#169 | |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
| The Following User Says Thank You to PandaSPUR For This Useful Post: | B-R-Z (02-18-2015) |
#171 |
Drives: BRZ Blue Series
Great post. Lots of information here. I am thinking about doing the same setup with an Alpine power pack amp. I am planning on getting a component 2 speaker system like the polk db651. I've had the infinity reference 6030cs and they were great speakers. I thought I'd give polk a try.
I have some doubts about how to do a component setup and would appreciate if someone could point me in the right direction. If I got component speakers, where would I install the crossovers? From what I've read I know that the factory tweeters are connected to the HU. Should I even install the crossovers or just install the tweeters to the factory wiring? Or should I just skip the components and go with a 2 way speaker? |
#172 |
Drives: FRS
I ran components, I put the crossovers in the back near the amp, used house wiring for the doors and ran new wires to the dash
#173 |
Radio wiring harness guru
Drives: 1996 SVX L AWD
Be careful choosing harnesses on eBay. Some will say "Metra xxx" (or Scosche yyy) but if you read closely they're only telling you those numbers to show comparability and they list some other company and part number as the manufacturer of the one they're actually selling.
I've also noticed that many of the vendors on eBay and Amazon keep showing the same old picture from when they first started selling the part, even though Metra (or whoever) has made changes (switched to a different plastic shell and/or added or deleted some of the wires). Even Crutchfield and Sonic Electronix are guilty of this. Some eBay and Amazon vendors show their old picture of one brand's harness but now are really selling a different brand. Also, some of the cheapest harnesses (such as those from DB Link) have smaller-gauge wires (20 or even 22 gauge on the Toyota 1761 type harnesses). Caveat emptor. Quote:
#174 | |
I am thinking about getting this 3 way components. http://www.sonicelectronix.com/item_...PPI-P65c3.html Was it hard to run wires to the dash? Did you pull wires from two sides or just one side? Do I just insulate the stock tweeter wires if I run new wires? Sorry for too many questions. Trying to figure this out. |
#175 |
Drives: 15 Steel FRS
I have found Pioneer recently released a small new amp which is rated at 15A too
there is the product link: http://www.pioneerelectronics.com/PU...eries/GM-D1004 I think I will buy this and used the same wire method as OP, but at same time, I just worried if I only used 2ch and 90 RMS to feed the two door speakers, then the dash and rear speakers won't be power enough for the whole sound stage in car? anyone has any experience about this setup? Or is it possible to bypass the dash and rear speaker input from HU, so I can wire in parallel then feed dash and rear speakers in 2CH 45w, and the other 2ch 45w goes door speakers.
#176 | |
Drives: 2013 BRZ Limited w/ AVO Stage 1.5T
| The Following User Says Thank You to Simisimi For This Useful Post: | Porcupint (05-20-2015) |
#177 |
Good results
My Alpine amp went in pretty easily thanks to the great posts in this thread. I elected to bridge mine since my component speakers (Polk DXi6501) can handle 100 watts. I bought 16 square feet of 50 mil adhesive sound deadening on Amazon where I also sourced the Metra 70-7601. I also used the stuffing from an old seat cushion to fill the area directly behind the door speakers. Thankfully I got the amp from Crutchfield because bridging by the instructions was not within my abilities. Their support rocks and justifies the slightly higher cost for me.
I am impressed. The gain is set to MIN and I am getting volume and clarity and a ton more thump. I am also hearing that background hiss at a very low but noticeable level as has been posted by others. If anyone figures that out I would love to be rid of it. Roughly a $400 upgrade over stock audio and worth every cent. Highly recommended and relatively easy once you wrap your head around the wiring nest. |
| The Following User Says Thank You to Simisimi For This Useful Post: | Hyper4mance2k (05-25-2015) |
#178 | |
Drives: 13 GBS BRZ
#179 |
#180 |
Drives: Subaru BRZ 2013
Feeding dash and door speakers from 4chan amp using oem wire from the back?
I was wondering if those:
Green = Left speaker signal input from HU [PIN 3 and 9] Purple = Right Speaker signal in from HU [PIN 4 and 10] Does this signal is the same signal sent to the front dash speaker? If I could unplug the front signal from the HU and then feed those Green and purple from the back from a 4 chan amp to front dash speaker. and also use the grey and white for the door as already described. I already have a RCA going to the back to feed my amp Thank you Last edited by CybexBRZ; 06-13-2015 at 04:14 PM. Reason: Put a title |
#181 | |
I love peanut butter
Drives: 2013 SWP BRZ Limited
#182 | |
I will only run a set on tweeter of a component set, it will be plug on a 50 rms amp but should not draw much power. Yes, after unplug the input from the back of the HU I'll check if there is still power on those wires at the back. |
| Wideband LC-1 wiring. | MattF | Forced Induction | 9 | 07-09-2013 09:33 AM |
| Wiring a sub in a BRZ | Shizuma | Electronics | Audio | NAV | Infotainment | 22 | 06-08-2013 01:02 PM |
| So is there a DIY yet for BRZ headlight wiring for the FR-S? | seven | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 11-25-2012 09:24 PM |
| x940bt wiring help | encity5 | Electronics | Audio | NAV | Infotainment | 10 | 08-31-2012 04:08 PM |
| Is foglight wiring in the car? | FastLap | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 08-26-2012 11:54 PM |
