Old 06-11-2015, 11:23 AM   #2563
jvincent
jvincent's Avatar
For just driving around? Use the pressure on the door.
Messing with pressures only really matters if you are going to be pushing the car hard, which will cause the pressures to rise dramatically.
The Following 2 Users Say Thank You to jvincent For This Useful Post:
DeaconRoc (06-15-2015), strat61caster (06-11-2015)
Old 06-11-2015, 11:43 AM   #2564
dp1
driving smoother faster
Drives: Sold
Originally Posted by DeaconRoc View Post
If you change to a different brand and type of tyre but in stock sizes should you just stick with stock pressures or should they change? If they should change how's the best way to work out what to change them too (without the use of a racetrack, tyre thermometer, etc!)
It depends on ambient temps, driving, tire (size, UTQG and sidewall stiffness), camber, suspension, road surface, etc...usually stock pressures down to 2-4 PSI less work well for street/spirited driving, unless you're driving hard (track) and gain a lot of pressure when you go from say 80F cold to 230F hot tire temps. +10F adds up to 1PSI. Many tires like 35-40 PSI hot pressures...check wear on tire edges and pressures when tires are hot and adjust as needed.
dp1 is offline   Reply With Quote
The Following 2 Users Say Thank You to dp1 For This Useful Post:
Racecomp Engineering (06-11-2015), strat61caster (06-11-2015)
Old 06-11-2015, 11:55 AM   #2565
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Regardless of street/track, drive around in the most aggressive manner that you plan to (evasive maneuvers or maaaad skidz). Look at the wear and discoloration. You want to make sure that during normal driving, you're utilizing the available tread (>80%).
You can always run higher pressures. If you're want better mileage on a highway trip, you can boost then anywhere from 30 psi to the manufacturer's rating (45-50 psi usually). You can find this on the sidewall or TireRack.
Personally, I run my summer tires at higher pressures for highway trips, to put some wear on the center strip. AutoX tends to wear the shoulders more than the center... so the net result is uniform wear.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 06-11-2015, 01:02 PM   #2566
stockysnail
Just the tip
stockysnail's Avatar
I run 5lbs less in front compared to the rear. I get much better turn in and the rear gently comes around in the corner when at the track instead of dragging behind. I think I was doing about 23lbs in front and 28lbs in the rear cold and after the session was over it jumped up about 5-8psi when hot.
Old 06-11-2015, 03:00 PM   #2567
Pat
Pat's Avatar
Drives: 2023 BRZ
I think most people with significant track experience would tell you that's lower than it should be. I shoot for ~36 hot.
Old 06-11-2015, 11:54 PM   #2568
kalamitykode
I draiv de cah
kalamitykode's Avatar
Drives: 2022 BRZ Limited MT
Hey, I figured I'd post here instead of making a new thread. I've had my 2014 BRZ for a year and a half now, still running stock wheels. Aftermarket exhaust and CAI, but other than that it's stock except for aesthetics. I decided I'd like to go ahead and upgrade the suspension and lower the car. Not too low, but enough to reduce the gap. I don't track it, and I don't really plan to. It's my daily.
My question is, what parts are necessary to keep from causing damage or making the car dangerous to drive? I bought some BC Racing BR Series coilovers, the standard 8kg/mm set. I've had a few different answers from my go-to advice people, but they don't own the car so I'd like some input if anyone can help. I've been told I need some lower control arms (looking at the Voodoo 13 set), and others have said I won't need them since I won't be super low. Do I need toe arms and/or trailing arms? What about front pieces, like front LCAs?
I'd appreciate any help!
2022SubaruBRZ/CrystalWhitePearl/Limited
kalamitykode is offline   Reply With Quote
Old 06-12-2015, 12:55 AM   #2569
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
It all depends on the alignment specs that you are looking for and how low you drop your car. The rear will naturally gain more negative camber as you lower the car. Aftermarket LCAs will allow you adjust the negative camber, but it will also impact your toe and the built in tow adjuster has a limited range that it adjusts between. For the front I would get the crash bolts for ~$14 from your closest subaru or toyota dealer, that should allow you enough camber adjustment to not have understeer problems, as unlike the rear, the ride height does not impact your camber in the front. I hope that helps, of course I would listen to the experts first though.
