Old 06-13-2015, 05:04 PM   #15
Jake_86
Jake_86's Avatar
i was being serious. all the greats do it
Gold Accented GT86 Build Thread
Live Fast, Die Young.
Jake_86 is offline   Reply With Quote
The Following User Says Thank You to Jake_86 For This Useful Post:
Hyper4mance2k (06-14-2015)
Old 06-13-2015, 09:35 PM   #16
The Feds
Government Issued
The Feds's Avatar
Drives: Unicycle
I like this hood...
I'm just skeptical bout the rain issue. Vents that big and it still stays dry in the engine bay? Anything to channel water?
2015 Crystal White Pearl BRZ Limited AT6 - Ordered & Waiting delivery
The Feds is offline   Reply With Quote
Old 06-14-2015, 01:21 AM   #17
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Originally Posted by The Feds View Post
I like this hood...
It doesnt stay dry at all, but this isn't a 44 Ford with points that you have to worry about getting wet... How do you think you clean an engine bay? Water.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 06-15-2015, 09:46 AM   #18
nelsmar
I like this hood...
Have you ever cleaned your bay before? When you did what did you use to clean it?
Having daily driven a car with a vented hood for 3-4 years in an area with snow drifts that would touch the roof of your home... I never had a problem, and I never parked indoors. I drove in the rain, I drove in monsoons, I drove in the snow. The alternator needed a rebuild sooner than normal due to corrosion (at roughly 80-90k miles after the hood install). A lot of raw steel components that were near heat such as the header heat shields would show signs of rust. However this car doesn't have many parts like this and not everyone here is parking their car in the rain. The only legitimate issues are corrosion to lower quality parts, and fear of water under extreme monsoon conditions (I live in Phoenix now, when it rains it RAINS and floods). And even then the rain bit is really quite a stupid concern. People do water injection all the time on their cars (Hell I am considering doing it on mine here soon). You aren't going to hydrolock the car by driving in the rain.
If you are really concerned there are some vented hoods with rain catches that push the rain to the side of the bay to drip near the wheel wells. However they do not extra air from the bay as well as the guards go directly under the vents and the air doesn't have as direct of a flow. Luckily most of them are removable so you can install them during winter months. I have been strongly considering a hood like this to help extract the mass amount of heat my car produces to fight the 100-115F weather I drive in, but really just don't like how aggressive it looks and am considering doing just a few Louvers in my hood to help out.
Most of our parts that would corrode are painted on this car such as the injector covers. Your header shields may rust but thats really about it. If you are worried about corrosion then try to avoid parking in the rain. When driving the water contamination is low as the water goes up and over the car not in it. Even stock cars will get some water under the hood from driving in wet conditions as the rain water can go through the radiator (and around it) as well as splash up over the under panels of the car (which help reduce moister as well). I used to drive in the rain with my S2000 all the time. I only remember two occasions in which I had to pull over under an overpass to put my roof up because the monsoons were so aggressive. other than those I barely got wet with the top down at 50+MPH unless I was at a complete stop.
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
Hyper4mance2k (06-15-2015)
Old 06-15-2015, 01:02 PM   #19
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
This, but I was too lazy to spell it out for the nay sayers.
Old 06-15-2015, 04:08 PM   #20
ModinJapan
ModinJapan's Avatar
Drives: 2013 SCION FRS
Yup like everyone is saying! No problems. My buddies FRS with the Seibon vented hood is still running after daily car washes and numerous rain storms. :P
-Josh
ModinJapan is offline   Reply With Quote
Old 06-15-2015, 07:07 PM   #21
The Feds
Government Issued
The Feds's Avatar
Drives: Unicycle
'preciate the information...
Old 06-18-2015, 12:31 PM   #22
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
The car in the OP is my car and to answer some questions:
I weighed both the stock hood and the seibon hood I received and they were both the same. The DV style hood from what ive seen/read is the only hood seibon makes that seems to have some minor fitment issues. I actually have spacers in my fenders in order to match the contour of the hood (it is raised up higher than the fenders right above the arch) and it sits a bit too low in the front. but i deal with it. its something that most people dont even notice.
