
KoolBRZ's Avatar
VE spreadsheet calc's anyone
I went to http://www.otctools.com/ve to calculate VE on my best run. Not good. Best at full throttle, top speed was 77%. High IAT was definitely a factor. I'm going to find the calculations to do a quick and dirty VE to include in a spreadsheet that I can paste my logs into. That will at least help me tune out the torque dip by increasing the VE in the bad areas. Here are some pics illustrating the bad areas.
Old 06-17-2015, 12:49 PM   #274
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
P.M.D. Header Dyno test results linked below.
[ame="https://www.youtube.com/watch?v=muAt4evb7Sk"]P.M. Dawn - Set Adrift On Memory Bliss (16:9 HD) /1991/ - YouTube[/ame]
edit:
This is what happens if you don't buy PMD. Apparently the part dies without you...
[ame="https://www.youtube.com/watch?v=C_qWlPCEnGM"]PM Dawn - I'd Die Without You - YouTube[/ame]
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 06-17-2015, 12:58 PM   #275
ZHoward
ZHoward's Avatar
Can u post pic? Thanks
Old 06-17-2015, 01:01 PM   #276
Koa
kool will you be my friend? I feel like we got off on the wrong foot.
Old 06-17-2015, 01:09 PM   #277
Shady195
A pic of what? There are plenty of this one and the nameless (they are identical as far as how they mount/clearances)
Old 06-17-2015, 09:56 PM   #278
Shady195
I have to admit while I love the sound of the header at natural revs, under a heavy load they sound like shit..
I just spent the night replacing and trying to find an exhaust leak, there does not appear to be one so I can only assume its the headers making noise from being "thin" and probably a shitty merge collector.
I'm going to play around a bit more and see if I can track it down, otherwise I'm going to attribute it to header noise.
The higher pitch sound at high RPM's doesn't bother me. I think these headers make the exhaust itself sound quite exotic with my TRD catback. I just can't stand going past buildings and hearing a "ticking/rattling" noise under load from the header.
Old 06-17-2015, 10:16 PM   #279
ZHoward
ZHoward's Avatar
I want I to see how can u fit OEM air intake, cause I tried and I don't have enough space
Old 06-17-2015, 10:17 PM   #280
Shady195
Is it hitting a small resonator box?
cheapbastards, dbags, knockoff
(Irvine / SoCal) ForSale FA20Club Long Tube Catted Header $350 mad_sb Engine, Exhaust, Bolt-Ons 12 03-31-2015 11:53 AM
wtb: sound tube delete inlet tube Jimmy817 Engine, Exhaust, Bolt-Ons 1 12-21-2014 09:15 AM
Long tube catted headers possible? wparsons Engine, Exhaust, Transmission 6 01-31-2014 09:56 AM
New 4-2-1 Long Tube Header Anorexic 86 Engine, Exhaust, Transmission 28 08-25-2013 03:28 PM
Cinco de Slamo Meet in Long Beach NY (Long Island) whitefrs New England 11 05-01-2013 09:03 AM