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
The Following 2 Users Say Thank You to Turkish For This Useful Post:
kalamitykode (06-12-2015), Racecomp Engineering (06-12-2015)
Old 06-12-2015, 01:52 AM   #2570
kalamitykode
I draiv de cah
Good advice, thank you. I really don't plan on more than a 1" drop for now, at least until I get new wheels. I'll probably drop 1" then let them settle which if I understand correctly will be another 0.2" or so. I don't want to be "hellaflush" or anything, I still want the car to handle well.
Edit: The more I think about it, may not even go a full inch lol. I have mudflaps which extend down at least an inch so too low and those will scrape.
Old 06-14-2015, 10:15 PM   #2571
Turkish
Serial Cone Killer
Turkish's Avatar
A question for the experts. I am looking to purchase Tarmac 2 coilovers a lot sooner than I had originally anticipated and I was wanting to really start the final round of homework; in other words, I need to figure out spring rates
What I do with my car:
My car is a DD that is also used in local autocross competitions, I am building for the autocross side of things.
Suspension info:
Where I am currently:
Bilstein B8 shocks with RCE Tarmac springs - front and rear
RCE hollow sway bars - front and rear both on softer setting, considering stiffening the rear bar for a bit more oversteer.
OEM wheels with Michelin Pilot Super Sport 225/45r17
What I am working towards with my build:
RCE Tarmac 2 coilovers, spring rates TBD - front and rear
RCE hollow sway bars, stiffness settings TBD - front and rear
17x9" wheels with TBD tires at 245/40r17 - front and rear for autocross
OEM wheels with Michelin PSS 225/45r17 - front and rear for DD
So I am mostly happy with the current setup, but the simplicity of it (not adjustable) has lost its allure as I have become a better autocrosser than I was when I first started dabbling with the suspension. Right now the suspension is very close to neutral, but I would like to have a bit more oversteer to better suit my autocross driving style, hence why I am considering stiffening the rear sway bar in my current setup (I believe that is the correct thing to do??). Of all the coilovers I have seen, combined with my experience so far with RCE products, I believe that the Tarmac 2 coilovers are the next step in my suspension. I like the adjustability of these coilovers for both compression and rebound, and it will allow me to better dial in my suspension than just playing with tire pressure. By default the Tarmac 2 coilovers come with 400lb spring rates all around; by contrast the Tarmac springs are 280lbs front and 290lbs rear if I remember correctly. If I am looking to keep to a similar suspension balance, would I want the same spring rates on the coilovers or would I want stiffer or maybe softer???? What I would like to avoid is having to replace my sway bars again; I like the ones I have currently. Thanks in advance!
... his name is...
C'THULHU
Old 06-14-2015, 10:33 PM   #2572
cjd
cjd's Avatar
Drives: 2017 BRZ
Suspension info:
Hold off on swaybar changes till you've got the coilovers. I'm not sure what is competitive on the T2 for spring rate, but spring will be able to get you more oversteer of that's what you want - though you may want a higher rear rate than front. It's sweepers vs slalom tuning.
Do upper camber plates up front. You don't mention alignment but changes there will also change grip and thus balance. Anything that changes grip will do that, and more up front will be less understeer. LCAs in the back to have proper control over camber.
Old 06-14-2015, 11:21 PM   #2573
Turkish
Serial Cone Killer
Turkish's Avatar
I knew I forgot something! I have Raceseng CASCAM plates in the front and RacerX LCA's in the rear. As for alignment specs, I am currently using -3 degrees camber and 1/32 toe out on each wheel in the front for a combined toe out of 1/16, castor adjustment is maxed out but i do not recall the total castor off the top of my head atm. In the rear I have -1.5 degrees camber and 1/32 toe in for a combined 1/16 toe in. My sway bars have two stiffness settings and both are currently on the softer setting.
... his name is...
C'THULHU
Old 06-15-2015, 10:57 AM   #2574
Are you in STX and sticking with street tires?
- Andy
Old 06-15-2015, 01:39 PM   #2575
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Just got back from getting my car aligned after I dropped it on H&R sport springs. Here's the sheet they printed out for me.
The front:
I'll need to get camber bolts in order to the -1 camber you guys said was optimal, but I'm happy with the ~0 camber. Is there any negative to running 0 camber over -1 in the front?
The rear:
I don't think the 0.3 variance is anything concerned about, is it?
Before:
After:
Thanks in advanced guys!
Bobblehead is offline   Reply With Quote
Old 06-15-2015, 05:00 PM   #2576
Turkish
Serial Cone Killer
Turkish's Avatar
- Andy
Yes and yes
Sent from my SM-G900V using Tapatalk
... his name is...
C'THULHU
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
