Old 06-16-2015, 02:51 PM   #1
Astroboy
Astroboy's Avatar
Drives: None
Is stabbing the throttle bad?
Yesterday, I did a test on my car to see if I had the di failure. Which I don't. I first let the car warm up to 85c, and then I stab the throttle in while in neutral at a complete stop. I just stabbed the throttle to red line three times. Is this bad? I noticed the engine somewhat bogged for a second when I did this. Note, my car is turbocharged.
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 06-16-2015, 02:56 PM   #2
dpgfunk
Drives: 2012 E92 M3, 2013 BRZ
depends on the type of blade you used to stab it
dpgfunk is offline   Reply With Quote
The Following 20 Users Say Thank You to dpgfunk For This Useful Post:
8R6 (06-17-2015), Andrew025 (06-18-2015), Astroboy (06-16-2015), brandonblt2 (06-18-2015), Calum (06-18-2015), civicdrivr (06-17-2015), DocWalt (06-16-2015), DustinS (06-18-2015), endless_pain (06-17-2015), GhostRai (06-18-2015), GotBRZ1691 (06-17-2015), Koa (06-16-2015), Pat.Thornton (06-19-2015), pushrod (06-18-2015), raven1231 (06-16-2015), Sportsguy83 (06-18-2015), STV3 (06-16-2015), TSwiftgavemecrabs (06-18-2015), Tye300 (06-18-2015), wparsons (06-16-2015)
Old 06-16-2015, 03:05 PM   #3
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I think the proper terminology would be "shanking the throttle".
The Following 3 Users Say Thank You to venturaII For This Useful Post:
8R6 (06-17-2015), GotBRZ1691 (06-17-2015), wparsons (06-16-2015)
Old 06-16-2015, 03:14 PM   #4
raven1231
I would assume its not great for it but it seems to still be running so I'd just carry on
Old 06-16-2015, 03:16 PM   #5
STV3
Señor Member
STV3's Avatar
The sharper the blade the better...
STV3 is offline   Reply With Quote
The Following User Says Thank You to STV3 For This Useful Post:
Old 06-16-2015, 03:53 PM   #6
Koa
fucking beat me to it, prick.
The Following User Says Thank You to Koa For This Useful Post:
dpgfunk (06-16-2015)
Old 06-16-2015, 03:55 PM   #7
STV3
Señor Member
STV3's Avatar
hmmm maybe just pricking the throttle will yield better results?
The Following 2 Users Say Thank You to STV3 For This Useful Post:
DustinS (06-18-2015), Koa (06-16-2015)
Old 06-16-2015, 03:56 PM   #8
Koa
STV all trying to get the remaining likes after homeboy stole the first sarcastic post award :'(
Old 06-16-2015, 04:07 PM   #9
STV3
Señor Member
STV3's Avatar
hahaha nah im just really bored at work and have a sarcastic sense of humor
Koa (06-17-2015)
Old 06-16-2015, 09:31 PM   #10
Astroboy
Astroboy's Avatar
Drives: None
Serious answers for a serious question guys please
Old 06-16-2015, 09:33 PM   #11
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
No, it's not bad for it unless you do it all the time or just sit there bouncing it off the rev limiter.
The Following User Says Thank You to DocWalt For This Useful Post:
Old 06-16-2015, 09:33 PM   #12
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
Sammakko is offline   Reply With Quote
The Following 3 Users Say Thank You to Sammakko For This Useful Post:
raven1231 (06-16-2015), shifter907 (06-18-2015), The Feds (06-17-2015)
Old 06-16-2015, 09:42 PM   #13
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
oh yeah stab the hell out of it, the more you stab it the better.
Old 06-16-2015, 09:42 PM   #14
Teseo
Drives: frs
Thats the feel of turbo lag
Teseo is online now   Reply With Quote
The Following User Says Thank You to Teseo For This Useful Post:
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? tracerit Engine, Exhaust, Transmission 11 02-15-2014 12:44 PM
throttle dip? JDM FRS Issues | Warranty | Recalls / TSB 18 07-07-2013 03:50 AM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