Rain? I just say fuck it. If you dont have a short ram intake, or something that water will get into it wont matter. Ive been running this hood for over 2 years with no problems and it rains A LOT where i live
Kuzuri is offline   Reply With Quote
The Following 3 Users Say Thank You to Kuzuri For This Useful Post:
Hyper4mance2k (06-18-2015), kch (06-18-2015), TheBRZsKnees (01-05-2019)
Old 06-18-2015, 12:51 PM   #23
nelsmar
People run water injection every day. If i can drive in a full blown monsoon in Arizona (yes the water goes over the sidewalk within minutes) you'll be just fine. :P
Foam filters can suck though since they can hold such a large volume of water. I've had a TROLOLOLOL experience with that once upon a time. I ended up pulling over, removing it (because I couldn't even move) and driving home without the filter and using a blow dryer to get the 50 gallons of water out of the foam filter. That was the last foam filter i ever used.
Old 08-13-2015, 07:58 PM   #24
Ashikabi
Ashikabi's Avatar
So I'm just gonna jack this thread quick. Everywhere I've seen says water on the engine won't hurt anything. Ok that's legit, but what about this ECU looking thing and this little breather hole on the oil filter bowl? Name:  uploadfromtaptalk1439506660309.jpeg
Size:  102.1 KBName:  uploadfromtaptalk1439506668649.jpeg
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 08-13-2015, 08:13 PM   #25
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
It's not like u gonna drive through a water puddle the depth of your hood. Then ya it will be totaled. 😁
Old 08-13-2015, 08:16 PM   #26
Ashikabi
Ashikabi's Avatar
Well I only ask cuz the vents will be directly over these items so that little bowl will get filled up every time it rains
Old 08-13-2015, 08:18 PM   #27
juliog
juliog's Avatar
Drives: 86
Originally Posted by Hyper4mance2k View Post
Are you happy with your purchase?
I'm merely satisfied. It's a cheap part and I knew fitment wouldn't be perfect
Did you see noticeable reduction in under hood temps?
Oil temps at the track are just a bit lower than the same car with OEM hood. I assume my car cools down faster too.
Did you see any measurable changes in gas mileage?
Nope.
Is it actually lighter than our featherweight stock hood?
Probably not. Did not weight.
How has it stood up to the test of time(wear)?
It's holding fine. But I color matched mine.
Does it shake or flop at high speeds?
Yes, it shake up & down significantly after 90MPH. You should use latches on all aftermarket hoods.
What is your overall impression of build quality?
Bad. Fitment is far from perfect. One side (where it meets the fender) is slightly higher. The gap where it meets the bumper is also not consistent across the width of the hood. On one side, the gap is almost as think as the weatherstrip below.
YMMV. Fitment variance of Seibon parts is huge. You might get a perfect part, but don't count on it.
No rain guards either, so engine bay will get dirty. Expect having to clean your bay more often.
juliog is offline   Reply With Quote
The Following User Says Thank You to juliog For This Useful Post:
Hyper4mance2k (08-14-2015)
Old 04-19-2017, 05:35 PM   #28
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
THREAD NECRO!!!!!!
just curious as to where the vents "dump" in relation to the belt path. I'm also curious as to how much clearance it removes underhood. I mainly just want to keep the alternator from getting drenched during heavy rains as well as the belt. the rest of the stuff is weatherpacked and sealed so no biggie. not sure if i need to get a grimmspeed tool tray to deflect water or not is all.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Seibon TS Hood questions SLC_BRZ Cosmetic Modification (Interior/Exterior/Lighting) 3 06-02-2015 09:55 PM
Seibon VS Style Hood. $325 harkbrz Canada Classifieds 10 01-04-2015 12:12 PM
WTB: VS-Style Seibon CF Hood ELutz04 Want-To-Buy Requests 0 10-03-2014 09:18 AM
wtb seibon ts style carbon fiber hood riironman Want-To-Buy Requests 6 07-26-2014 01:23 AM
Seibon FA Style Hood and CSL Style Trunk invisage Cosmetic Modification (Interior/Exterior/Lighting) 2 04-17-2013 02:39 AM
