Northwest AK, ID, OR, WA
Old 06-11-2015, 12:34 AM   #15
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
@Lunatic, @Decay107, I'm looking very forward to running with you guys. Focusing on getting some more instructed time under my belt this summer. Safety first.
Well I know I'll be doing at least two more this season both of which offer instruction. There is the NWAA day at ORP, super cheap at $125. Ran with them last year and had a great time!
http://www.motorsportreg.com/events/...5#.VXkPSflVhBd
And I'll also be doing the Fall AROO day at PIR, no sign up yet, but will probably be the first or second week of October.
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
Ultramaroon (06-11-2015)
Old 06-11-2015, 01:54 PM   #16
sachu
Drives: rocketship
Thanks for that. i will ccertainly run that day
sachu is offline   Reply With Quote
Old 06-11-2015, 07:41 PM   #17
Decay107
Decay107's Avatar
Sounds like they'll be running the short course in the afternoon, can't say I'm crazy about that as all the best corners are in the North loop.
Old 06-13-2015, 12:30 AM   #18
Decay107
Decay107's Avatar
Ho-ly-shit! The short course is freaking awesome! You sacrifice the half pipe for a straightishaway with a ton of short elevation change, car basically dances around underneath you the whoke time. Only two street cars there me and a C7, we were running a similar pace (which was way quicker than the majority of the field). Did about 2 hours on the full course and an hour on the short one.
Also, pretty sure I melted a throw out bearing
Old 06-13-2015, 12:52 AM   #19
Want help dropping your tranny?
Old 06-13-2015, 01:14 AM   #20
Decay107
Decay107's Avatar
Gonna try a few other things first, it's the infamous squeak right now. Just for shits and grins, going to try to get it warrantied.
In other news, sounds like I burned a new hole in the exhaust (need to get under to investigate) but I think I found a good oil balance. Couldn't get redline 5w30 with a setrab 16 row core to drop below about 60 psi (front of engine) or get higher than about 230F, and this was an 80 degree day and old oil (3 track days total on it)
Also I'll have you know that tranny is an offensive term and you shouldn't use it.
Old 06-13-2015, 01:36 AM   #21
It's ok at the drag strip.
Decay107 (06-13-2015)
Old 06-13-2015, 02:13 AM   #22
stockysnail
Just the tip
stockysnail's Avatar
Once I save up for new front track pads, I'll join in on the track time again. Hopefully I get one more in before the season is over. Trying to finish paying off my debts by the end of the year (not counting house and car). I'll have more $ per month then unless I try to pay off my car quick next.
Old 06-14-2015, 07:52 PM   #23
jblmr2
jblmr2's Avatar
OK @Decay107 how did it go?
jblmr2 is offline   Reply With Quote
Old 06-15-2015, 12:52 AM   #24
Decay107
Decay107's Avatar
It was great! Only 2 road cars (myself and a c7), got a lot quicker thanks to the open run format. Ended up with about three hours of track time not including warm up or cool down laps!
Also, I thought I'd dislike the sort course, but man was I wrong. Due to all the quick elevation change car basically dances right at the limit of grip through the entire bypass "straight"
Old 06-15-2015, 09:06 AM   #25
jblmr2
jblmr2's Avatar
Glad you enjoyed it. I wasn't able to rearrange my schedule or I would have been there. The open format is fun, coming and going as you please. I assume you ran clockwise? If so I've done the bypass in that direction and you're right, it's a straight that's not straight....typical ORP.
Just to let you know there is an event coming up at The Ridge on the fourth of July that's reasonably priced, $235. Most of the events there are $300>. The outfit putting it on is TSS/FFD. Registration is via Motorsportsreg.
Old 06-15-2015, 11:03 AM   #26
Decay107
Decay107's Avatar
Yep, clockwise. Almost went up the hill after turn 5 right after they changed to the bypass, needed a real quick correction to not plow through the cones blocking off the northern part of the track.
And thanks for the info on the Ridge! I've been meaning to try it for a while, gotta see if I can fix the stuff I broke and still have some room in the budget to squeeze it in.
Old 06-15-2015, 12:24 PM   #27
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
You're gonna like The Ridge. There are mixed opinions about "The Ridge Complex" (aka, mini corkscrew) but overall the track is very rewarding, flows well, without being overly technical and has a good variation of all the bits; big long straight, a long sweeper, elevation changes, blind corner, hairpin and corkscrew.
PRO86 | WTCC | STL
The Following User Says Thank You to rice_classic For This Useful Post:
Decay107 (06-15-2015)
Open track day June 13th Mike @ MRP NY / NJ / CT / PA 0 05-30-2013 01:59 AM
Open track day in az Kdej1 Tracking / Autocross / HPDE / Drifting 4 05-20-2013 03:13 PM
Open Track Day - Big Willow Aug 26th fastlaneracingschool Tracking / Autocross / HPDE / Drifting 0 08-24-2012 12:32 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs NY / NJ / CT / PA 11 08-20-2012 11:31 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs Tracking / Autocross / HPDE / Drifting 0 08-14-2012 06:46 PM
