Old 06-14-2015, 12:28 PM   #1
X Factor
Drives: 2013 Red BRZ Limited
New wheels/tires=alignment
Getting new 18x8.5 w/245-45's, is an alignment required? If so do you align friends nt and rear?
X Factor is offline   Reply With Quote
Old 06-14-2015, 12:35 PM   #2
adamg
Drives: brz
if your just getting new wheels then you probably don't need an alignment unless you have a lot of miles on your car and have never gotten one anyways, then it wouldn't be a bad idea
adamg is offline   Reply With Quote
Old 06-14-2015, 12:42 PM   #3
X Factor
I'm at 28k, never aligned.
Old 06-14-2015, 01:07 PM   #4
fx35s
Drives: 2013 Subaru BRZ
You might wanna get an alignment then.
Any aftermarket parts like LCA, toe arm, end links, etc?
You'd love how a bit of tuning the alignment can affect the handling
fx35s is offline   Reply With Quote
Old 06-14-2015, 01:52 PM   #5
X Factor
No aftermarket parts, yet.
Old 06-14-2015, 02:36 PM   #6
cjd
cjd's Avatar
Drives: 2017 BRZ
That's a pretty big jump in tire diameter! 245/40/17 is about stock, 245/45/18 is quite a bit bigger. 245/35/18 is the right size though...
Old 06-14-2015, 09:20 PM   #7
tyrantcf
Drives: '16 WRX, CBR1000RR
Alignment not required, but recommended due to your mileage.
If you plan on doing some suspension parts soon, hold off on the alignment until you get it all installed.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Wheels & Alignment - Plano Onikudaki Southwest 6 09-12-2014 10:43 PM
Question about balancing/alignment on new wheels The_Societan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-23-2013 11:42 PM
Oddities: new alignment, tires and wheels rainmonkey Tracking / Autocross / HPDE / Drifting 12 10-25-2013 09:29 PM
Wider wheels: need an alignment? OakmanSmalls Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 07-18-2013 11:34 AM
