Old 04-01-2014, 12:29 AM   #1
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Clutch Pedal Travel Stopper (CPTS) Modification
Included in Kit:
1x Threaded Bumper
1x Black-oxide steel washer (0.125 inch thick)
3x Type 316 stainless steel washer (0.05 inch thick)
1x Serrated-Flange nut
Tools Required:
9mm or 11/32in combination wrench (optional)
Instructions:
1. Locate the bracket holding the clutch pedal spring assembly and clutch pedal stop.
2. Carefully remove rectangular factory rubber clutch pedal stop by grabbing the sides and pulling out.
NOTE: Be careful not to use excessive force as this may damage the thin clutch stop.
3. The hole that the clutch pedal stop mounts to will now be visible, pictured below.
4. The nut will have to be placed behind the bracket. It may be necessary to depress the clutch pedal to move the spring assembly back. While depressed, place nut behind bracket with 11/32in or 9mm wrench, and slowly release clutch pedal.
WARNING: It may pinch fingers, so it is advised to have some help to depress the pedal while installing.
5. Thread bumper with desirable washer configuration.
NOTE: It is not advised to use all 4 washers. Recommended configurations:
0 washers
1 thick washer
1 thick and 1 thin washers
Up to 3 thin washers
NOTE: It is recommended to have no more than 0.18 inches thickness (1 thick and 1 thin washer) to ensure the bumper stud has sufficient amount of threads into the nut.
6. Test to verify that the clutch pedal can be depressed to engage the engine switch.
NOTE: If the engine does not start, remove washers to achieve the proper height.
NOTE: You will have to adjust the 2 sensors mounted below the dash. The lower sensor that is more easily accessible detects when the clutch is engaged and may need to be adjusted when lowering clutch pedal when the gear display is enabled. The higher sensor, that is more difficult to access detects when the clutch is depressed to enable the engine starter. Both sensors are adjusted with 14mm wrenches.
7. When final height is set, wipe any grease off of the rubber bumper and use rag or towel to grip the rubber stop and tighten using 9mm wrench on nut.
8. Admire your work, and enjoy your CPTS!
Feel free to message me for more information.
JDKane527 is offline   Reply With Quote
Old 04-28-2014, 11:24 PM   #2
TM
TM's Avatar
Drives: DGM BRZ 6MT
I got this kit from @JDKane527 and it fits into the bracket perfectly.
It was hard to shift into the gears unless I put extra pressure after the clutch hits the stopper to depress the pedal even more. I had the clutch pedal lowered 3 months ago so that it was either the same height or slightly lower than the brake pedal (don't remember, since I did the adjustment last year as well). I'm not sure if this is the cause of the problem or not.
I ended up chopping off about a fifth to a quarter of the bumper and I'm able to shift into gear perfectly now. The shifter is going into all of the gears like before.
The rubber is nice and dense inside, so I don't think it'll wear out any faster than when it had the outer layer.
I'll have to get used to the shorter travel, though. Didn't give it enough gas a couple of times when shifting because I'm so used to letting off the clutch half an inch before giving it gas. Now that the bumper is there, I need to give it gas as soon as I let go.
It is a lot less tiring to shift now! Since I'm usually pressing the clutch all the way down, I don't need to extend my calf muscles as much anymore.
TM is offline   Reply With Quote
Old 05-07-2014, 04:34 PM   #3
Dusty
Dusty's Avatar
Drives: 2013 Firestorm FR-S (traded).
Where are you buying this stopper? I'd like to try this out.
"I'm getting my turtleneck. I'm not defusing a bomb in this!"
Dusty is offline   Reply With Quote
Old 05-07-2014, 09:56 PM   #4
JDKane527
JDKane527's Avatar
Check your inbox
Old 06-15-2015, 11:31 PM   #5
yaguphire
Drives: white-out FR-S
Where to find this rubber stopper. I can't seem to find a stopper that can be tightened. Everywhere I see online just sell the rubber only.
yaguphire is offline   Reply With Quote
Old 06-15-2015, 11:42 PM   #6
I just cleaned the hard stop with some acetone and used one of these little buttons. Works perfectly and I have 15 extra.
Old 06-16-2015, 12:03 AM   #7
yaguphire
What u use to get the felt to stick?
Old 06-16-2015, 12:05 AM   #8
JDKane527
JDKane527's Avatar
They're probably self adhesive.
Old 06-16-2015, 12:09 AM   #9
lol... top right corner of the pic.
Seriously though, it works perfectly. Even feels better than the rubber stop.
Old 06-16-2015, 12:15 AM   #10
yaguphire
Terrible that this OEM rubber stopper is a POS
Old 06-16-2015, 12:25 AM   #11
yaguphire
If u have 15 extra that means you used 23 felt pads?
Old 06-16-2015, 01:14 AM   #12
lolol.... They were really thin.
My wife puts them on everything so we have a junk drawer half filled with opened packages.
...for the record, I only type "lol" if I actually lol. Good stuff.
Old 06-16-2015, 10:50 AM   #13
JDKane527
JDKane527's Avatar
Nearly anything is better than the OEM rubber stop. It's soft thin rubber that degrades easily over time, and is accelerated by heat.
Ultramaroon, great solution using local hardware store supplies. You can dial in the stop height precisely by stacking the discs. I'd be worried about the adhesive degrading over time due to heat, but with so many spares in the pack, you can change them pretty often.
Old 06-16-2015, 09:21 PM   #14
Calum
That Guy
Drives: 2013 asphalt FRS MT
ELIM5? What's the point of this? (serious)
Clutch Pedal Adjustment? EAGLE5 Northern California 41 05-20-2015 01:10 AM
Clutch Pedal Noise Help!! ZackZ Scion FR-S / Toyota 86 GT86 General Forum 6 09-06-2013 05:35 PM
Worn out clutch stopper AsianStyle Issues | Warranty | Recalls / TSB 1 07-05-2013 07:07 PM
New Clutch Pedal Stopper -- Bang For The Buck Mod!! 86_ZN6 Interior Parts (Incl. Lighting) 1 04-17-2013 10:26 PM
Clutch Stopper? wootwoot Engine, Exhaust, Transmission 4 08-06-2012 02:02 PM
