Old 06-14-2015, 03:41 PM   #1
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Spec d headlight.
So I've had my spec d headlights for just barely under a year. Works great. Looks great. Perfect. But today I realize on the drivers side. My headlight started to separate from the housing. I'm guessing with the heat lately. It separated it. Would it be safe just to use a heat gun and basically push it back together?
Chen is offline   Reply With Quote
Old 06-14-2015, 10:05 PM   #2
BlackJesus
Shut up baby, I know it
BlackJesus's Avatar
Drives: 2013 BRZ DMG
You can do that but buy some extra sealant to ensure that no water leaks into it! Find high temp sealant for best result if you live in a very dry/hot area. Best wishes
BlackJesus is offline   Reply With Quote
Old 06-15-2015, 12:57 AM   #3
Chen
Regional Moderator
Chen's Avatar
I'm just gonna try and do this tomorrow. After I wait for the glue to dry. I'll wash the car.
Old 06-15-2015, 09:51 AM   #4
stevesnj
stevesnj's Avatar
Use windshield adhesive... the 3M version. AutoZone has it.
http://www.autozone.com/sealants-glu...ne/464397_0_0/
My 2016 Build thread
Old 06-16-2015, 11:45 PM   #5
Chen
Regional Moderator
Chen's Avatar
I took off the head light off the car. And it was a lot worse than I thought. I'm glad I caught it before it started to rain. I tried to use a heat gun to soften up the glue. And clamp then back together. But it was impossible. I figured I'd take off the whole housing and reapply it. Clips didn't line up or anything. Anybody have any other ideas? I would hate to throw these headlights away or let them rot in garage.
That's a pic of what they looked like as soon as I took them off the car.
Old 06-16-2015, 11:57 PM   #6
Irace86
Drives: BRZ + Ducati M796
Consider the oven method? Put them in the oven on 150-175 for five minutes. Take apart then reapply with more glue. It may take two times in the oven to take apart and to put back together. Use the heat; dont try to pull if it cools fast.
Irace86 is offline   Reply With Quote
Old 06-17-2015, 12:14 AM   #7
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Originally Posted by Irace86 View Post
Consider the oven method? Put them in the oven on 225° for 12-15 minutes. Take apart then reapply with more glue. It may take two times in the oven to take apart and to put back together. Use the heat; dont try to pull if it cools fast.
fixed*
Old 06-17-2015, 12:16 AM   #8
Chen
Regional Moderator
Chen's Avatar
I have thought about that. But I didn't attempt. There are 3 wires and a crap load of LEDs in the headlight and I didn't want to ruin those. I used a heat gun and blow drier to get the projector off the housing. Now the clips don't line up.
Old 06-17-2015, 12:21 AM   #9
boredom.is.me
Custom User Title
I solder LED SMD chips at 425+ Fahrenheit, occasionally up to 600 depending on particular situation. (Seconds versus minutes does make a difference, but not at this temperature.) This posses absolutely no threat. Just don't let any part of the headlight touch metal. Place the headlight on a wooden sheet/plank or blocks.
If you want to be safe, pop it in at 200 for 10 minutes. It's already separated for the most part.
The Following User Says Thank You to boredom.is.me For This Useful Post:
Koa (06-17-2015)
Old 06-17-2015, 12:23 AM   #10
Chen
Regional Moderator
Chen's Avatar
The headlight is separated now. I'm having trouble putting the headlight back together at this point.
Old 06-17-2015, 12:25 AM   #11
boredom.is.me
Custom User Title
Ah I see. What are the screw holes looking like? It shouldn't have even been possible to separate if it was screwed together. Did Spec D even use screws? Is there any chance of the black housing being messed up to the point where the screws pulled through?
Old 06-17-2015, 12:28 AM   #12
Chen
Regional Moderator
Chen's Avatar
They did use screws. 6 total. I don't believe the black housing was messed up at all. As they were never tampered with. Put it did just look like the 1 screw was just screwed into the glue.
Old 06-17-2015, 01:03 AM   #13
boredom.is.me
Custom User Title
It may have just been a miss assembly from the factory. Remove all of the screws, if you haven't already and try again. The sealant has to be malleable (HOT) or else the lens won't move even if it feels like it is... Unless you have Hulk hands or something.
Old 06-17-2015, 01:13 AM   #14
Irace86
Yea what he said. It needs to be pulled out of the oven fast and immediately pressed together because it'll get cool within maybe 15-30 seconds (depending on the oven setting) and be impossible to press together.
*****Official Spec-D headlight groupbuy 86SPEED Groupbuys 197 11-28-2015 12:48 AM
Spec D headlight HID Install instructions/wiring? jibai Cosmetic Modification (Interior/Exterior/Lighting) 9 04-05-2015 02:38 PM
My Spec D headlight review Gixxersixxerman Cosmetic Modification (Interior/Exterior/Lighting) 7 10-07-2014 06:31 PM
Spec-D Headlight Question iStanley Cosmetic Modification (Interior/Exterior/Lighting) 2 05-10-2014 06:44 AM
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 03:32 PM
